Modelism - RHC Forum: F5J Eurotour la vecini - Modelism - RHC Forum
F5J Eurotour la vecini Korona Cup 2015 Ungaria
#1 Useril este offline   OcsiRC
  • Postari: 567
  • Inregistrat: 16-April 14
Postat 14 June 2015 - 09:25 PM
Pentru cei interesati sa urmareasca o competitie F5J cu traditie desfasurata dupa reglementari FAI , sau isi doresc sa concureze cu sportivi din vreo 7 tari , mai jos date de concurs / inscriere .....
Din pacate competitia se desfasoara cu programare usor atipica - joi si vineri - pentru a lega si competitia interna de F3J care se desfasoara in continuare -sambata si duminica ....
Voi reveni cu amanunte / poze
#2 Useril este offline   Travel Air
  • Postari: 1235
  • Interests:Zbor
Postat 14 June 2015 - 09:49 PM
Vezi postareaOcsiRC, la 14 June 2015 - 09:25 PM, a spus:
Multe si amanuntite :clapping:
Pare sa fie destul de ieftin si aproape...
Si categoria F5J-400-ALTI ce inseamna?
Aceasta postare a fost editata de Travel Air: 14 June 2015 - 09:52 PM
Bogdan Floria
bogdan.floria@aeromodelism.ro
bogdanfloria@gmail.com
0757110983
#3 Useril este offline   OcsiRC
  • Postari: 567
Postat 14 June 2015 - 10:33 PM
Vezi postareaTravel Air, la 14 June 2015 - 09:49 PM, a spus:
RULES OF F5-J254 CATEGORY (F5J-400-Alti)
Basic: F5J FAI rules.
Differences:
5.5.11.1.3. a) Maximum wingspan: .... 254 cm
j) .....
The (altimeter / motor run timer) device can allow the motor to be restarted
during the flight.
If the motor is being restarted the device must not show F5J Alt. In this case
the result of the flight is 0.
5.5.11.5.1 The competitor will be allowed two attempt at each official flight. In the case of
second attempt, only the second result must be recorded.
Accepted firmware’s:
- F5J FAI or
- special firmware for this rules
+ motoare direct drive seria 400 accu max 2 S ... in rest idem F5J
  • Postari: 19177
Postat 15 June 2015 - 08:01 AM
Inseamna ca pulsarul ala de 2.5m de il stiu eu, pentru categoria asta este echipat... ma miram ce are motor asa mic 67g si kv mare... 1337kv... 2s clar
#5 Useril este offline   OcsiRC
  • Postari: 567
Postat 15 June 2015 - 10:01 AM
Vezi postarearenatoa, la 15 June 2015 - 08:01 AM, a spus:
Corect !
Asa e si prezentat / oferit , F5J - dar nu doar F5J-400 , echiparea recomandata aici il face compatibil F5J ...doar fara mentiunea ca la suprafata lui... e greu sa se ia la tranta cu compozite de competitie cu anverguri de 3,5m + ... :pardon: ...desi la cat de usor e , cu o vreme linistita ...
