Kv: 4800rpm/v
Diameter: 25.2mm
Length: 56mm
Shaft diameter: 2.3mm
Weight: 77g
Battery: 2-3S 2200mAh+
acest motor este destul de bun pentru un navomodel de nadit?
Corona 928BB Servo 7.0kg/ 53g/ 0.13sec
Model: CS928BB
Operating Voltage: 4.8V / 6.0V
Operating Current: 200mA / 240mA
Operating Speed: 0.14sec.60º/ 0.13sec.60º
Stall Torque: 1.8kg.cm / 2.0kg.cm
Weight: 9g
Dead Band: ≤5uSec
Operating Travel: 40º/one side pulse traveling 400us
Potentiometer: 2 slider/Direct Drive
Ball bearing: MR85
Gear: Plastic
Connector wire: 215mm
Operating Temperature Range: -20J+6
ce greutate pot pune pe cuve cu acest servo?
HobbyKing 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)(THROTTLE ON THE LEFT)
pina la ce distanta merge aceasta radiocomanda?
astept pareri
Aceasta postare a fost editata de mallaxa: 08 December 2011 - 11:23 PM
