Modelism - RHC Forum: DIverse - Modelism - RHC Forum
DIverse catamaran, motor, carme, arbore
#1 Useril este offline   GST 7.7
  • Sky isn't the limit
  • Postari: 1074
  • Inregistrat: 13-August 07
  • Interests:Programare, IT, Modelism
Postat 03 September 2012 - 01:10 PM
1) 2 ansamble Z-Drive cu cardan (fara elice) pret 40 lei o bucata
2) Arbore cu tub pupa:
Diametru arbore: 4 mm
Lagar: Bucsa bronz
Lungime arbore: 130 mm
Diametru tub: 6.5 mm
Filet: M4
Lungime tub: 90 mm
25 lei o bucata
3) Burduf de etansare (2 buc) 15 lei ambele
Fisier atasat  20111223_002.jpg (197.37K)
4) Barcuta din balsa neterminata, cu hardware montat, carma cu admisie de apa, elice, ax flexibil, servo, cuplaj. Pret 200 lei
Fisier atasat  20111223_003.jpg (151.35K)
Number of downloads: 438 Fisier atasat  20111223_004.jpg (134.32K)
Number of downloads: 442 Fisier atasat  20111223_005.jpg (119K)
5) Motor HXT 2040 4850kv Brushless Inrunner (conectori auriti de 4mm) - Pret 60 lei
Motor Size: 2040 (130L)
Speed: 4850kv
ESC Required: 18A
Voltage Range: 6~12v
No Load Curr: 1.8A
Max Load: 25A
Diameter: 20.2mm
Length: 42mm
Front Mounting Hole Distance: 16mm
Front Mount Thread Size: M2.5
Shaft Diameter: 2.3mm
Shaft Length: 10mm
Sau 350 lei tot ce e mai sus
Fisier atasat  20111223_006.jpg (161.13K)
Aceasta postare a fost editata de GST 7.7: 03 September 2012 - 01:10 PM
The GST 7.7 is over 30% larger than a Revo 3.3. Park the GST 7.7 next to a Savage, and the Savage doesn't look so tough anymore.
#2 Useril este offline   GST 7.7
  • Postari: 1074
Postat 10 September 2012 - 09:58 AM
up
#3 Useril este offline   catilin
  • Postari: 40
  • Inregistrat: 10-April 10
Postat 10 September 2012 - 02:26 PM
1,2 si 3 le iau eu.un nr de tel.ms.
#4 Useril este offline   GST 7.7
  • Postari: 1074
Postat 10 September 2012 - 09:47 PM
Ai PM
#5 Useril este offline   GST 7.7
  • Postari: 1074
Postat 13 September 2012 - 03:43 PM
1,2,3 au plecat azi mai ramane barca si motorul ambele 240lei
#6 Useril este offline   GST 7.7
  • Postari: 1074
Postat 20 September 2012 - 10:04 AM
Up pentru barca cu motor la 220 lei
#7 Useril este offline   GST 7.7
  • Postari: 1074
Postat 28 September 2012 - 09:56 PM
up
#8 Useril este offline   GST 7.7
  • Postari: 1074
Postat 05 October 2012 - 09:17 PM
200 ultimu pret
#9 Useril este offline   GST 7.7
  • Postari: 1074
Postat 12 October 2012 - 09:27 PM
up
#10 Useril este offline   GST 7.7
  • Postari: 1074
Postat 20 October 2012 - 10:30 AM
up merg si schimburi
#11 Useril este offline   GST 7.7
  • Postari: 1074
Postat 27 October 2012 - 04:00 PM
up
#12 Useril este offline   GST 7.7
  • Postari: 1074
Postat 10 November 2012 - 11:20 AM
bump
#13 Useril este offline   GST 7.7
  • Postari: 1074
Postat 31 January 2013 - 01:57 PM
Barcuta din balsa neterminata, cu hardware montat, carma cu admisie de apa, elice, ax flexibil, servo, cuplaj + motor Pret 200 lei
#14 Useril este offline   GST 7.7
  • Postari: 1074
Postat 11 February 2013 - 09:46 PM
up
