Features:
Arduino and ArduPilot Mega 2.5 Compatible!
Includes both right angle and straight pins for I/O, allowing user to customize as needed.
Includes 3-axis gyro, accelerometer and magnetometer, along with a high-performance barometer
Onboard 16Mbit Dataflash chip for automatic datalogging
Digital compass powered by HMC5883L chip, included on the main board.
Invensense's 6 DoF Accelerometer/Gyro MPU-6000.
Barometric pressure sensor upgraded to MS5611-01BA03, from Measurement Specialties.
Atmel's ATMEGA2560-16AU and ATMEGA32U-2 chips for processing and usb functions respectively.
The RCTimer Radio telemetry system base on 3DR Radio system and 100% compatible.
It's designed as an open source Xbee replacement radio set, offering a lower price, longer range (approx one mile) and superior performance to Xbee radios. It’s available in 915Mhz ; and in the following configurations: serial board (for the air) and USB (for the ground).
The system provides a full-duplex link using HopeRF's HM-TRP modules running custom, open source firmware. Interface to the module is via standard 5V-tolerant TTL serial / FTDI USB serial.
Firmware upgrades and configuration are fully supported in the APM Mission Planner. Configuration is also possible through the 3DR Radio configurator and AT commands.
GPS CN06 Features:
·Standalone GPS receiver
·u-blox NEO-6M GPS module
·EEPROM for save configuration permanently
·Build in 25X25mm active antenna
·UART (TTL) port with EMI protection
·Rechargeable battery for backup/hotstart
Default parameter
·Baud rate : 9600
If this GPS receiver used for I2C-GPS NAV Board, it must be changed to baud rate 115200 / update rate 5hz.
Package content
·Apm2.5 x 1
·CN06 V2.0 x 1
·Radio Telemetry Kit 433Mhz x 1
PRET: 800 Ron
Tel 0722514695
Number of downloads: 71 -
