Modelism - RHC Forum: RV4 1800 anv, OS 26 cc metanol - Modelism - RHC Forum
RV4 1800 anv, OS 26 cc metanol bun de tractat planoare pina in 3 kg ...
#1 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Inregistrat: 05-December 08
  • Gender:Not Telling
  • Interests:-
Postat 05 August 2016 - 08:14 PM
RV 4 trainer cu aripa jos, bun de tractor sau acrobatie, 1800 mm anvergura 5 kg, cirlig de tractare, pompa perry, rezervor de 1/2 l, Rx Spectrum 9 ch DSMX, , servo Futaba 30xx, doua servo pe profundor, eleroane, flaps, reparat artistic dupa o busitura de poveste, un adevarat tractor.Doua baterii pe alimentare, doi sateliti pe receptie, PRET 2000 lei.
#2 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 05 August 2016 - 08:17 PM
Are si capota motorului, dar trebuie sa-i fac poze cu ea montata ...
#3 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 05 August 2016 - 08:20 PM
Mda, ... ca pe vremea disketelor se incarca pozele astea imense ... de max 500 KB :)))
#4 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 09 August 2016 - 12:48 PM
Pina Simbata 1300 de lei.
#5 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 16 August 2016 - 11:47 PM
2000
#6 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 21 August 2016 - 01:19 PM
Fara Rx, 1000 lei.
#7 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 15 September 2016 - 08:26 PM
1800 cu AR 9020, 1500 fara RX
#8 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 28 November 2016 - 11:37 PM
... 1300 de lei, cu Rx ...
Aceasta postare a fost editata de Borian: 28 November 2016 - 11:38 PM
#9 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 18 February 2017 - 04:32 PM
1000 lei fara Rx
#10 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 15 March 2017 - 12:33 AM
Motor OS 160 fx (26 cc/930 gr) + pompa Perry, elice 18x10 APC, rezervor de 0.5l, cirlig de tractare, pilot greu incercat, doua UBEC uri HiModel de 10A, conecatre paralel cu diode (daca un LiPo ''pica'', ramine celalalt ... tren de aterizare cu amortizare ... robust, puternic, motor fiabil alimentat constant cu pompa auxiliara, doua servouri pe profundor, flapsuri pt conditii mai bune de aterizare, huse la aripi si fuselaj, ...
https://www.amainhob...osm19260/p35255
Pret 1500 lei cu receptorul AR 9020 cu doi sateliti.
1200 de lei fara receptor.
Aceasta postare a fost editata de Borian: 15 March 2017 - 12:35 AM
#11 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 15 March 2017 - 12:39 AM
..Poze poze ..
Aceasta postare a fost editata de Borian: 15 March 2017 - 12:42 AM
#12 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 15 March 2017 - 12:40 AM
delete
#13 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 22 March 2017 - 03:45 AM
Acuma daca tot nu-l vrea nimeni, o sa va zic povestea cu prabuseala, pt ca nu e una ''de manual'' !!
Eram pe cimp si ma dadeam cu agregatu, tractam un fel de banner, mai largam bannerul, mai faceam ceva acrobatie cu steagu dupa el, in fine vin niste baieti care il vad, le place si vor sa-l ia, ca sa se dea cu el ''de Paste'', eu nu si nu ! ... pina la urma imi lasa un nr de tel ...
Avionul mergea prea bine dupa ce-i pusesem pompa perry, arata si foarte bine ... mie imi plac avioanele cu aripa jos si cu diedru, pilotul are si el ''contributia'' lui, ma gindeam sa apuc macar sa tractez un planor si poate ma hotaram dupa ... asa ca in zilele urmatoare l-am tot zburat, motorul trage mult peste ce are el nevoie si te scoate din greseli, e f relaxant, nici consumul nu e mare pt ca, la cit trage OSul si la cele 5 kg, clapeta sta sub 50 %, asa ca ''totu lin, fara suspin''.
Numai ca Murphy vegheaza si asteapta rabdator, eu ma apuc sa-l mai ''reglez'' un pic, acolo pe cimp, intr-o pauza foarte relaxanta ... vremea era superba, nici prea-prea, nici foarte-foarte ...
Pun aripile la loc, admir noile curse ale eleroanelor, mai verific cite ceva pe ici pe colo si intru din nou pe pista, pt decolare ... macar daca mai faceam ceva taxi, dar n-am facut !! ...
Decolez, fac vreo doua treceri ''asezate'' dupa care initiez un tonou ... mai fac unul si ... deodata vad cum ii sare o aripa !!! incerc ceva asa la disperare, nu vad vreun efect o vad si pe-a doua parasind lupta !!! ... bineinteles, uitasem sa le asigur ...
Noroc cu bannerul !! ... energia impactului s-a consumat in ''surcelizarea'' cutiei pe care era fixat motorul de panoul de foc, in ruperea unei pale si in sifonarea capotei, nici macar foarte tare ... aripile au venit jos ca frunzele, doar una a avut un colt de la bordul de fuga al flapsului, infundat.
L-am reparat, l-am ''botezat'' cu subleru si banana, pilotul e mai incercat ca niciodata, zboara la la fel de bine sau chiar mai bine daca ne luam dupa vorbe ...
Mai am un SpaceWalker de 2.2 m si fiind tot ''aripa jos + diedru'', .. mai aerisim depozitu, mai primenim portofelu ...
Hai ca vine RR !!
Aceasta postare a fost editata de Borian: 22 March 2017 - 03:50 AM
#14 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 04 April 2017 - 12:38 PM
1200 cu Rx, 1000 fara.
#15 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 11 April 2017 - 09:08 PM
1550 cu Rx 1200 fara.
#16 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 22 April 2017 - 08:53 PM
Ocazie pt cine vrea un tractor la intilnirea de la Rapa Rosie, 1200 cu receptor, gata de zbor, dau si vreo 2 l de metanol 10% nitro.
Am zis !
#17 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 06 May 2017 - 03:00 PM
1500 cu Rx, 1200 fara Rx.
#18 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 05 June 2017 - 11:59 PM
Oferte, variante ?
#19 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 20 June 2017 - 04:07 PM
1100 fara Rx
#20 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 03 July 2017 - 11:21 AM
1000 fara Rx si fara LiPo.
#21 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 13 July 2017 - 01:58 AM
Haideti ca vreau sa scap de el(e) !
#22 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 16 August 2017 - 10:39 AM
Oferte ?
#23 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 07 September 2017 - 11:06 AM
Interesati ? ...
#24 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 23 September 2017 - 09:38 PM
... ne intelegem ... poate ..
#25 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 27 December 2017 - 02:39 AM
1100 lei cu Rx ... si LiPo.
#26 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 16 March 2018 - 03:42 PM
1000 de lei cu Rx si LiPo !!
#27 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 08 April 2019 - 04:34 AM
900 lei cu receptor cu tot !
#28 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 08 April 2019 - 04:56 AM
Il vand si pe bucati ...
#29 Useril este offline   Borian
  • autonom
  • Postari: 664
  • Interests:-
Postat 14 April 2019 - 07:01 PM
Vandut.
