Modelism - RHC Forum: Sbach 342 36% - Modelism - RHC Forum
Sbach 342 36% Pilot RC
#1 Useril este offline   djandrey
  • Postari: 604
  • Inregistrat: 15-June 09
  • Interests:Automodelism , Aeromodelism , IT
Postat 13 October 2012 - 12:08 PM
De vanzare Sbach 342 36% de la Pilot RC RTF
Specificati:
Wingspan: 107 in(2.7M)
Wing Area: 2296 sq in(14818sq cm)
Fuselage length: 95.7 in(2.43M)
Weight: 27.5 lbs (12.5kg)
Engine: 100cc
Este echipat cu urmatoarele:
Motor: DLE 111 (reglat setat si toate cele, merge impecabil)
Servo: 6xHITECH HS-7954SH High Voltage de 29kg ( 4 pe aripi,2 pe profundor) 1xHS-7950TH High Voltage de 35kg (pe directie)
Elice: 27x10 Carbon
Receptor/PowerBox: AR9100 3 Sateliti DSM2 8,4V spre servouri
Statie : Spektrum DX7 7 canale (binduita,setata,avion trimat pe ea)
Acumulatori: 2x NANOTECH 7,2V 3300 MAH (pe receptie) 1x NANOTECH 7,2V 2200 MAH (pe aprindere) 1x NANOTECH 7,2V 1300 MAH (pentru pompa de fum)
Instalatie de Fum
Modelul este RTF,are nevoie doar de benzina si incarcat baterii.
Pret: 7000lei negociabil. tel:0722223997
#2 Useril este offline   djandrey
  • Postari: 604
Postat 13 October 2012 - 12:11 PM
#3 Useril este offline   djandrey
  • Postari: 604
Postat 19 October 2012 - 10:39 PM
uPPP!!!
#4 Useril este offline   GigiGL
  • Postari: 2109
  • Inregistrat: 10-March 11
  • Interests:Aero
Postat 20 October 2012 - 06:13 AM
I remember...
http://www.youtube.c...h?v=0ZpeTM06EZo
Gigi Sterian
Rascal 1940mm fs.61 nitro
Rascal 120 DLE 30
U Can Do .46 nitro .52, 2T
Beaver 1520
Maule 1500
Helios 2545
#5 Useril este offline   djandrey
  • Postari: 604
Postat 26 October 2012 - 09:55 PM
up up up !!!
#6 Useril este offline   nicajohn
  • Postari: 534
  • Inregistrat: 20-August 06
  • Interests:aeromodele
Postat 29 October 2012 - 08:16 AM
Dau la schimb un avion de hârtie, complet echipat, necesita doar radio, stare excelentă, doar două zboruri.....:()))
pasarile fac oua si din ele ies pui iar avioanele fac oua de aluminiu si ies aeromodele....din intelepciunile lui fiu-meu<span style='font-size:8pt;line-height:100%'> </span><!--coloro:red--><span style="color:red"><!--/coloro--> <!--colorc--></span><!--/colorc-->
#7 Useril este offline   djandrey
  • Postari: 604
Postat 02 November 2012 - 11:08 PM
Huuuuupp!!! Nu vrea nimeni un avion serios ?
#8 Useril este offline   djandrey
  • Postari: 604
Postat 09 November 2012 - 03:29 PM
Up! Up! Up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :)
#9 Useril este offline   djandrey
  • Postari: 604
Postat 09 November 2012 - 09:07 PM
Rezervat
#10 Useril este offline   flypol
  • Postari: 4092
  • Inregistrat: 01-January 09
Postat 16 November 2012 - 10:03 AM
Nu-l da Andrei,e prea frumos si zboara ca de pe alta lume! Si....e scandalos de ietin!
#11 Useril este offline   djandrey
  • Postari: 604
Postat 16 November 2012 - 02:01 PM
Aveti mare dreptate da deja l-am dat. :rofl:
VANDUT !!!
