Modelism - RHC Forum: 2 buc ESC Hobbyking SS 40A - Modelism - RHC Forum
2 buc ESC Hobbyking SS 40A Brushless
#1 Useril este offline   Wili
  • Postari: 201
  • Inregistrat: 12-August 13
Postat 29 September 2015 - 12:08 PM
Vand 2 buc ESC Hobbyking SS 40A, una nefolosita iar una folosita de doua ori la incercarea unui motor. Pret: 35lei bucata
Spec.
Weight: 39g
Cells: 2-4S
Max Current: 40A
Burst: 50A
BEC: None (Opto Only)
User Programming options:
Battery setting
Throttle Range
Brake setting 4 options: Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Poze:https://drive.google...iew?usp=sharing
#2 Useril este offline   Wili
  • Postari: 201
Spec.
Weight: 39g
Cells: 2-4S
Max Current: 40A
Burst: 50A
Battery setting
Throttle Range
PWM setting: 8K/16K
#3 Useril este offline   Wili
  • Postari: 201
Postat 29 September 2015 - 12:14 PM
Vand 2 bucati ESC LRP Nexxt 4x Brushed+Brushless folosite la tractor. Pret: 200lei bucata, negociabil
Poze:
Spec:
Brushless+BrushedForward + Brake, Forward + ReverseWeightWeight20gSize28.5x40.3mmVoltage input4.8-11.1VDimensionsMotorlimit 370/380 sizeNo limitMotorlimit 540 sizeover 7.5T
Sensorless brushless + brushed speed control<li>Sensorless design<li>2.0A B.E.C.<li>100% waterproof<li>ADPCTM - Advanced Digital Phase Control<li>ADVANCED Digital with 4 adjustable modes<li>Auto Cell System – Automatic NiMH/LiPo adaptation<li>Multifunction menu<li>Internal-Temp-Check-System<li>Launch control <li>High Frequency<li>Fail Safe<li>External soldering tabs<li>1.5mm² power wire<li>3.5mm gold connector<li>2S + 3S optimised<li>Suited for 1/10th to 1/12th scale models
#4 Useril este offline   Wili
  • Postari: 201
Postat 29 September 2015 - 12:15 PM
Poze:
Spec:
2S + 3S optimised
Brushless+Brushed: Forward + Brake, Forward + Reverse
Weight 20g
Size28.5x40.3mm
Voltage input 4.8-11.1V
Dimensions
Motorlimit 370/380 size No limit
Motorlimit 540 size over 7.5T
Sensorless design
2.0A B.E.C.
100% waterproof
Multifunction menu
Launch control
High Frequency
Fail Safe
External soldering tabs,
Aceasta postare a fost editata de Wili: 29 September 2015 - 12:19 PM
#5 Useril este offline   cyrus
  • Postari: 211
  • Inregistrat: 17-March 06
  • Interests:Modelism,masini cu abur,prelucrarea lemnului,vw golf 1
Postat 29 September 2015 - 03:08 PM
Vezi postareaWili, la 29 September 2015 - 12:08 PM, a spus:
<br />Vand 2 buc ESC Hobbyking SS 40A, una nefolosita iar una folosita de doua ori la incercarea unui motor. Pret: 35lei bucata<br /><br />Spec.<br />Weight: 39g<br />Cells: 2-4S <br />Max Current: 40A<br />Burst: 50A<br />BEC: None (Opto Only)<br /><br /><br />User Programming options: <br /> Battery setting <br /> Throttle Range <br /> Brake setting 4 options: Direction and Cutoff Type<br /> Timing Mode Setting: 1 / 7 / 15 / 30<br /> PWM setting: 8K/16K<br />Poze:<a href='https://drive.google.com/file/d/0B_jADtpOQRvaZjlZYTJKTUV6a3M/view?usp=sharing' class='bbc_url' title='Link extern' rel='nofollow external'>https://drive.google...iew?usp=sharing</a><br /><a href='https://drive.google.com/file/d/0B_jADtpOQRvaSGNnT3Q1ZEFFcFE/view?usp=sharing' class='bbc_url' title='Link extern' rel='nofollow external'>https://drive.google...iew?usp=sharing</a><br /><br />
<br /><br /><br />Salut. Cele doua esc-uri de la Hobbyking le vreau eu .Ai PM.
#6 Useril este offline   Wili
  • Postari: 201
Postat 30 September 2015 - 08:15 AM
Astazi pleaca spre userul cyrus
#7 Useril este offline   Wili
  • Postari: 201
Postat 02 October 2015 - 07:08 AM
VANDUT
#8 Useril este offline   cyrus
  • Postari: 211
Postat 07 October 2015 - 04:50 PM
Vezi postareaWili, la 02 October 2015 - 07:08 AM, a spus:
<br />VANDUT<br />
<br /><br /><br />Aseara le-am ridicat de la posta. Multumesc
