Modelism - RHC Forum: probleme cu raza de actiune la un dx5e - Modelism - RHC Forum
#1 Useril este offline   cata2
  • Postari: 643
  • Inregistrat: 05-November 08
Postat 05 September 2009 - 06:26 AM
Am montat pe o barcuta o telecomanda dx5e cu receptor ar500(full range) si iese din raza de actiune cam pe la 100-125m.Ciudat nu?Sa-i pun antena exterioara?Daca da de care?Sau care o fi problema?
tel . 0765940409
#2 Useril este offline   mariandmd
  • Postari: 2161
Postat 05 September 2009 - 08:43 AM
am si eu un dx5e dar nu am testat-o inca
vezi ca are un intrerupator in dreapta sus care este pentru distanta
trebuie sa fie ridicat in sus pe HI
#3 Useril este offline   ipsihi
Postat 05 September 2009 - 09:30 AM
Vezi postareamariandmd, la Sep 5 2009, 09:43 AM, a spus:
...HI/LOW RATE nu are nici o treaba cu puterea de emisie, doar ajusteaza cursa servo, 100% pe high si 70% pe low!!!
#4 Useril este offline   mariandmd
  • Postari: 2161
Postat 05 September 2009 - 10:16 PM
Vezi postareaipsihi, la Sep 5 2009, 10:30 AM, a spus:
ai citit manualul?
#5 Useril este offline   Porumbeu
  • Postari: 831
  • Inregistrat: 09-July 07
  • Interests:discussion
Postat 05 September 2009 - 11:29 PM
@marian ... vezi ca vorbesti in necunostinta de cauza
intrerupatorul Hi-Lo are 2 functii:
1. pentru range test se tine tras intrerupatorul cu functia trainer si intrerupatorul hi-lo se actioneaza de 4 ori si abia atunci esti in modul range test
2. The DX5e offers a high/low rate function on aileron,
elevator and rudder. When the HI/LO rate switch is in the upper position or “HI” position, 100% travel is achieved
on the aileron, elevator and rudder channels. When the switch is in the lower position a reduced travel of 70% is achieved on the aileron, elevator and rudder channels. This is useful allowing the aircraft to have a high control rate (switch in the “HI” position) for aggressive maneuvers and a low control rate (switch in “LO” position) for smooth, precise maneuvers.
Pe langa faptul ca citesti manualul, mai trebuie sa il si INTELEGI.
@cata2 ... dx5e are receptor air iar tie la barca iti trebuie receptor marin. Spektrum face diferentiere intre receptoare.
AICI este un receptor de barca.
Postat 06 September 2009 - 09:49 AM
Vezi postareamariandmd, la Sep 5 2009, 11:16 PM, a spus:
ai citit manualul?
...eu da, ti-l imprumut si tie deca vrei !!!
#7 Useril este offline   mariandmd
  • Postari: 2161
Postat 06 September 2009 - 10:09 AM
Vezi postareaPorumbeu, la Sep 6 2009, 12:29 AM, a spus:
scuze....
acu am rasfoit din nou manualul si intradevar aveti dreptate
eu citisem doar despre distanta
#8 Useril este offline   cata2
  • Postari: 643
Postat 07 September 2009 - 07:21 AM
Problema este ca cu un e-fly 100b cea mai praf telecomanda am atins si 250 m.Intrebarea este ce sa scot afara din barca antena care are cam 1.5 cm sau feeder-ul care are cam 12 cm?
tel . 0765940409
#9 Useril este offline   VanPulov
  • Postari: 503
  • Inregistrat: 01-August 06
  • Interests:navo
Postat 07 September 2009 - 09:58 AM
Vezi postareacata2, la Sep 7 2009, 07:21 AM, a spus:
salut,
ai pus antena la 90 grade asa cum zice in manual?
eu am un dx6i care are receptor tot de aero
si am mai multe modele (navo) pe care il folosesc
ideea e ca raza e diferita la fiecare model si acest lucru este determinat de pozitia receptorului in barca
am observat ca daca lipesc receptorul de punte (in interior binenteles) are o raza mai mare
rata de absorbtie este mult mai mare in apa, chiar mai mare decat la sol, acesta este principalul motiv pentru care raza de actiune scade atat de dramatic
#10 Useril este offline   cata2
  • Postari: 643
Postat 08 September 2009 - 07:07 AM
Am montat receptorul ca in carte si in spatele barcutei pe capac departe de cablurile electrice.Am sa incerc sa scot feeder-ul afara,daca nu merge atunci pa 2.4ghz
tel . 0765940409
#11 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 08 September 2009 - 09:02 AM
Vezi postareacata2, la Sep 8 2009, 07:07 AM, a spus:
eu zic ca ai putea sa incerci ce a zis Porumbeu, respectiv sa iei un receptor de navo, asta binenteles, daca iti permiti
#12 Useril este offline   Freigeboren
  • Postari: 166
  • Inregistrat: 02-June 08
Postat 14 September 2009 - 01:03 PM
Vezi postareacata2, la Sep 8 2009, 08:07 AM, a spus:
Ce-ar fi daca scoti firul principal printr-un tub de plastic, deasupra puntii (capacului) si lasi feederul ,perpendicular si lipit de capac?
Un pui de lup , intr-o noapte cu Luna plina s-a speriat de ea, si a jurat ca dupa ce va creste mare si puternic , o va pandi si o va manca......Dupa 1 an , intr-o alta noapte cu Luna plina , insetat, lupul a vazut Luna in oglinda unui lac.....incordat a sarit cu gura larg deschisa si.............s-a'necat! ....
#13 Useril este offline   popad
  • Aeromodelist
  • Postari: 1829
  • Inregistrat: 05-February 09
Postat 16 September 2009 - 10:05 PM
"Spektrum’s DX5e 5-channel system incorporates 2.4GHz
DSM2 technology offering full beyond-the-limits-of-sight
range and is ideal for sport-sized electric, gas and glowpowered
5-channel or fewer airplanes. No longer will
you have to wait for a frequency pin or be concerned that
someone may inadvertently turn on to your same frequency.
With Spektrum DSM2 technology, when you’re ready to fly
simply turn on, and go flying!"
Chiar producatorul spune clar este o statie pentru aeromodele.
Aceasta postare a fost editata de popad: 16 September 2009 - 10:10 PM
Aterizari fericite !
PopaD
#14 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 29 November 2009 - 08:30 PM
Vezi postareaVanPulov, la Sep 8 2009, 09:02 AM, a spus:
si-a achizitionat cineva receptor pentru navo ?
eu sunt pe cale sa fac acest lucru si as vrea sa stiu daca cumva are cineva vreun feedback despre functionarea lui
despre acesta vorbesc :
MR3000
Numa bine !
#15 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 20 March 2010 - 09:22 PM
revin,
mi-am cumpărat receptorul de care spuneam mai sus si acum ca s-au dezghețat apele am ieșit la proba, nu am nici cea mai mica problema
ideea e ca are mustățile mai lungi pe care le poți scoate afara din coca deci nu ar trebui sa pună probleme, oricum au am dus bărcuța la 100m nici nu o mai vedeam bine și nu a făcut figuri
avantaje: e protejat împotriva apei, e foarte mic, are dual output la cîrma și motor
în ciuda prețului care e destul de piperat eu zic ca merita
#16 Useril este offline   zgr_44
  • Postari: 1324
  • Inregistrat: 02-February 07
Postat 20 March 2010 - 11:37 PM
Firele alea sau mustatile cum le mai numea cineva nu prea au cum sa fie nici mai lungi, nici mai scurte, antena efectiva la 2.4ghz este lamba/4 care vine FIX 31mm (lungime efectiva antena).....2.4ghz nu-i nici pe departe 35 sau 40mhz....in cel mai bun caz se poate pune un pigtail ( cablu adaptor cu mufa care intra pe receptor si pe captul celalalt cu mufa in care se poate monta o antena de castig mai mare) antena originala are un castig "calculat" de 2db, dar sunt antene pe la routere sau placi de retea Wi-Fi care au cam 5db...sau receptorul acela "marine" care ...probabil are o sensibilitate mai mare...
#17 Useril este offline   ipsihi
Postat 21 March 2010 - 12:57 AM
...eu am dus dx5 fix v-o 470m la sol, citibili pe kilometrajul masinii , receptorul stock la luneta, la distanta asta servourile au dat in balbaiala !!!
#18 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 21 March 2010 - 01:26 PM
Vezi postareaipsihi, la Mar 21 2010, 12:57 AM, a spus:
la sol nu zic ca nu duce destul, dar in apa raza se scurteaza destul de mult
#19 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 21 March 2010 - 01:40 PM
Vezi postareazgr_44, la Mar 20 2010, 11:37 PM, a spus:
in cel mai bun caz poti fi mai bun decat cei de la spektrum, lucru care nu-l comentez
treaba sta in felul urmator: are doua antene cu mufe legate la receptor antena A=324+31=355mm si antena B=199+31=230mm fara nici un fel de adaugire cu mufe, portiunea cu 31mm fiind portiunea activa
aceasta lungime fiind pentru a putea ridica portiunea activa(31mm) destul de sus peste nivelul apei incat sa se diminueze posibilitatea interpunerii apei intre Rx si Tx
.....probabil
Aceasta postare a fost editata de VanPulov: 21 March 2010 - 01:42 PM
#20 Useril este offline   zgr_44
  • Postari: 1324
Postat 21 March 2010 - 11:31 PM
de cultura generala...cum ti-au dat in balbaiala...ca la Hitec pe receptorul de 7 canale ( hitec ) in 2.4, nici cu statia inchisa nu dau in balbaiala...
#21 Useril este offline   ipsihi
Postat 22 March 2010 - 12:09 AM
...adica au murit subit, no signal ,am uitat sa pun traducerea pt unii ca tine, cat despre cultura generala e discutabil, n-am facut scoala de retelisti ,asa ca latura asta a pregatirii mele are de suferit, hitecul nefiind slabiciunea mea in materie de statii nu stiu cum face in lipsa semnalului dar se exista si exceptii, de pilda e-fly 100B in 2,4 sau alte chinezarii ieftine in aceasi frecventa !!!
Aceasta postare a fost editata de ipsihi: 22 March 2010 - 12:21 AM
#22 Useril este offline   zgr_44
  • Postari: 1324
Postat 22 March 2010 - 09:41 AM
Vezi postareaipsihi, la Mar 22 2010, 12:09 AM, a spus:
...e e mai greu sa faci diferenta intre a da in balbaiala ( a face cursa necontrolata ) si a murii subit ( a nu face nimic )....deh....scoala de retelistica...ce sa-i faci....apropo....si Spektrum tot o chinezarie e...vezi ce scrie pe spatele ei...( Made in ..... ) :)
Aceasta postare a fost editata de zgr_44: 22 March 2010 - 09:42 AM
#23 Useril este offline   ipsihi
Postat 22 March 2010 - 10:18 AM
Vezi postareazgr_44, la Mar 22 2010, 09:41 AM, a spus:
...nea' cultura generala, a muri se scrie cu un singur i, deh, scoala generala, in final ziceam ziceam ceva de chinezisme IEFTINE, dx se vrea o statie cu staif !!!
#24 Useril este offline   zgr_44
  • Postari: 1324
Postat 22 March 2010 - 10:33 AM
Vezi postareaipsihi, la Mar 22 2010, 10:18 AM, a spus:
mdea...ma rog...deh...tastatura...e cam uzata.....iar cu soala...unii nu au nici cei 7...si se mai dau si "specialisti" in ale vorbirii...dar cate odata ne mai place sa facem pe despteptii.....se vrea ea staie cu staif...dar nu prea e...mai degraba e statie cu multe antene pe receptie....de ce oare.....si sa nu incepem ca, vai... sunt pt. fuselajele din carbon....
#25 Useril este offline   ipsihi
Postat 22 March 2010 - 11:31 AM
...dap, cei mai mult decat 1 e greu de numarat, a scrie si a vorbi corect in limba materna nu-i moft, este o obligatie ce deriva din minimum de educatie si cultura ,si ca sa ma dau "destept" in continuare in alea "7 clase" ale mele am invatat ca adverbul "cateodata ,adica uneori" se scrie intr-un cuvant !!!
#26 Useril este offline   zgr_44
  • Postari: 1324
Postat 22 March 2010 - 11:35 AM
Vezi postareaipsihi, la Mar 22 2010, 11:31 AM, a spus:
:lol: :) :lol: ce-mi mai place....ceva on-topic ...nimic....aia e....adverbul respectiv a fost lasat momeala.....la care ai muscat IMEDIAT....superb.....superb...
ce sa-i faci...DX-ul e frumusel ca statie, si chiar aproape ca nu prea e chinezarie....numai ca antenele alea multe de pe receptoarele lor nu-mi plac de nici un fel....
Aceasta postare a fost editata de zgr_44: 22 March 2010 - 11:37 AM
