Modelism - RHC Forum: Vand piese multicopter - Modelism - RHC Forum
#1 Useril este offline   Parfenov
  • Postari: 737
  • Inregistrat: 25-July 13
Postat 29 July 2016 - 04:14 PM
Din cauza unei mari dorinte renunt la restul pieselor de pe fostul tricopter . Piesele pe care le vand functioneaza perfect si nu au prezentat defectiuni .
1. SL2212/920KV CW CCW Multi-Rotor Motor(2pcs/bag)
Specifications:
KV : 920
Shaft Diameter: 3mm
Motor Dimension(Dia.*Len) : Φ28х24
Weight(g): 48g
No.of Cells(Lipo) :3-6S
Max Continuous current(A)180S : 20A
Max Continuous Power(W)180S : 400W
Max. efficiency current :(3-10A)>85%
https://s31.postimg.org/b9likm9m3/IMG_20160729_162807.jpg
https://s31.postimg.org/md54q7uwb/IMG_20160729_163727.jpg
Motoarele vin cu tot cu elice , dar nu vin cu batiu pentru ca nu le mai gasesc . Pret 80 lei .
2.2830 850KV Outrunner Brushless Motor
Model: 2830
Motor size: Ф28*30mm
Shaft size: Ф3.17*45mm
Weight: 52g
KV(rpm/v): 850
Max Power: 187W
Battery: 2-4Li-Po
Prop: 11X7/8x6
Ri(M Ω): 0.136
ESC: 30A
https://s31.postimg.org/thiclicrv/IMG_20160729_155345.jpg
Pret 40 lei.Vine cu toate accesorile ce le vedeti in poza.
3.Rctimer Mini ESC20A OPTO BLHeli Firmware (OneShot125)
Specification:
Voltage: 6-16.8V(2-4S LiPo)
Output Current: 20A
BEC: Without
Output PWM frequency:18KHz
Firmware:BLHeli 14.1
Weight:2.0g(without wires)
https://s31.postimg.org/64kb2zwob/IMG_20160729_155723.jpg
Prefer sa le dau pe ambele deodata . Pret 70 lei !
4.OpenPilot CC3D Flight Controller
https://s31.postimg.org/65u8weyi3/IMG_20160729_155747.jpg
https://s31.postimg.org/42jtoqyp7/IMG_20160729_155757.jpg
https://s31.postimg.org/5ivc6w1m3/IMG_20160729_160659.jpg
Pret 60 lei !
Transportul prin Posta Romana , cu plata transportului sau fara in functie de comanda .Contact Pm sau la 0745426621 , indiferent de ora !
Piesele au fost prezente pe acest tricopter : https://www.youtube....h?v=BEKq7EbGsF4
Aceasta postare a fost editata de Parfenov: 29 July 2016 - 04:15 PM
Parfenov Razvan
#2 Useril este offline   Parfenov
  • Postari: 737
Postat 05 August 2016 - 03:44 PM
Up, preturi usor negociabile !
Parfenov Razvan
#3 Useril este offline   mellbo
  • Postari: 508
  • Inregistrat: 26-August 13
Postat 06 August 2016 - 01:38 AM
eu nu am inteles..
la punctul unu, ai doar doua motoare 2212 ? eu as vrea 4. si care e pretul ? per motor, sau per set ?
Aceasta postare a fost editata de mellbo: 06 August 2016 - 01:39 AM
TEL: 0786.607.466
#4 Useril este offline   MarianM1
  • Postari: 13
  • Inregistrat: 05-August 16
  • Interests:Quads
Postat 07 August 2016 - 12:19 PM
iau eu CC3D, vorbim in privat
#5 Useril este offline   Parfenov
  • Postari: 737
Postat 07 August 2016 - 02:13 PM
Da Mellbo ,din cauza ca eu au avut un tricopter . Cele 2 motoare au fost pe fata si celalalt motor a fost pe spate . As prefera sa le dau pe amandoua deodata.Pretul este de 80 lei pentru amandoua .
Aceasta postare a fost editata de Parfenov: 07 August 2016 - 02:14 PM
Parfenov Razvan
#6 Useril este offline   Parfenov
  • Postari: 737
Postat 08 August 2016 - 12:23 PM
CC3D s-a vandut !
Parfenov Razvan
#7 Useril este offline   Parfenov
  • Postari: 737
Postat 12 August 2016 - 10:43 PM
Up
Parfenov Razvan
#8 Useril este offline   Parfenov
  • Postari: 737
Postat 15 August 2016 - 03:19 PM
Motoarele si esc-urile le vand si separat .
Parfenov Razvan
#9 Useril este offline   Parfenov
  • Postari: 737
Postat 22 August 2016 - 03:35 PM
Up !
Parfenov Razvan
#10 Useril este offline   vlad1
  • Postari: 2661
Postat 21 September 2016 - 07:19 AM
Aveti P.M.
#11 Useril este offline   Parfenov
  • Postari: 737
Postat 25 September 2016 - 04:15 PM
Imi cer scuze , produsele se retrag de la vanzare deoarece nu mai sunt acasa si nu pot le pot livra.
Parfenov Razvan
