Sbach 342 36% Pilot RC
Postat 13 October 2012 - 12:08 PM
De vanzare Sbach 342 36% de la Pilot RC RTF
Specificati:
Wingspan: 107 in(2.7M)
Wing Area: 2296 sq in(14818sq cm)
Fuselage length: 95.7 in(2.43M)
Weight: 27.5 lbs (12.5kg)
Engine: 100cc
Este echipat cu urmatoarele:
Motor: DLE 111 (reglat setat si toate cele, merge impecabil)
Servo: 6xHITECH HS-7954SH High Voltage de 29kg ( 4 pe aripi,2 pe profundor) 1xHS-7950TH High Voltage de 35kg (pe directie)
Elice: 27x10 Carbon
Receptor/PowerBox: AR9100 3 Sateliti DSM2 8,4V spre servouri
Statie : Spektrum DX7 7 canale (binduita,setata,avion trimat pe ea)
Acumulatori: 2x NANOTECH 7,2V 3300 MAH (pe receptie) 1x NANOTECH 7,2V 2200 MAH (pe aprindere) 1x NANOTECH 7,2V 1300 MAH (pentru pompa de fum)
Instalatie de Fum
Modelul este RTF,are nevoie doar de benzina si incarcat baterii.
Pret: 7000lei negociabil. tel:0722223997
Specificati:
Engine: 100cc
Elice: 27x10 Carbon
Instalatie de Fum
Postat 13 October 2012 - 12:11 PM
Number of downloads: 349 -
Number of downloads: 377 -
Number of downloads: 333 -
Postat 20 October 2012 - 06:13 AM
Gigi Sterian
Rascal 1940mm fs.61 nitro
Rascal 120 DLE 30
U Can Do .46 nitro .52, 2T
Beaver 1520
Maule 1500
Helios 2545
Rascal 120 DLE 30
Beaver 1520
Maule 1500
Helios 2545
Postat 29 October 2012 - 08:16 AM
Dau la schimb un avion de hârtie, complet echipat, necesita doar radio, stare excelentă, doar două zboruri.....:()))
pasarile fac oua si din ele ies pui iar avioanele fac oua de aluminiu si ies aeromodele....din intelepciunile lui fiu-meu<span style='font-size:8pt;line-height:100%'> </span><!--coloro:red--><span style="color:red"><!--/coloro--> <!--colorc--></span><!--/colorc-->
Postat 16 November 2012 - 10:03 AM
Nu-l da Andrei,e prea frumos si zboara ca de pe alta lume! Si....e scandalos de ietin!
