Modelism - RHC Forum: Curatenie de Primavara - Modelism - RHC Forum
Curatenie de Primavara acumulatori, motoare, etc.
#1 Useril este offline   VanPulov
  • Postari: 503
  • Inregistrat: 01-August 06
  • Interests:navo
Postat 15 May 2011 - 09:07 PM
Salutare,
Se vand urmatoarele
Preturile si detalii gasiti mai jos
#2 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 15 May 2011 - 09:09 PM
#3 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 15 May 2011 - 09:14 PM
AERO X3D
mini avion (jucarie)
Telecomanda 40 mhz - merge cu 6 celule AA
Avionul cu doua motoare BL acumulator lipo incarcare de la telcomanda sau de la incarcator
#4 Useril este offline   NAVOMARIUS
  • MARIUS
  • Postari: 4699
  • Inregistrat: 04-October 10
  • Interests:AEROMODELE
Unde-s preturile?
Tel 0740850863
Grea 6--POZE CET VEST
#5 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 15 May 2011 - 09:24 PM
Aripa polistiren expandat cu anvergura de aprox. 1,3m
ranforsata cu bagheta rotunda cu diametrul de 10mm
pret 80 ron
motor T
Model: 2409-12 Delta Turn
Weight: 63g
Voltage: 10v (2~3 Cell lipo pack)
Idle Current: 1.9
Kv: 1600
Shaft: 3mm Diameter
Max efficient current: 23
Max Load: 25A
Max Power Output:200W
Suggested Propeller: 8*.3.8 or 8*6 GWS Hyper Drive
pret 50 ron
TowerPro Brushl
ess Outrunner TP2409_12D
#6 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 15 May 2011 - 10:20 PM
1. lipo Flightmax 3s 11.1v 2200 mAh 20C 50 ron
2. lipo RCS 3s 11.1v 2260 mAh 25C 50 ron
3. lipo (primii care au aparut la sierra) 3s 11.1v 3300 mAh (cam obosit, dar merge) 40 ron
4. lipo RCS 3s 11.1v 4000 mAh 20C 80 ron
5. NiCd 6N 7,2V 2400 mAh 20 ron
6. NiMh 7N 8,4V 3300 mAh SunPower 40 ron
7. NiMh 7N 8,4V 4600 mAh LRP 100ron
8. NiCd 5N 6V 1300mAh Sanyo 30ron
9. NiCd 5N 6V 1300mAh Sanyo 30ron
10. Sursa modificata 12V 7A 40 ron
11. 2x lipo Flightmax 2s 7.2v 5000 mAh 20C 100ron/buc
12. cooler cu ventilator pentru motoare seria 540 50ron
13. variator jamara NO LIMIT 180 ron
14. motor brushed Graupner seria 400 7,2V 20 ron
15. motor brushed 12x2 pregatit pentru navo (racire peperii) lagare cu rulmenti 50 ron
16. Motor brushed Team Orion 12x2 pregatit pt navo (racire perii, camasa de racire carcasa) lagare cu rulmenti, se vinde fara cuplajul de pe ax 80ron
17. motor brushed 17T 70ron
18. Z-Drive 30 ron
19. Slefuitor cu vibratii 220V 40 ron
20. 2x spirala de racire 5ron/buc
21. Incarcator acumulatori Plumb 2v/6v/12v 80ron
22. 8xAA NiMh 2500 mAh 30 ron
23. 4xAAA NiCd 600mAh 10 ron
24. 8xAA GP NiCd 1300mAh 30ron
25. 8xAA GP NiCd 1000mAh 20 ron
26. 4xAAA NiCd 800mAh 10 ron
Bonus 4xAA EcoPower (Graupner) NiCd 800mAh pentru cine cumpara acumulatorii NiMh/NiCd de mai sus
27. acumulator Pb 2V pentru alimentare bujie 20ron
28. fisa bujie 20 ron
29. acumulator 12V 7Ah 30 ron
30. filtru combustibil 5 ron
31. roto-start graupner-eco 12V 80 ron
32. cutia+pompa combustibil electrica+furtune 60ron
33. motor nitro Magnum XLS .46 7,45cmc heli aprox 3l consumati 250 ron
34. nitro 5% mai bine de 2,5l in bidon 70 ron
elice pentru termice 10x6 10 ron
rezervor 110ml 10 ron
rezervor 340ml 15 ron
accept si combinatii de preturi
la cumpararea mai multor produse se face reducere de pret
la pachetul ''termic'' de la pozitia 27. pana la sfarsit prefer sa le dau toate impreuna
Aceasta postare a fost editata de VanPulov: 15 May 2011 - 10:23 PM
#7 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 15 May 2011 - 10:22 PM
Vezi postareaNAVOMARIUS, la 15 May 2011 - 09:14 PM, a spus:
Unde-s preturile?
nu te grabi, sunt din cluj, merge mai incet treaba :rolleyes: sunt si multe.....
am uitat pretul pentru avionul de jucarie(polistiren) ------100 ron
pentru alte detalii, intrebari si sugestii va astept cu placere
Aceasta postare a fost editata de VanPulov: 15 May 2011 - 10:25 PM
#8 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 16 May 2011 - 07:26 PM
s-au dat unele chestii
18. Z-Drive 30 ron
#9 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 29 May 2011 - 09:15 PM
update
18. Z-Drive 30 ron
#10 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 30 May 2011 - 07:21 PM
update
18. Z-Drive 30 ron
Aceasta postare a fost editata de VanPulov: 30 May 2011 - 07:22 PM
#11 Useril este offline   florin_group
  • Postari: 56
  • Inregistrat: 17-May 11
Postat 01 June 2011 - 08:50 PM
salut,
in ce stare este pozitia 1 sau 2? adica cat de utilizate au fost?
trimiteti in bucuresti prin posta?
multumesc
#12 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 01 June 2011 - 09:25 PM
Vezi postareaflorin_group, la 01 June 2011 - 08:50 PM, a spus:
salut,
multumesc
imi pare rau dar s-au dat ambele
doar informativ: trimit si prin posta oriunde in tara
#13 Useril este offline   adrian40
  • Postari: 216
  • Inregistrat: 18-January 09
  • Gender:Not Telling
Postat 02 June 2011 - 09:51 AM
salut iau acumulatorul de bujie si fisa daca le lasi la 30 amindoua,
#14 Useril este offline   Richard 59
  • ex garorich
  • Postari: 138
  • Inregistrat: 09-July 08
Postat 02 June 2011 - 07:37 PM
Spune-mi te rog denumirea exacta a modelelor motoarelor de la poz.15,16 si 17,pentru detalii tehnice amanuntite(cautare pe net).Multumesc.
#15 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 03 June 2011 - 07:45 AM
Vezi postareaadrian40, la 02 June 2011 - 09:51 AM, a spus:
ai PM
#16 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 03 June 2011 - 07:46 AM
Vezi postareaGarorich, la 02 June 2011 - 07:37 PM, a spus:
ok
o sa ma interesez si te informez
unul din ele s-a dat
dar o sa postez detalii cu restu
#17 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 03 June 2011 - 12:30 PM
update
18. Z-Drive 30 ron
#18 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 03 June 2011 - 03:17 PM
update
11. lipo Flightmax 2s 7.2v 5000 mAh 20C 100ron/buc
18. Z-Drive 30 ron
#19 Useril este offline   Richard 59
  • ex garorich
  • Postari: 138
Postat 04 June 2011 - 08:52 PM
Nu te cazni sa cauti detalii pe net,pot s-o fac si eu...Spune-mi numai cum le cheama exact...
#20 Useril este offline   adi6109
  • Postari: 1
  • Inregistrat: 01-June 11
Postat 05 June 2011 - 05:59 PM
spune-mi te rog care este starea acc de la pozitia 4
#21 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 05 June 2011 - 07:50 PM
Vezi postareaGarorich, la 04 June 2011 - 08:52 PM, a spus:
salut
pe cel cu 17 infasurari l-am gasit
http://www.offroad-c...tock%2017x2.htm
cat despre team orion 12x2 inca mai caut
#22 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 05 June 2011 - 07:52 PM
Vezi postareaadi6109, la 05 June 2011 - 05:59 PM, a spus:
are aproximativ 10 cicluri incarcare-descarcare
pot sa te asigur ca nu este un acumulator din gama de varf, dar isi face treaba cum trebuie atata timp cat nu ii incerci limitele
#23 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 07 June 2011 - 03:26 PM
update
18. Z-Drive 30 ron
#24 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 07 June 2011 - 03:28 PM
Vezi postareaVanPulov, la 15 May 2011 - 09:14 PM, a spus:
AERO X3D
pret 100 ron
#25 Useril este offline   Richard 59
  • ex garorich
  • Postari: 138
Postat 10 June 2011 - 06:52 PM
Pentru motorul de la poz.16,spune-mi te rog diametrele cu si fara camasa de racire si diametrul axului.Multumesc.
#26 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 13 June 2011 - 09:46 PM
Vezi postareaGarorich, la 10 June 2011 - 06:52 PM, a spus:
salut,
diam. fara camasa este 36mm
diam. cu camasa este 39mm si 43mm deoarece camasa nu este axisimetrica
diam. axului este 3,17mm
Sper sa te ajute la ceva
#27 Useril este offline   Richard 59
  • ex garorich
  • Postari: 138
Postat 14 June 2011 - 03:38 PM
Vezi PM pentru Team Orion.Multumesc.
#28 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 21 June 2011 - 06:32 PM
Vezi postareaVanPulov, la 15 May 2011 - 09:24 PM, a spus:
pret 80 ron
motor T
Weight: 63g
Idle Current: 1.9
Kv: 1600
Shaft: 3mm Diameter
Max Load: 25A
pret 50 ron
TowerPro Brushl
aripa 70 ron
motor 50 ron
impreuna 100 ron
avion jucarie X3D 90 ron
Aceasta postare a fost editata de VanPulov: 21 June 2011 - 06:34 PM
#29 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 21 June 2011 - 06:37 PM
update
18. Z-Drive 30 ron
34. elice pentru termice 10x6 10 ron
la pachet articolele nr 27-34 ----------330 ron
#30 Useril este offline   VanPulov
  • Postari: 503
  • Interests:navo
Postat 08 July 2011 - 07:52 PM
update
18. Z-Drive 30 ron
la pachet articolele nr 27-34 ----------330 300ron
