Pret 400 ron
0730583513
YES I-PEAK 545 is a microprocessor controlled balance charger especially designed to charge all kind of Li-Po battery packs ranging from 1 to 5 cells, Ni-Cd & Ni-MH battery packs ranging from 1 to 14 cells and Lead Acid batteries from 2V to 12V.
The YES I-PEAK 545 is encased in an aluminium anodized case with a large clear backlit display and a fast and easy to navigate setup program. Take advantage of the special balance ports and charging program when charging Lithium Polymer batteries fitted with the appropriate balance lead and keep your cells in perfect condition any time.
Operating Voltage: 11 - 18V DC
N° of Ni-Cd / Ni-MH cells: 1 - 14 Cells
N° of Li-Po cells: 1 - 5 Cells
PB Battery Voltage: 2V - 12V
Circuit Power: 50W
Charge Current Range: 0.1 - 5.0A
Current drain for
balancing Li-Po cells: 200mA / Cell
Temperature sensor is optional, not included
Number of downloads: 209 -
Number of downloads: 195 -
Acest topic e inchis
