plusmodel
#34
Postat 15 May 2003 - 05:18 PM
Flickr - pozele mele
#36
Postat 16 May 2003 - 11:08 AM
http://www.tamiya.com/english/products/35259krupp/krupp_top1.jpg
http://www.tamiya.com/english/products/35259krupp/krupp2.jpg
http://www.tamiya.com/english/products/35259krupp/krupp4.jpg
1/35 scale Overall length: 250mm Every characteristic of this truck such as the low-profile bonnet, the chassis, the ammunition boxes and the crew seats on the rear part, as well as the spare wheel for the anti-tank gun has been realistically reproduced. A 3.7cm Pak anti-tank gun and various accessories are part of the set. 4 all-new figures and decals for 4 different markings are included.
A, scuze: 30$
Aceasta postare a fost editata de VIPER: 16 May 2003 - 11:21 AM
#38
Postat 16 May 2003 - 11:42 AM
http://www.tamiya.com/english/products/35257t55/t55_3.jpg
Tamiya presents the 1/35 scale plastic assembly kit of the Russian Medium Tank T-55A. The unique form of this tank has been accurately replicated. You can choose between several versions, with or without a DShK-M anti-aircraft machinegun, of the T-55 and T-55A. You will also be able to represent Polish or Czechoslovakian built versions. Every characteristic of the T-55A such as the engine grills and external fuel tanks has been reproduced down to the finest details. One tank crew chief figure and decals for 5 different markings are included.
#39
Postat 16 May 2003 - 11:47 AM
http://www.tamiya.com/english/products/24260enzo/enzo.jpg
http://www.tamiya.com/english/products/24260enzo/enzo3.jpg
http://www.tamiya.com/english/products/24260enzo/enzo5.jpg
1/24 Scale Plastic Assembly Kit. Overall Length: 197mm, Overall Width: 93mm. The assembly of the kit imitates the actual car construction. The V-12 engine has been replicated down to the finest details. The assembled engine is mounted on a sub-frame that is then attached on the chassis main frame. Front and rear suspensions have been precisely reproduced. The quite simple driving compartment has also been rendered faithfully. Once completed, the model form is perfectly accurate. Rear diffuser and car underside are identical to the actual Enzo. Gull wing type doors and rear cowling can be opened and closed.
#40
Postat 16 May 2003 - 11:49 AM
#41
Postat 16 May 2003 - 11:56 AM
http://www.tamiya.com/english/products/24255peugeot206_02/top.jpg
http://www.tamiya.com/english/products/24255peugeot206_02/rear.jpg
http://www.tamiya.com/english/products/24255peugeot206_02/int.jpg
1/24 scale, Overall length after completion: 168mm, Overall width: 75mm. Kit replicates Tour de Corse version. Attractive roundish body form, intricate roll cage frames, and tiny interior parts are authentically recreated. Includes driver & co-driver figures at the wheel. Decals for car No.1, 2, and 3 are included.
#42
Postat 16 May 2003 - 12:01 PM
http://www.tamiya.com/english/products/20053tyrrell_p34/tyrrell_p34_4.jpg
1/20 scale assembly model kit depicts Tyrrell P34 as it appeared in the Monaco GP, 1977 with the same half engine cowling of the previous season. Overall length: 201mm, overall width: 101mm. Model captures the unique form of the Tyrrell P34 with rear seat cowl, front brake cooling air duct, stabilizer, rear wing side plate, and taillight. Ford Cosworth DFV engine portrayed with the utmost detail. Gear box, ignition, and wheels are all precisely recreated. Driver figure included. Markings included for recreation of two machines: #3, R. Peterson and #4, P. Depailler.
#43
Postat 16 May 2003 - 12:04 PM
http://www.tamiya.com/english/products/24248astra_holzer/astra1.jpg
http://www.tamiya.com/english/products/24248astra_holzer/astra3.jpg
1/24 scale, total height: 196mm, total width 81mm.Model replicates machine driven by Joachim Winkelhock under Opel Team Holzer. Gull-wing style doors can be smoothly opened and closed even after assembly via metal hinges. Parts for propping up gull-wing doors have been precisely recreated in this model. Roll-cage and car-interior have been replicated with the utmost authenticity. Taillights employ transparent, clear red, and clear orange parts. Metal transfer marks are included for grille, emblem, bonnet and door-catch.
#45
Postat 16 May 2003 - 12:10 PM
http://www.tamiya.com/english/products/24241focus01_pre/focus_wrc01_1.jpg
http://www.tamiya.com/english/products/24241focus01_pre/focus_wrc01_3_2.jpg
1/24 scale, total length- 174mm, total width- 75mm.Decals replicate machine coloring in Monte Carlo Rally. Reproduction of rounded roll cage and cockpit spare no detail.Driver and data reading co-driver figures included.Decals included for replication of markings on Carlos Sainz's and Colin McRae's machines.
#46
Postat 16 May 2003 - 12:13 PM
#47
Postat 16 May 2003 - 12:15 PM
http://www.tamiya.com/english/products/24216pennzoil/pennzoil1.jpg
1/24 scale static assembly kit based on the Pennzoil Nismo GT-R, an active contender in the 1999 Japanese GT Championship. Overall length: 192mm, Overall width: 80mm Realistically recreated body with wide fenders and large rear wing capture the dynamic style of the Nismo GT-R. Roll cage and other cockpit race equipment included. Highly detailed large diameter brakes and suspension. Transparent undercowl reveals lower engine block and front suspension detail. Racing livery recreated with easy to use decals.
#48
Postat 16 May 2003 - 12:16 PM
#50
Postat 19 May 2003 - 10:54 AM
#51
Postat 19 May 2003 - 11:36 AM
#52
Postat 19 May 2003 - 11:38 AM
http://www.internethobbies.com/internethob.../plusmodel.html
http://www.plusmodel.cz/
http://www.steelmode...i/Plusmodel.htm
#53
Postat 20 May 2003 - 11:19 AM
VIPER, la 19 May 2003, 11:36, a spus:
Da, cit am nevoie imi aduc de fiecare data cind fac o vizita acolo
#54
Postat 20 May 2003 - 12:34 PM
#55
Postat 20 May 2003 - 02:37 PM
VIPER, la 20 May 2003, 12:34, a spus:
Nu cind aduci 2-3 kit-uri de figurine sau de tank Totuþi nu fac afaceri prin asta nu?
#56
Postat 20 May 2003 - 02:41 PM
#57
Postat 20 May 2003 - 03:51 PM
Intrebarea mea de mai devreme nu era pentru o idee de business (cu toate ca de ce nu, s-ar gasi clienti garantat!) ci in ideea daca ai cum sa ajuti pe alti amatori de modele adevarate sa-si procure Tamiya...
#58
Postat 21 May 2003 - 08:24 AM
Am un 1/24 Mercedes Benz CLK GTR D2 luat acum vreo 3-4 ani din Belgia (din cate-mi amintesc, in jur de 20$) si este o bijuterie. Detalii complete la motor, suspensii, roti... Din pacate nu mai este pe site la Tamiya, dar daca am timp poate îi fac niste poze.
Pacat ca masina asta nu mai alearga la Le Mans (dupa ce si-a luat zborul).
Postat 21 May 2003 - 09:17 AM
Aceasta postare a fost editata de VIPER: 21 May 2003 - 09:57 AM
