• Microprocessor controlled
• Individual cell balancing
• LiHV, Li-ion, LiPoly and LiFe capable
• Ni-Cd and NiMH capable
• Delta-peak sensitivity (NiMH/NiCd)
• Lead Acid capable
• Large range of charge currents
• Terminal Voltage Control (TVC)
• Lipo Battery Meter
• Battery Internal Resistance Meter
• Store function, allows safe storage current
• Time limit function 1~720 minutes
• Temperature Cut-off (20-80 degree Celsius/68-176 Fahrenheit)
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 10 packs in memory)
• Battery break in and cycling. (1-5 cycles)
Specs:
Input Voltage: 11~18v
Circuit Power: Max Charge: 50W / Max Discharge: 5W
Charge Current Range: 0.1~6.0A
Balance Cells: 2-6 cells
NiMH/NiCd Cells: 1~15
LiHV /LiIon/LiPoly Cells: 1~6
Pb battery Voltage: 2~20v
Weight: 240g
This charger has a JST-XH balance charge plug, which makes it compatible with Zippy, HXT, TURNIGY and any pack with a JST-XH adapter.
Includes:
1. Accucell 6 50W Charger
2. Alligator clip input lead
3. XT60 with Banana connector charging Cable (340mm)
4. XT60 to Alligator clip charging cable (180mm)
PRET 180 lei
0722359121
