Profundor detasabil
Servouri hex 9g 4 buc
Motor LiPolice+esc LiPolice 25A
325 lei + transport FanCourier
Pentru a zbura mai are nevoie de TX, rx si acumulator 3S, 1800-2200mA
Andu, 0724242950
HK Bixler RTF anvergura 1400 mm
Postat 08 March 2014 - 09:22 PM
Roaga un moderator sa iti redenumeasca topicul cu ARF,RTF inseamna pachet complet cu tot cu statie receptor acumulator si incarcator.
Postat 08 March 2014 - 09:44 PM
Ciprian97, la 08 March 2014 - 09:22 PM, a spus:
Asa e, ARF e denumirea corecta, multumesc.
Number of downloads: 156 -
Number of downloads: 149 -
Number of downloads: 130 -
Number of downloads: 136 -
Number of downloads: 142 -
Number of downloads: 138 -
Number of downloads: 135 -
Aceasta postare a fost editata de ANDUNG: 08 March 2014 - 09:44 PM
Postat 11 March 2014 - 09:34 AM
Revin cu detalii despre motor si ESC:
Motor LiPolice LPA-2213/18T 1200Kv
Cell number LiPo/LiFe: 3 S
Maximal current short: 20 A
Maximal capacity: 200 W
No-load current approx: 1,13 A
Internal resistance: 0,075 Ohm
Number of turns: 18 T
Number of poles: 14
Idle speed: 1200 U/min/V
Ø Engine: 28 mm
Ø Engine shaft: 3 mm
Length of engine without shaft: 32 mm
Weight of engine without gear: 55 g
Recommended air screw: 9x4,7-10x4,7
Pe Bixler e folosit cu elicea originala din kit , mai mica ( 5 x 5.5 parca) si trage ok fara nicio problema.
Cumparatotului ii pun la dispozitie si suportul original in cruce ( Bixler are suport propriu).
http://www.der-schwe...2213_18t-1200kv
Regulator LiPolice ESC 25A-BEC
Application area: Aeromodele
Cell number NiCd/NiMH: 6-10
Cell number LiPo: 2-3 S
Continuous current: 25 A
Maximal current short: 30 A
BEC continuous current: 2 A
Length approx: 42 mm
Width approx: 25 mm
Height approx: 7 mm
Weight with cable: 18 g
http://www.der-schwe...ice_esc_25a-bec
Si o actualizare de pret: 295 RON + transport curier ( daca e cazul).
Andu, 0724 24 29 50
Bucuresti
Number of poles: 14
Ø Engine: 28 mm
Width approx: 25 mm
Height approx: 7 mm
Andu, 0724 24 29 50
Bucuresti
Acest topic e inchis
