Vine, vine, primavara... Fac loc in debara
Postat 06 April 2012 - 12:22 PM
1. Avion biplan Pitts Special 1400mm, motor OS 91 FX Max, UBEC HiModel 8A (max.15A) 2-3S LiPo, acumulator LiPo Turnigy 2S 2100 mAh, servo standard Turnigy (necesita RX/TX si retusuri minore la folia de la varful aripii inferioare care a fost ciupita/agatata de ciulini/scaieti/ierburi) = 800 RON
http://img846.imageshack.us/img846/3269/imagine0385.jpg http://img685.imageshack.us/img685/7889/imagine0386.jpg
http://img140.imageshack.us/img140/2500/imagine0387.jpg
2. Aripa Slinger (schimbat motorul cu perii cu un brushless EMAX 2812), echipata complet (necesita doar Rx/Tx; a zburat fix 4 acumulatori, achizitionata in decembrie = 200 RON
http://img94.imageshack.us/img94/5580/imagine0396.jpg http://img190.imageshack.us/img190/8880/imagine0395.jpg
3. Motor brushless NTM Prop Drive 3536/1400kV (ax rupt, il dau cu ax de schimb) = 35 RON
Specs:
Model: NTM Prop Drive 35-36B 1400
Kv: 1400rpm/v
Turns: 7
Max current: 53.94A
Max Power: 495W @ 12v (3S) / Waiting test results (4S)
Shaft: 4mm
Weight: 117g
ESC: 60A
Cell count: 3s~4s Lipoly
Front Mounting Hole Distance: 25mm or 19mm
http://img851.imageshack.us/img851/7812/imagine0418.jpg
4. Motor brushless NTM Prop Drive 3536/1800kV (ax rupt, il dau cu ax de schimb) = 40 RON
Specs:
Model: NTM Prop Drive 35-36A 1800
Kv: 1800rpm/v
Max current: 65A
Max Power: 700W @ 12v (3S) / 875W @ 15v (4S)
Shaft: 4mm
Weight: 120g
ESC: 70A
Front Mounting Hole Distance: 19mm or 16mm
Connection: 3.5mm Bullet-connector
http://img834.imageshack.us/img834/9186/imagine0419.jpg
5. Motor brushless Roxxy 3541 (folosit) = 80 RON
http://img823.imageshack.us/img823/7733/imagine0420.jpg
6. Motor brushless Turnigy Aerodrive 2828 (nou) = 30 RON
http://img38.imageshack.us/img38/1568/imagine0421j.jpg
7. Motor brushless Roxxy 2830/12 (folosit) = 100 RON
Specificatii:
Tensiune: 2-4 cell LiPo (7 - 15 V)
Curent: 12 A
Curent maxim: 19 A (max 60 sec)
Turatie in gol: 910 rpm/ V
Tractiune maxima: 1000 g
Dimensiuni: 28 x 30 mm
Diametru ax: 3.17 mm
Masa: 57 g
Elice recomandata: 11 x 5.5 inch
http://img27.imageshack.us/img27/8939/imagine0422.jpg
8. Motor brushless Turnigy 3648/600kV (nou) = 85 RON
Dimension: 51mm x 37mm, 70mm(with shaft)
Weight: 136g (kv600)
Diameter of shaft: 5mm
Length of front shaft: 19.1mm
Lamination thickness: .2mm
Magnet type: 45SH
Max performance
Voltage: 2-3S
Max current: 35~50A
Prop: 12x8~14x10
Thrust: 1820~2400g
Power: 800W
For 1800~2500g model airplane.
http://img7.imagesha...imagine0423.jpg
9. Motor brushles 2830/1300kV (nu stiu ce e, banuiesc ca e motorul de pe Arcus, folosit) = 35 RON
http://img43.imagesh...magine0424u.jpg
10. Motor brushless BM 2410/12 (flosit, ax rupt) = 15 RON
http://img521.images...magine0425j.jpg
11. Regulator (ESC) Multiplex BL-17/II, 17A, 2-3S LiPo = 50 RON
http://img209.images...imagine0427.jpg
12. Regulator (ESC) Art-Tech 20 A = 40 RON
http://img822.images...imagine0428.jpg
13. Motor cu perii (habar n-am de care e); dimensiuni: 28x43mm, ax=2,32mm = 20 RON
http://img707.images...imagine0429.jpg
14. Adaptor ax elice/prop saver (pt ax 3,17mm) (3 seturi) = 10 RON (toate 3)
http://img805.images...magine0430d.jpg
15. Adaptor ax elice/con (pt ax 4mm) = 5 RON
http://img834.images...imagine0431.jpg
16. Adaptor ax elice/con (pt ax 3mm) = 5 RON
http://img842.images...imagine0432.jpg
17. Ax motor 3542 (4mm) = 5 RON
http://img577.images...imagine0433.jpg
18. Ax motor 3530 (4mm) (2 buc) = 5 RON/buc
http://img341.images...imagine0434.jpg
19. Ax motor 2836 (4mm) (3 buc) = 5 RON/buc
http://img688.images...imagine0435.jpg
20. Ax motor 2830 (3,17mm) (3 buc) = 5 RON/buc
http://img269.images...imagine0436.jpg
Postat 06 April 2012 - 12:25 PM
http://img841.imageshack.us/img841/754/imagine0437.jpg
22. Elice JXF Sport 14x8 = 25 RON
http://img337.imageshack.us/img337/9336/imagine0438.jpg
23. Elice Master Airscrew K 14x6 = 25 RON
http://img163.imageshack.us/img163/273/imagine0439.jpg
24. Elice Master Airscrew K 13x8 = 20 RON
http://img269.imageshack.us/img269/9449/imagine0440.jpg
25. Elice Electro 11x5,5 (2 buc, 1 noua, 1 folosita) = 20 RON (amandoua)
http://img268.imageshack.us/img268/289/imagine0441.jpg
26. Elice Electro 13x4 = 20 RON
http://img138.imageshack.us/img138/2502/imagine0442.jpg
27. Elice Electro 12x6 = 15 RON
http://img526.imageshack.us/img526/6672/imagine0443o.jpg
28. Elice APC 13x6,5 (folosita) = 15 RON
http://img40.imageshack.us/img40/9721/imagine0444.jpg
29. Elice GWS 13x6,5 = 5 RON
http://img822.imageshack.us/img822/4356/imagine0445f.jpg
30. Elice GWS 12x6 (folosita) = 5 RON
http://img41.imageshack.us/img41/4781/imagine0446.jpg
31. Elice GWS 8x4 (3 buc noi) = 15 RON (toate 3)
http://img829.images...imagine0447.jpg
32. Elice tripala GWS 10x6 = 5 RON
http://img818.images...imagine0448.jpg
33. Mini Power Panel Turnigy (Input:12V, glow output 1,5V, ignitor charger, DC 12V output) = 50 RON
http://img685.images...imagine0450.jpg
34. Parghie plastic pentru suprafete de comanda 20x27mm 4 gauri, 4 buc./set (am 5 seturi) = 5 RON (toate cele 5 seturi)
http://img521.images...imagine0451.jpg
35. Parghie reglabila cu talpa din aluminiu si brat filetat. Articulatia intre brat si furca poate fi realizata cu articulatie sferica sau cu rulment, eliminand frecarile si jocul mecanic.
Lungime: 70 mm, filet: M4 Gaura ptr. articulatie: 3 mm, surub M3x10 cu piulita inclus
1 set cu 4 buc. = 15 RON
http://img407.images...imagine0452.jpg
Postat 06 April 2012 - 12:26 PM
Postat 06 April 2012 - 01:36 PM
Postat 07 April 2012 - 07:38 AM
http://img585.imageshack.us/img585/6493/20120406143800.jpg http://img62.imageshack.us/img62/6397/20120406142338.jpg
Postat 07 April 2012 - 07:45 AM
Se adauga la lista de mai sus si o statie Futaba T6EX 2.4GHz cu acumulator LiPo 2200mAh + 1 receptor original + 2 receptoare OrangeRx Futaba FASST + curea de gat = 600RON
http://img6.imageshack.us/img6/827/20120406142411.jpg
Postat 07 April 2012 - 09:40 AM
Postat 07 April 2012 - 10:30 AM
Aceasta postare a fost editata de adyrex: 07 April 2012 - 10:30 AM
Postat 07 April 2012 - 11:43 AM
Postat 07 April 2012 - 12:46 PM
#11
Postat 18 April 2012 - 03:10 PM
toate cu exceptia pozitiilor 6, 11, 14, 15, 32.
Nu uitati de super oferta de primavara-vara referitoare la statia Futaba cu 3 receptoare!
Aceasta postare a fost editata de Rower: 18 April 2012 - 03:11 PM
#16
Postat 06 May 2012 - 04:01 PM
#17
Postat 06 May 2012 - 06:06 PM
Mersi mult
#18
Postat 07 May 2012 - 09:14 AM
#19
Postat 10 May 2012 - 08:39 AM
Si cele 2 motoare cu ax rupt:
Un pret total pe PM.
Stima, George.
0767699779.
Aceasta postare a fost editata de PANTHERA: 10 May 2012 - 08:41 AM
#24
Postat 29 December 2012 - 02:03 PM
Mersi mult.
#25
Postat 29 December 2012 - 05:02 PM
Ma int. punctul 3 sau 4 daca s-au vandut.
IAR 80
JU-A702.
YAR832
Tlf.0744493927
#26
Postat 01 January 2013 - 03:35 PM
Stima si La Multi Ani!
