Modelism - RHC Forum: setare ESC - Modelism - RHC Forum
setare ESC
#1 Useril este offline   ZIPPO 9
  • Postari: 439
  • Inregistrat: 17-January 14
  • Interests:RC & BIKE
Postat 29 November 2014 - 10:46 PM
salut.am o problema cu Traxxas EVX2:Il pornesc,se aprinde verde apoi incepe sa clipeasca rosu intruna.NU pot actiona motorul deloc.Am incercat sa il calibrez dupa manual:tin apasat verde-rosu las ,clipeste odata......accel fulll,clipeste de 2 ori....full revers ...se aprinde verde las in neutru si incepe problema:in loc sa ramana verde continuu,ramane 1secunda si incepe sa clipeasca rosu
il alimentez dintro sursa la 7 V.radiocomanda e un HK GT2 2.4ghz
va rog foarte mult sa ma ajutati
HSP NITRO 1/10 buggy
TAMIYA SONIC FIGHTER 1/10 brushed
#2 Useril este offline   Pinochio
  • Postari: 236
  • Inregistrat: 30-October 05
  • Interests:Running
Postat 30 November 2014 - 10:02 AM
•Fast Blinking Red: The EVX-2 is equipped with thermal shutdown
protectionto guard against overheating caused by excessive current
flow.If the operating temperature exceeds safe limits, the EVX-2 will
automaticallyshut down. Let the EVX-2 cool. Make sure your model is
properlygeared for the conditions.
•Slow Blinking Red (with Low-Voltage Detection on): The EVX-2 has
enteredLow-Voltage Protection. When the battery voltage begins to
reachthe minimum recommended discharge voltage threshold for LiPo
batterypacks, the EVX-2 will limit the power output to 50% throttle. When
thebattery voltage attempts to fall below the minimum threshold, the
EVX-2will shut down all motor output. The LED on the speed control will
slowlyblink red, indicating a low-voltage shutdown. The EVX-2 will stay in
thismode until a fully charged battery is connected.
Aceasta postare a fost editata de Pinochio: 30 November 2014 - 10:05 AM
#3 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 30 November 2014 - 12:55 PM
Vezi postareaPinochio, la 30 November 2014 - 10:02 AM, a spus:
Acum am dat din sursa 8,4 V si tot aceeasi problema.
#4 Useril este offline   Mr.Catalin
  • fan HPI!
  • Postari: 708
  • Inregistrat: 25-August 14
Postat 30 November 2014 - 09:05 PM
http://s115.photobuc...WIRING.jpg.html
evx2 este un esc facut sa functioneze cu 2 acc 7,2/7,4v in serie.
pt a fi folosit sub 16.8v foloseste schema de mai sus si schimba pe nimh.
Aceasta postare a fost editata de Mr.Catalin: 30 November 2014 - 09:09 PM
#5 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 30 November 2014 - 09:59 PM
Adica il alimentez 8,4 pe akku,impreuna16,8
#6 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 01 December 2014 - 03:26 PM
Ce inseamna cand clipeste rosu?
#7 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 02 December 2014 - 09:38 PM
Nu reusec nimic cu el!!
#8 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 04 December 2014 - 07:24 PM
imi intra pe el protectia termica si nu ma lasa sa fac nimic
ce sa fac
#9 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 06 December 2014 - 09:44 AM
Cnva care a avut esc poate da niste sfaturi?
#10 Useril este offline   Mishu-Ptm
  • Postari: 652
  • Inregistrat: 07-April 12
  • Interests:Heli
Postat 12 December 2014 - 12:19 AM
Ia incearca sa opresti LVC (low voltage cutoff)
Trex 600 Pro EFL | Trex 500 ESP FBL - Spektrum Dx6
Sprint 2 Sport | Tamco Raider | Speed Passion RS-2 | Turnigy SCT 1/16
My feedback
#11 Useril este offline   ZIPPO 9
  • Postari: 439
Postat 19 December 2014 - 10:35 AM
Cum?
