Modelism - RHC Forum: Vand Radiocomanda Turnigy GTX3 - Modelism - RHC Forum
#1 Useril este offline   rc.ovidiu
  • Postari: 153
  • Inregistrat: 26-November 15
Postat 18 February 2018 - 04:11 PM
Vand Radiocomanda pt masina sau barca , Turnigy GTX3 AFHDS 2.4 Ghz in stare impecabila , in cutia originala si foarte putin folosita . Se vinde cu receptor si cu acumulator de Litiu 3s pt statie.
Channels: 3
RF Type: 2.4Ghz AFHDS
Bandwidth: 500Hz
RF power: less than 20DB
Sensitivity: 1024
Low Voltage Warning: Yes (less than 9V)
Fail Safe: Yes
DSC Port: Yes (3.5mm PPM)
Charging Port: Yes
Power: 12V DC (1.5AA x 8)
Weight: 395g
CE & FCC certified
3.9" Blue Back-lit LCD
Programing Options:
Model Memory (10 Models)
Servos NOR/REV
Steering Trim
Throttle Trim
Dual Rate
End Point Adjustment
ABS Settings
EXP Settings
Pret 180 RON
tel: 0756887786
e-mail: ovidiuraucescu@yahoo.com
#2 Useril este offline   rc.ovidiu
  • Postari: 153
Postat 18 February 2018 - 04:18 PM
Vezi postarearc.ovidiu, la 18 February 2018 - 04:11 PM, a spus:
Channels: 3
Bandwidth: 500Hz
Sensitivity: 1024
Fail Safe: Yes
Charging Port: Yes
Weight: 395g
CE & FCC certified
Programing Options:
Servos NOR/REV
Steering Trim
Throttle Trim
Dual Rate
ABS Settings
EXP Settings
Pret 180 RON
tel: 0756887786
#3 Useril este offline   rc.ovidiu
  • Postari: 153
Postat 18 February 2018 - 04:23 PM
Channels: 3
Bandwidth: 500Hz
Sensitivity: 1024
Fail Safe: Yes
Charging Port: Yes
Weight: 395g
CE & FCC certified
Programing Options:
Servos NOR/REV
Steering Trim
Throttle Trim
Dual Rate
ABS Settings
EXP Settings
Pret 180 RON
tel: 0756887786
Aceasta postare a fost editata de rc.ovidiu: 18 February 2018 - 04:26 PM
