Modelism - RHC Forum: CURATENIE PRIMAVARA - Modelism - RHC Forum
CURATENIE PRIMAVARA
#1 Useril este offline   petre1955
  • Postari: 42
  • Inregistrat: 26-November 08
Postat 02 April 2016 - 10:04 AM
VIND :
1.CONTROLER NAZE 32 NOU -80RON
2. MOTOARE A2212 2200KV -3BUC 40RON BUCATA
3.ESC 30A SIMONK 3BUC 40RON BUCATA
TEL.0727429676
Aceasta postare a fost editata de petre1955: 02 April 2016 - 10:05 AM
#2 Useril este offline   Mato
  • Postari: 165
  • Inregistrat: 29-May 11
Postat 02 April 2016 - 11:22 PM
Naze 32 este 6 sau 10 dof?
#3 Useril este offline   Loredan
  • Postari: 16
  • Inregistrat: 03-March 16
Postat 03 April 2016 - 12:03 PM
Cumpar 2 bucati motor 2200kv si 2 bucati esc. Vreau cv detali pe pm pentru motor si esc.
#4 Useril este offline   petre1955
  • Postari: 42
Postat 03 April 2016 - 03:46 PM
Vezi postareaMato, la 02 April 2016 - 11:22 PM, a spus:
6 dof
#5 Useril este offline   petre1955
  • Postari: 42
Postat 03 April 2016 - 03:52 PM
Vezi postareaLoredan, la 03 April 2016 - 12:03 PM, a spus:
MOTOR
KV: 2200
Max Efficiency: 80%
Max Efficiency Current: 4-10A (>75%)
Current Capacity: 12A/60s
No Load Current @ 10V: 0.5A
No. Of Cells: 2-3 Li-Poly
Motor Dimensions: Φ27.5 x 30mm
Shaft Diameter: Φ3.17mm
Weight: 47g
ESC
Size: 57mm x 25mm x 8mm
Sustaining Input Voltage: 6-12V
BEC Output Current: 5V/3A
Continuous Output Current: 30A
Max Current: 35A/12s
Weight:25g
#6 Useril este offline   Loredan
  • Postari: 16
Postat 03 April 2016 - 04:30 PM
Aveam nevoie de 2200 pt esc 30a
asta e pt 10a.
#7 Useril este offline   Loredan
  • Postari: 16
Postat 03 April 2016 - 04:31 PM
Cate grame duce motoru cu elice de 6x4? Am nevoie pe f22 raptor
#8 Useril este offline   petre1955
  • Postari: 42
Postat 03 April 2016 - 07:21 PM
Vezi postareaLoredan, la 03 April 2016 - 04:31 PM, a spus:
IMI PARE RAU DAR NU AM MAI MULTE INFORMATII DESPRE MOTOR+ESC
#9 Useril este offline   petre1955
  • Postari: 42
Postat 03 April 2016 - 07:26 PM
http://phoenixmodels...00-p-3219.html- MOTOR
ESC RESOFTATE SIMONK
Aceasta postare a fost editata de petre1955: 03 April 2016 - 07:29 PM
#10 Useril este offline   petre1955
  • Postari: 42
Postat 03 April 2016 - 07:34 PM
SCUZE,
PENTRU MOTOR:
http://phoenixmodels...200-p-3219.html
Aceasta postare a fost editata de petre1955: 03 April 2016 - 07:38 PM
#11 Useril este offline   petre1955
  • Postari: 42
Postat 08 April 2016 - 04:19 PM
Vezi postareapetre1955, la 02 April 2016 - 10:04 AM, a spus:
PRETURI NOI
1.CONTROLER NAZE 32 NOU -60RON
Features:
• Flexible motor outputs, support various airframe types:
Quad/Hexa/Tri/Bi/Y4/Y6/Octo/Camera Gimbal. (Default is Quad-X)
• Up to 8 ch RC input - supports standard receivers (PWM), PPM Sum receiver (FrSky, etc), or Spektrum satellite receivers.
• Built in FrSky telemetry inverter (shared w/main port)
• Battery voltage monitoring
• Modern 32-bit processor running at 3.3V/72MHz (STM32F103CB).
• Onboard MicroUSB for setup and configuration
• LEDs so bright, they could blind you
• MultiWii-based configuration software for easy setup
• rev5 hardware
2. MOTOARE A2212 2200KV -3BUC 30RON BUCATA
KV: 2200
Max Efficiency: 80%
Weight: 47g
3.ESC 30A SIMONK 3BUC 30RON BUCATA
Weight:25g
TEL.0727429676
#12 Useril este offline   savage25
  • Postari: 507
  • Inregistrat: 26-March 12
Postat 11 April 2016 - 11:16 PM
Salut, sunt interesat de naze 32.
#13 Useril este offline   petre1955
  • Postari: 42
Postat 12 April 2016 - 05:23 PM
CONTROLER NAZE 32 vindut
1. MOTOARE A2212 2200KV -3BUC 30RON BUCATA
KV: 2200
Max Efficiency: 80%
Weight: 47g
2.ESC 30A SIMONK 3BUC 30RON BUCATA
Weight:25g
TEL.0727429676
#14 Useril este offline   as2008
  • Postari: 731
  • Inregistrat: 04-May 10
Postat 24 August 2016 - 04:35 PM
Vezi postareapetre1955, la 12 April 2016 - 05:23 PM, a spus:
KV: 2200
Max Efficiency: 80%
Weight: 47g
Weight:25g
TEL.0727429676
buna ziua , motor si , esc , mai sunt de actualitate? le pot pune pe un avionas? esc-ul mai trebuie programat pentru acest motor ? . multumesc de raspuns
#15 Useril este offline   as2008
  • Postari: 731
Postat 26 October 2016 - 04:34 PM
Vezi postareaas2008, la 24 August 2016 - 04:35 PM, a spus:
buna ziua , motor si esc mai este de actualitate??
