Modelism - RHC Forum: mai 2009 - Modelism - RHC Forum
  • 7 Pagini +
mai 2009
#91 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2186
  • Inregistrat: 28-November 06
Postat 16 May 2009 - 11:24 PM
pun si eu o poza. buna de desktop :unsure:
Imagine atasata: showtime.jpg
#92 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2186
Postat 16 May 2009 - 11:32 PM
CE.A.PE. 232
Imagine atasata: ceape.jpg
#93 Useril este offline   ALLEN
  • Postari: 3004
  • Inregistrat: 11-May 08
Postat 16 May 2009 - 11:35 PM
Vezi postareahash84, la May 17 2009, 12:32 AM, a spus:
CE.A.PE. 232
mai, te rog frumos: CEAPEU 580 :unsure:
#94 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2186
Postat 16 May 2009 - 11:51 PM
Vezi postareaallen_g30, la May 17 2009, 12:35 AM, a spus:
mi scuzi http://www.rhcforum....tyle_emoticons/default/tongue.gif
neted ca in palma puteti spune?
Imagine atasata: neted.jpg
#95 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2186
Postat 17 May 2009 - 12:01 AM
mai are un pic si ma face. amator inca pe spate :unsure:
Imagine atasata: pespate.jpg
#96 Useril este offline   ALLEN
  • Postari: 3004
Postat 17 May 2009 - 09:44 AM
nene te scuz, ca deh....
si filmul de ieri cu primul zbor singur, multzam celor care m-au impins de la spate (baaa, sa nu cititi pe la spate)
http://www.youtube.c...h?v=jkc2t2pUknA
#97 Useril este offline   Ahernar
  • Postari: 739
  • Inregistrat: 20-December 08
Postat 17 May 2009 - 08:17 PM
Azi am busit EG -ul . Tare , dar nu fatal , am mai zburat cu el post crash . Mama lor de conectori proprietari .
http://www.youtube.c...h?v=65nH5JJ4_Uc
#98 Useril este offline   takeoff
  • Postari: 1029
  • Inregistrat: 25-July 08
Postat 17 May 2009 - 08:32 PM
Vezi postareaAhernar, la May 17 2009, 09:17 PM, a spus:
Mai explicit se poate?........Mama lor de conectori proprietari .
#99 Useril este offline   matei_silviu
  • Postari: 243
  • Inregistrat: 04-June 07
Postat 17 May 2009 - 08:41 PM
Scuze de intarziere. Ptr. inceput "no comment"
  • Imagine atasata: G2B.jpg
#100 Useril este offline   matei_silviu
  • Postari: 243
Postat 17 May 2009 - 08:46 PM
Recunoașteți personajul?
Verificari :blink:
  • Imagine atasata: S662.jpg
  • Imagine atasata: s66.jpg
  • Imagine atasata: s663.jpg
  • Imagine atasata: s664.jpg
  • Imagine atasata: E1.jpg
#101 Useril este offline   matei_silviu
  • Postari: 243
Postat 17 May 2009 - 08:53 PM
  • Imagine atasata: E2.jpg
  • Imagine atasata: G1.jpg
  • Imagine atasata: G2.jpg
  • Imagine atasata: P1.jpg
  • Imagine atasata: P2.jpg
  • Imagine atasata: T1.jpg
  • Imagine atasata: T2.jpg
  • Imagine atasata: T3.jpg
#102 Useril este offline   matei_silviu
  • Postari: 243
Postat 17 May 2009 - 08:54 PM
Edg-ul @depron
  • Imagine atasata: M_E1.jpg
  • Imagine atasata: M_E2.jpg
#103 Useril este offline   matei_silviu
  • Postari: 243
Postat 17 May 2009 - 08:58 PM
Touch & Go
Landing
  • Imagine atasata: M_L1.jpg
  • Imagine atasata: M_L2.jpg
  • Imagine atasata: M_L3.jpg
  • Imagine atasata: M_L4.jpg
  • Imagine atasata: M_L5.jpg
#104 Useril este offline   matei_silviu
  • Postari: 243
Postat 17 May 2009 - 09:00 PM
Si cel mai reușit portret (numai la 3D găsiți :)
  • Imagine atasata: fin1.jpg
  • Imagine atasata: fin2.jpg
#105 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
  • Inregistrat: 03-February 07
  • Interests:AEROMODELISM
Postat 17 May 2009 - 09:15 PM
Saptamana viitoare .....facem si la gratar niste poze ! de data asta l-am ratat. ASA ca saptamana viitoare se lasa tare la 3DRUMURI ! ..NU UITATI UMBRELUTELE! :)
ADOR VITEZA!!!
#106 Useril este offline   Ahernar
  • Postari: 739
Postat 17 May 2009 - 09:18 PM
Vezi postareatakeoff, la May 17 2009, 08:32 PM, a spus:
Detaliile erau in descrierea filmului... pe scurt am pus din greseala o antena cu conector SMA reverse pe Tx video , asta inseamna practic ca nu aveam antena
respectivului conector aflat pe antena ii lipsea pinul care sa intre in tx desi este identica cu celelalte .
Din WIKI
Reverse polarity SMA (RP-SMA or RSMA) is a proprietary variation of the SMA connector specification which reverses the gender of the interface, as shown in Figures 1 and 2.
There is much confusion caused by the terms 'male' and 'female' with reversed connectors. These terms are best avoided and the correct terms 'plug' and 'jack' should be substituted.
The RP-SMA plug connector has the same external housing as a standard or conventional SMA plug connector, which consists of an outer shell with the thread on the inside; however, the internal prong or pin is replaced by a receptacle or female inner pin. The RP-SMA jack connector as shown in Fig 2 has the same housing as a standard or conventional SMA jack connector, thread on the outside, however the female receptacle is replaced by a male prong or pin.
RP-SMA connectors are widely used by Wi-Fi equipment manufacturers to comply with specific local regulations, e.g. the FCC, which are designed to make it difficult for consumers to connect antennas with gain and thereby breach compliance. "
Am scapat ieftin din fericire :)
#107 Useril este offline   ALLEN
  • Postari: 3004
Postat 17 May 2009 - 09:51 PM
hash84 si extra 300
Imagine atasata: alex___02.JPG Imagine atasata: alex___04.JPG
acromaster... buna spuma
Imagine atasata: allen___07.JPG
ave si Yak-ul sau. frumoasa tinuta de zbor
Imagine atasata: ave___04.JPG Imagine atasata: ave___16.JPG
focke, la o discutie amicala. interlocutor... nu mai stiu
Imagine atasata: dragos.JPG
ba da... cu asta mic vorbea focke (florin 100%)
ete ce a facut soarele si caldura din el
Imagine atasata: florin___09.JPG
si uite asa se trece de la modele mari, la unele si mai mari
Imagine atasata: florin___05.JPG
#108 Useril este offline   ALLEN
  • Postari: 3004
Postat 17 May 2009 - 09:53 PM
serban cu un recital de acrobatie cu heli
Imagine atasata: serban___01.JPG Imagine atasata: serban___02.JPG
Imagine atasata: serban___03.JPG
soghi cu polecat
Imagine atasata: shoghi.JPG
#109 Useril este offline   ALLEN
  • Postari: 3004
Postat 17 May 2009 - 09:56 PM
ei, si cum azi fu caldura mare... stiti vorba aia cu ne-a zapacit caldura???
ete si mostra:
Imagine atasata: nebunii___02.JPG
Imagine atasata: nebunii___01.JPG
Imagine atasata: nebunii___04.JPG
#110 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 18 May 2009 - 07:36 AM
Vezi postareaallen_g30, la May 17 2009, 10:56 PM, a spus:
Eu o stiam cu "ne-a batut soarele-n cap"...
Ave
#111 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2186
Postat 18 May 2009 - 08:19 AM
m-a rugat ieri cineva sa ii filmez o katana la maiden flight. il rog sa ma contacteze pt film
#112 Useril este offline   Red Sky
  • Gold Member
  • Postari: 935
  • Inregistrat: 15-March 06
Postat 18 May 2009 - 10:44 AM
De ce i se vede umbra pe posterul din spate??
Cu ce l-ati suspendat pe bietul om acolo??
<_<
www.redsky.ro
#113 Useril este offline   hash84
  • DreamTeam member
  • Postari: 2186
Postat 18 May 2009 - 11:09 AM
Vezi postareaRed Sky, la May 18 2009, 11:44 AM, a spus:
:D
daca te gandesti la trucaj, nu e <_<
umbra e de la timpul mai mare expunere + blitz.
saritura it's all natural. m-am speriat si eu cat de sus pot sa sar....
#114 Useril este offline   ave
  • Postari: 1010
Postat 18 May 2009 - 11:24 AM
Da, cand vezi cum vine bazaitoarea aia spre tine nu-ti dai seama ce esti in stare sa faci ca sa te feresti... <_<
Ave
#115 Useril este offline   ave
  • Postari: 1010
Postat 18 May 2009 - 11:44 AM
Da, ieri am inceput sa ma obisnuiesc cu Yak-ul. Zboara de rupe, pacat ca nu are pilot pe masura...
Faza dementiala: la decolare tragea dreapta. Da' tragea URAT. 4 decolari m-am chinuit cu el. La final, la curatenie, constat ca janta rotii dreapta era blocata, iar anvelopa aluneca pe janta. Naspa.
Acum va trebui sa ma chinui sa desfac unul dintre colierele limitatoare. Partea amuzanta e ca am pus loctite pe stiftul filetat care tine colierul acolo. Sa vedem daca il mai pot desface...
Ave
#116 Useril este offline   shogi
  • Postari: 2753
  • Inregistrat: 08-March 06
  • Interests:pussy
Postat 18 May 2009 - 12:30 PM
Vezi postareahash84, la May 18 2009, 09:19 AM, a spus:
funtana era ...eu ti`am spus sa`l filmezi.poti sa mi`l dai mie sau sa`l pui sus pe net pe undeva.cum ti`e tie mai bine
#117 Useril este offline   ave
  • Postari: 1010
Postat 18 May 2009 - 02:56 PM
Vezi postareaallen_g30, la May 17 2009, 10:51 PM, a spus:
Mai, multumesc de aprecieri, dar ai prins doua pozitii mai potrivite ale aparatului. Saracul de el, e cuminte foc (daca nu incep sa ma sparg in figuri). Sper ca in 2-3 luni sa-i fac rost si de un pilot mai competent...
Ave
#118 Useril este offline   SILVIU66
Postat 18 May 2009 - 03:03 PM
Vezi postareaave, la May 18 2009, 03:56 PM, a spus:
ai gasit undeva de cumparat? <_<
#119 Useril este offline   Romulus
  • Postari: 1190
  • Inregistrat: 02-June 08
Postat 18 May 2009 - 03:10 PM
Si eu caut, am incercat la metru, la magazinele de stofa, dar n-au.
#120 Useril este offline   ave
  • Postari: 1010
Postat 18 May 2009 - 03:33 PM
Vezi postareaSILVIU66, la May 18 2009, 04:03 PM, a spus:
Inca nu, dar continuu sa caut. Cu multa insistenta chiar, pot spune... :D
Vezi postareaRomulus a spus:
Stofa de pilot bun se fabrica greu si, in general, se vinde pe sub mana. Mai ales in .ro. D-aia nu cred c-o sa gasesti la magazinele de profil, trebuie sa te duci direct la fabrica (eu incerc la aia de la Chitila, da' ritmul de productie e cumplit de lent...)
Aceasta postare a fost editata de ave: 18 May 2009 - 03:42 PM
Ave
  • 7 Pagini +
4 useri citesc topicul
