2) Arbore cu tub pupa:
Diametru arbore: 4 mm
Lagar: Bucsa bronz
Lungime arbore: 130 mm
Diametru tub: 6.5 mm
Filet: M4
Lungime tub: 90 mm
25 lei o bucata
3) Burduf de etansare (2 buc) 15 lei ambele
4) Barcuta din balsa neterminata, cu hardware montat, carma cu admisie de apa, elice, ax flexibil, servo, cuplaj. Pret 200 lei
5) Motor HXT 2040 4850kv Brushless Inrunner (conectori auriti de 4mm) - Pret 60 lei
Motor Size: 2040 (130L)
Speed: 4850kv
ESC Required: 18A
Voltage Range: 6~12v
No Load Curr: 1.8A
Max Load: 25A
Diameter: 20.2mm
Length: 42mm
Front Mounting Hole Distance: 16mm
Front Mount Thread Size: M2.5
Shaft Diameter: 2.3mm
Shaft Length: 10mm
Sau 350 lei tot ce e mai sus
Aceasta postare a fost editata de GST 7.7: 03 September 2012 - 01:10 PM
