am gasit pe net totusi un tabel de programare ..
si avem :
Turn on transmitter
Put model on car stand, hold mode button down and switch on ESC
Release mode button.
RED LED blinks one time entering setting mode
Press mode button to enter next setting mode
Press mode button and hold it GREEN LED blinks one time
Pressing mode button will take you through each parameter
Pressing mode button for more then one second completes setting
Turn off ESC and transmitter
Parameter Modes
RED LED.........GREEN LED.............Action
one blink........one blink............. NiMh battery
.....................two blink..............LiPo battery*
.....................three blink............LiFo battery
two blink........one blink..............reverse off
.....................two blink..............reverse LOW
.....................three blink............reverse Medium*
......................four blink.............reverse HIGH
three blink......one blink..............standard start
.....................two blink..............LOW start
.....................three bblink..........MEDIUM start
.....................four beep..............HIGH start*
four blink.......one blink..............drag brake OFF*
....................two blink..............drag brake LOW
....................three blink............drag brake MEDIUM
....................four blink..............drag brake HIGH
* the default setting..............
# modificarile se fac pe rand, repetand pasii
Aceasta postare a fost editata de e.cata: 30 November 2013 - 06:04 PM
