Postat 05 July 2009 - 09:41 PM
Curious to see what the ranges are on the Spektrum system, I devised an
experiment to find out. Not completely scientific, but representative.
I mounted a AR6100 (v1.2) and a AR7000 on a piece of plywood and taped it to a cardboard box (see photos). The main receiver antennas were oriented left-right and the AR7000 satellite receiver antenna was oriented vertically. This assembly went on top of my Jeep with the servo extension leads run in thru the sunroof. On the seat of the car were two batteries and two servos with arm on them that had tape flags identifying which went to which receiver.
This gave me two receivers to compare and placed them far enough above the top of the car to eliminate most, if not all, metal interference. And the servos were attached to the throttle port on the receivers, both of which were bound to the same model on the DX7. The arms of the servos were horizontal (full throttle) when receiving a signal and popped vertical when signal was lost (fail safe position).
With my wife keeping watch on the DX7 sitting on top of her car, I drove my car with the receivers up a street away from her parking spot. I had direct line of sight for almost three miles with the exception of a hill about two miles away from her. Her spot was about 100 feet above the street I was on. See photo.
Results:
With the DX7 antenna vertical and the main receiver antennas horizontal
and perpendicular to line of sight:
Solid contact with no dropouts on either receiver for 1.7 miles. At 1.7 miles
the AR6100 began to drop in and out, the AR7000 was solid. Going behind the hill at 1.9 miles both dropped out, as you would expect. At 2.2 miles the AR7000 began to drop in and out and became solid at 2.4 miles while the AR6000 was in and out. At 2.8 miles, the max distance available for line of sight, the AR 6000 was in and out and the AR7000 was solid.
Same setup as above only DX7 antenna bent horizontal:
Both receivers solid at 2.8 miles, dropping in and out behind the hill at 2.2
miles, and then solid from 1.7 miles back to the start line. This put both main
receiver antennas and the DX7 antenna in the same plane. Before they were
perpendicular to each other. Radio theory says both should be in the same plane (geometric plane, not air plane) for max range.
Putting the receivers so all three antennas were horizontal and pointing at the DX7 caused dropout at 1.7 miles. This is worst case for expected range. However, turning a circle within 1.5 miles of the DX7 caused no dropouts with the receivers in normal orientation.
Conclusions:
AR6100 range is almost as good as the AR7000 up to 2.8 miles. The satellite receiver of the AR7000 made it more solid due to signal diversity and dual antenna orientation, as expected. It was not as susceptible to cars passing as the AR6000 was, again thanks to the satellite receiver.
Bending the DX7 antenna into the same plane as the receiver antenna improves range. This is mitigated by the continuous maneuvering of our models, so I don't consider it a concern. Plus at ranges where you can see your model the connection is solid regardless of antenna orientation.
Final conclusion: I guess I've got way too much time on my hands.... [/i][/i][/i]
(Traducerea e usoara)
Cam asta am citit , acu cred ca gresala mea e ca ei au statia in varianta USA , a mea e din Austria luata, deci varianta Eu. O sa fac curind eiu un test sa vad clar ( am mai facut odata era cu ar 7000 si mi a dat cam 700 metri ) Am vazut pe net ca dc vrei sa o detunezi e ieftin o trimiti la Horizon in uk si ti o refac ei la puterea initiala (vro 20 lire)
