Modelism - RHC Forum: BEAVER DHC2 din depron - Modelism - RHC Forum
  • 24 Pagini +
  • 12
  • 13
  • 14
BEAVER DHC2 din depron Pentru motor 400
#331 Useril este offline   boddha
  • Postari: 64
  • Inregistrat: 10-June 05
Postat 25 May 2006 - 04:20 PM
Ce diedru am pus?
Am pus diedrul dat de inaltimea scrumierei asezate la nervura 2 exterioara a aripii, asta pe o masa care are ea insasi diedru negativ.
Toate bune,
Boddha
#332 Useril este offline   olly
  • Postari: 676
  • Inregistrat: 03-April 05
Postat 25 May 2006 - 04:23 PM
:rolleyes: merci .si eu am de lipit semiaripile . cred ca maine o sa incerc
<<<ZA MOLDAVIAN BRAZARS>>>
Radiolink AT10, 2,4GHz
GRUNAU BABY 2.3M
ASW-28 2M
#333 Useril este offline   boddha
  • Postari: 64
Postat 25 May 2006 - 04:26 PM
Nu lasa pe maine ce poti lipi azi :rolleyes:
Toate bune,
Boddha
#334 Useril este offline   olly
  • Postari: 676
Postat 25 May 2006 - 04:27 PM
nu ma mai apuc azi, ca vine mama si face criza cand ma vede cu smirghel si cu lipici in sufragerie :rolleyes: http://www.rhcforum....tyle_emoticons/default/ic_00.gif
GRUNAU BABY 2.3M
ASW-28 2M
#335 Useril este offline   SILVIU66
Postat 25 May 2006 - 04:34 PM
olly, la 25 May 2006, 17:27, a spus:
ca vine mama si face criza cand ma vede cu smirghel si cu lipici in sufragerie http://www.rhcforum....tyle_emoticons/default/ic_13.gif http://www.rhcforum....tyle_emoticons/default/ic_00.gif
sa vezi cum e cand vine nevasta...ajungi tu si acolo... http://www.rhcforum....tyle_emoticons/default/ic_13.gif :rolleyes: http://www.rhcforum....tyle_emoticons/default/ic_13.gif http://www.rhcforum....tyle_emoticons/default/ic_19.gif
#336 Useril este offline   ciobelix
  • Postari: 297
  • Inregistrat: 12-March 06
Postat 25 May 2006 - 06:24 PM
azi e ziua cea mareeeee. ma apuc de castor. am scapat de toate tezele. i am happy. ura.
ciobelicz neboonu trage cu tunu
#337 Useril este offline   kele
  • Postari: 210
  • Inregistrat: 13-March 06
Postat 25 May 2006 - 08:56 PM
asa, asa... http://www.rhcforum....tyle_emoticons/default/rolleyes.gif
Da aripi viselor tale!
#338 Useril este offline   jester
  • Postari: 1296
  • Inregistrat: 11-April 04
Postat 25 May 2006 - 09:47 PM
mai fratilor, bine ati venit in breasla castorarilor. uite ca se umple forumul de castori.. http://www.rhcforum....tyle_emoticons/default/smile.gif foarte bine. multi inainte
#339 Useril este offline   Intruder
  • Postari: 256
  • Inregistrat: 04-June 03
Postat 26 May 2006 - 09:49 AM
Ingros si eu randurile castorarilor, m-am apucat nu de unul ci de doua in paralel. Asta ca sa ma asigur ca daca rup unul am inlocuitor B)
O sa pun si ceva poze. Acum astept sa primesc comanda de balsa. Deocamdata am doua fuselaje cu ampenajele montate. Mai trebuie aripile.
#340 Useril este offline   kele
  • Postari: 210
Postat 26 May 2006 - 09:58 AM
Bine ai venit. Deja ma gandesc sa organizam o intalnire a castorarilor. EXCLUSIV! B)
#341 Useril este offline   ciobelix
  • Postari: 297
Postat 26 May 2006 - 10:20 AM
ar fi tare. io o sa ii zis alui meu castror broscos ca il fac din depron verede ca broasca :D B)
#342 Useril este offline   Intruder
  • Postari: 256
Postat 26 May 2006 - 11:32 AM
uite un beaveras dragut.
http://www.abu-onlin...beaver_dhc2.htm
interesanta solutia pentru trenul de aterizare. Cred ca o sa aleg si eu solutia asta. E si mai usor si mai elastic si prinderea mi se pare mai buna decat cu placa de aluminiu.
si depronul meu tot verde este. am vazut ceva spray vopsea pentru polistiren la concurenta. poate ii schimb un pic infatisarea :rolleyes:
#343 Useril este offline   racketistu
  • Postari: 223
  • Inregistrat: 24-April 06
Postat 26 May 2006 - 07:59 PM
Am si eu o intrebare.Pot folosi servo nano la beaver atat la eleroane cat si la profundor si directie.
Ideas for life'gfh
#344 Useril este offline   kele
  • Postari: 210
Postat 26 May 2006 - 09:44 PM
Pentru siguranta e bine ca servourile sa aiba moment > 1 kgcm. Eu am pe al meu SG90, categoria micro si merg fara probleme.
#345 Useril este offline   racketistu
  • Postari: 223
Postat 26 May 2006 - 09:58 PM
Pentru aripile unui beaver invelite cu solarfilm trebuiesc altfel de nervuri decat cele pentru aripile invelite cu depron?Daca da de ce?Si ce fel de nervuri.Ce se intampla daca folosesc nervurile pentru aripile invelite cu depron pentru aripile invelite cu solar?
Ideas for life'gfh
#346 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:03 PM
in continuare voi pune cateva poze cu nout bot alavionului, din polistiren invelit cu depron,cel original fiind incepator l-am crapat.
#347 Useril este offline   alexu`
  • Postari: 87
  • Inregistrat: 22-July 05
Postat 26 May 2006 - 10:05 PM
Nu, nu trebuie alte nervuri din cate stiu eu.
Alexandru
Nu lasa MiG-ul 29 din mana pe F-ul 16 de pe gard!...
#348 Useril este offline   jester
  • Postari: 1296
daca le folosesti tot pe alea, vei alea alt profil. ca solarul are grosimea neglijabila,pe cand asa, depronul avea 3 mm de pe parte, 3 pe alta. intrebarea e daca le poti face tot din depron si apoi inveli cu solar, daca nu se topesc.
#349 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:07 PM
poaza 2..
#350 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:08 PM
#351 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:10 PM
#352 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:11 PM
#353 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:13 PM
si ultima, pe avion...
#354 Useril este offline   kele
  • Postari: 210
Postat 26 May 2006 - 10:16 PM
Sculptor te-ai nascut jester. Fromus lucrat si se vede de la o posta ca e si rezistent. Pe cantar cum se prezinta?
#355 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:27 PM
B) multuimesc@kele. omu la disperare face de toate...daca am spart botu original la decolare, trebuia altul mai rezistent.. la cantar sunt vreo 25 g in plus,dar un bot rezistent indeajuns pt mine :D
sa revin la intrebarea lui @racketistu:
dupa cum se vede in poze,profilele apartin aceluiasi avion, castorul nostru. cel mare e profilul final,fara 6mm de la bot, unde vine baghata de balsa. cel mai mic, in afara faptului ca e mai scurt, ca vin eleroanele in continuare, e si mai subtire. dupa ce vine invelit cu depron de 3 pe extra si intrados, va ajunge in final ca cel mare. daca il lasi asa si il invelesti cu solar, aripa va avea profilul cel subtire, care nu garantez ca va ridica vreodata avionul. daca vrei sa-l faci cu solar, atunci toata aripa va trebui sa aibe profilul cel mare, nu cel mic.cel mare,pt ca solarul are grosime neglijabila cum ziceam, si deci nu va modofica profilul substantial.
PS
imi cer scuze pt calitatea pozei, webu bata-lvina.am facut-o si pe intuneric, acuma seara inm graba.
#356 Useril este offline   jester
  • Postari: 1296
Postat 26 May 2006 - 10:50 PM
as vrea sa rog pe colegii nostrii, dacaare cineva plan de beaver, in afara de asta din depron,am vazut ca e cineva care a facut unul din blasa rosu, m-as interesa planul daca se poate.
multumesc anticipat.
#357 Useril este offline   ciobelix
  • Postari: 297
Postat 29 May 2006 - 11:10 AM
am si eo o dilemuta mica: eleroanele tre sa le fac aerodinamice sau e suficienta o bucata de depron simpla cu forma celei din plan? a , si cum ai indoit boddha depronu asa bine si a ramas asa? cu ce l-ai lipit?
cu stima,
florin
#358 Useril este offline   boddha
  • Postari: 64
Postat 29 May 2006 - 11:53 AM
Salut! Ca sa fii prevenit de la inceput, nu sunt eu cel mai in masura sa-ti raspunda la intrebari.
Dar acum, daca tot am apucat sa raspund, voi scrie pana la capat cum vad eu lucrurile (hei, "cei mari", ma corectati, da, daca scriu prostii?).
Eleroanele NU pot fi fin depron "chior", pentru ca pot flamba foarte tare (banuiesc ca doar daca nu ai optat pentru solutia balamalelor din scotch, ceea ce am inteles ca nu e recomadabil la dimensiunile astea). De aceea eu le-am facut din balsa de 6; ca varianta ar fi si 2 straturi de 3, lipite bine (mai rezistente, iar ca aport de greutate - dat de adeziv - neglijabil).
Tot din motive de flambaj Men m-a sfatuit sa pun chiar 3 balamale pe eleron (dar eu nu l-am ascultat si am facut economie, am pus doar doua:P).
Indoitul depronului e floare la ureche, si am vazut ca daca pui sensul nervurilor materialului (vezi p-aici prin forum despre asta) cum trebuie (pe planuri chiar e specificat), si daca mai tragi si niste dungi pe spatele depronului (acolo unde nu se vede, deci pe interiorul curburii) cu un pix sau ceva asemanator - FARA SA TAI MATERIALUL, FARA SA AJUNGI IN PARTEA CEALALTA, se indoaie singurel, de mai mare dragul.
Era sa uit de faza cu lipitul: in mare parte, PICATURA sa traiasca... si apoi cu niste adeziv (Bison, o pasta alba, se gaseste la Praktiker-Bricostore-Carrefour-Cora etc) ceva cu Fix... Dar nu mi-as pune mare baza in el, nu stiu cum se comporta in timp si la solicitari.
Acum, daca te intereseaza ceva in mod special, cum am facut o piesa anume, poti sa-mi dai MI, si te voi lamuri. Sau cel putin voi incerca...
Aceasta postare a fost editata de boddha: 29 May 2006 - 11:55 AM
Toate bune,
Boddha
#359 Useril este offline   ciobelix
  • Postari: 297
Postat 29 May 2006 - 08:23 PM
ma intereseaza aqsa, in mod mai special piesa care a facuto si jester, ca tot nu mam prins
#360 Useril este offline   jester
  • Postari: 1296
Postat 29 May 2006 - 10:57 PM
salut.
@boddha
picatura nu e un fel de superglue? adica nu e ciano? nu topeste depronul? cat despre balamale, eu am facut eleronul din balsa si tot am pus 3 balamale ca 2 nu parea suficiente. adica de jumatati de balama. o balama de aia de 1 latime am taiat-o in 2. cu putina grija sa o pun in asa fel incat sa nu lase eleronul sa se miste in lateral, a iesit super.
@ciobelix
daca la bot te referi, ala oricum ti-l fac eu, ti-am promis.
e f simplu facut. o bucata de pilsitren grosimea cat lungimea botului(eu am lipit 2 bucati ca alea erau exact cat imi trebuia. era un polistiren(ex pilistiren, my mistake, sorry :()ramas de la frigider, l-am pus deoparte ca nu stie cand am nevoie de el si uite ca am avut), ala sculptat in forma dorita si apoi invelit cu depron de 3, ti cont de dimensiuni ca la final cu depronul pe el sa fie lat cat e si avionul. asta o faci simplu.pe partea din spate a lui desenezi panoul din fata, iar pe partea din fata a lui desenezi panoul de foc, ala rotund. apoi cu o pisica(cred ca asa se cheama smurglu pe bucata de lemn) slefuiesti pana ajungi la contur, si faci trecerile de la forma aia patratoasa cu triunghi pe cap la forma rotunda. apoi invelesi si il lipesti pe avion, de panoul din fata, cel pe care l-ai desenat la inceput. eu zic ca pozele sunt destul de explicite. :(
Aceasta postare a fost editata de jester: 31 May 2006 - 07:37 PM
  • 24 Pagini +
  • 12
  • 13
  • 14
