Modelism - RHC Forum: Probleme cu castile (in engleza!)... - Modelism - RHC Forum
Probleme cu castile (in engleza!)... Interferente, actioneaza ca o antena?
#1 Useril este offline   aCkEr
  • Postari: 2
  • Inregistrat: 16-November 04
  Postat 17 November 2004 - 12:13 AM
Salutare lume...
[EDIT dupa vreo 10 minute]:
Hai ca am dat cu bata in balta... Eram pe mai multe forumuri in acelasi timp si am citit ceva care cat de cat avea legatura cu problema mea. Asa ca m-am inscris pe forum (se pare ca nu pe cel care trebuia) si am posta. Dar se pare ca wrong place! Daca totusi aveti chef cititi...
MEA CULPA
[/EDIT]
Uite ca am ajuns si pe forumul asta. De ceva vreme colind diverse forumuri in speranta ca o sa dau de cineva cu cunstiinte tehnice solide care sa ma poata ajuta si pe mine. Sunt obosit si de aceea nu o sa mai traduc textul in romana (cred ca 99% din voi stiti engleza si nu imi place sa fac un lucru de doua ori). M-am uitat si prin Regulament si n-am vazut nimic de genul "Doar in romana" (si RHC=Romania Hobby Center).
Sper ca am postat unde trebuie, daca nu, mutati, stergeti, faceti ce credeti de cuviinta... dar ajutati-ma si pe mine... ca nimeni niciodata nu-mi da nimic.
Si acum la treburi mai serioase:
I bought three months ago an AKG 66 Headphone (with a 3 metter cable) and i have a problem with "background" noise. Even if i don't play music I hear sounds (no, i am not that paranoid http://www.rhcforum....tyle_emoticons/default/wink.gif ) (similiar like you hear when listening to an AM Radio frequency, but not that loud). If I start playing some music I can cover that noise but it is really annoying, and i definetly don't want this as a solution. This noise starts at the same time as i turn my PC on.
I've noticed that if I plug out the headphones and insert back the cable in the soundcard there is no noise for about 10, (15 ,20?) seconds. After that, it starts again. ( if i start playing music louder, it starts exactly that moment) Both left and right phones are affected, but on the right side is a more pronunced.
This noise is influenced by moving the mouse or scrolling windows, moving windows etc. Monitor does not create this because this happens even if I turn it off. My sound card is an AC97 onboard (i know it rocks :D ). Could the video card interfere with the soundcard?
I thought about current on my computer's case. I've connected that case to a pipe to be sure that is grounded. No effect! I've removed my harddrive, cd-rom, I've also took out my motherboard so it won't make contact with computer's case. Still no difference.
I've tested headphones with my cd-player and it sounds ok. There is a small noise but nothing compared with this. I have that noise with all headphones.
I thought it may help setting everything (like modem, aux, mic etc) to mute in widows (and linux) but that didn't helped.
I've contacted my motherboard manufactuer but they couldn't help me. I've rewritten my BIOS, but guess what? NOISE again. I've posted my message on different computer forums but no one gave me any help.
I've noticed that if I keep about 20-30 centimeters of headphone's cable perfectly(as much as i can) straight there is almost no noise.
I've tried to tell you anything i know about the problem, but if you need more info please ask. I need a filter that would allow only low frequencies to pass? (i don't know how you call that in English).
Hope someone has a clue...
regards,
acker
PS. It looks like my ethernet card influence this although does not creates it.
Mainboard: CM33-TC
CPU Celeron Copermine (1Ghz)
128 + 64 SDRam
8 MByte shared onboard Trident Cyberblade i/1 video
1 Realtek Ethernet 10/100 card
240 W power supply
Latest BIOS available installed.
Mai multe informatii? just ping me... (o sa mai trec pe aici ca vad ca nu am optiune sa imi trimita mail automat cand primesc un replay :D SAU?)
[EDIT:]
Am gasit si optiunea cu mailu.. :D
Aceasta postare a fost editata de aCkEr: 17 November 2004 - 12:23 AM
Postat 17 November 2004 - 05:56 AM
e clar ca ai interferente
1.cablul de la casti in loc sa fie coaxial calumea e "varza" si de aceea apare inductie pe el(incearca sa schimbi cablul)
2.arunca placa de baza.
3.i-atzi un soundcard separat
4.i-atzi niste casti ca lumea
5.oricare din cele 4 variante de mai sus sau chair combinatii intre ele. http://www.rhcforum....tyle_emoticons/default/biggrin.gif
Aceasta postare a fost editata de SILVIU66: 17 November 2004 - 06:05 AM
#3 Useril este offline   LooSeR
  • Postari: 1108
  • Inregistrat: 14-May 04
Postat 17 November 2004 - 07:01 AM
1. Fa test la un prieten .. daca se aude bine schimba placa de sunet ... daca nu castile !
Placa de sunet iti recomand ... de la Yamaha sau audygit
Galeria mea
#4 Useril este offline   woodpecker
  • Postari: 90
  • Inregistrat: 12-May 04
Postat 17 November 2004 - 09:35 AM
clar...placa de sunet.
btw...tot asa am citit undeva ca ar avea rezultate invelirea placii de sunet cu o hartie si apoi in staniol legat la carcasa PC, dar daca ai sunet onboard......asta e.
AKG din cate stiu eu sunt casti meseriase......deci nu cred ca ar folosi aia un cablu "varza", poate doar daca sunt imitatii turcesti.
#5 Useril este offline   degetzica
  • Postari: 152
  • Inregistrat: 17-February 03
Postat 17 November 2004 - 12:14 PM
Din ce am citit despre AC97 astea nu sunt placi de sunet, la propriu. Sunt niste Audio Codec -uri. Folosesc o parte din puterea de calcul a procesorului pentru a-ti da sunetul.
Am avut o placa cu asa ceva si baga un bazait atunci cand miscam cursorul sau ferestrele.
Probleme la placile cu AC o sa tot gasesti. E o solutie mai ieftina. Se pare ca e si de la placa video.
Dar gasesti si placa de sunet integrata pe placa de baza, pe PCI. ( placa Intel cu chip Yamaha, de ex. )
Astea sunt bune.
Castile nu au nimic defect. Daca ai probat si cu Cd-player si nu se aude acel zgomot e OK.
Nu stiu la ce te-ar ajuta un filtru de inalte, o sa-ti taie si din semnalul util.
Incearca cu o placa de sunet montata cat mai departe de placa video, dar se pare ca si aceasta e tot integrata pe placa de baza.
Cred ca singura solutie e cea care nu-ti prea convine, scapa de placa de baza cu AC.
Ala Bala Portocala ...
#6 Useril este offline   aCkEr
  • Postari: 2
Postat 17 November 2004 - 01:27 PM
Mersi... in sfarsit cineva spune ceva!
Placa de baza e naspa. Asta e clar. La fel si placa de sunet si video :D. Am calcul de ceva vreme si nu l-am ales eu. Ma descurc cu ce am. Pana acum nu am avut probleme cu placa video sau de sunet ca nu ma joc (jocuri) si nu ma prea interesa puterea. Ce am imi este de ajuns.
SILVIU66: nu stiu cat de naspa sunt castile... am dat peste 1 mil. pe ele. Firma e buna si castile mi-au fost recomandate de niste tipi care se pricep cat de cat.
woodpecker: sau o pung electrostatica (dintr-aia cu care vine HDD sau placa de baza)
Am incercat cu o placa de sunet PCI pusa la mine in calc si nu am avut asa zgomot. Dar, din pacate placa era destul de crappy si daca dadeam totul la maxim se auzea... sa zicem ca nu se auzea. Tot la cumpararea unei placi de sunet cred ca voi recurge, desi nu prea vreau acest lucru. Pentru ca: sunt la faculta la Politehnica la Automatica si Calculatoare (an2) si daca tot sunt acolo ma astept sa fac si eu ceva mai tehnic nitel... sa nu fac faculta si doar sa schimb ceva. Partea cu filtru era doar o idee... nu prea stiu eu ce frecventa au porcariile astea. As fi vrut sa vorbesc cu cineva chiar stie electronica si electrotehnica. Am mai intrebat si pe niste asistenti una alta... dar nu prea am avut noroc. Unul mi-a zis ca s-ar putea sa fie vreun condensator busit. Pe profesori mi-e cam urat sa ii intreb ca nu par prea dornici de chestii de genul asta. Poate o sa ii intreb. sau nu? Offf..
E foarte usor sa zici sa-mi schimb placa de baza, de sunet etc. dar nu am timp. And you all know tims is money :wub:. Cu placa de sunet hai ca ma descurc.
Si sa nu mai deschid inca un thread: am mai cautat pe net si deci sa nu ma trimiteti la google, dar tot nu mi-e foarte clar. Puteti sa imi spuneti care e treaba cu letcon (parca asa ii zice) / ciocan / pistol de lipit. Cu ultimele doua cam am idee, cu primu mai putin. La ce putere (W) lucreaza astea? Pentru ce e bun fiecare in parte? Daca vreau sa imi fac o schema electronica pe o placa (am uitat cum ii zice :( ) ce imi trebuie din astea. Si ce la ce putere sa fie? Pana acum cateva zile credeam ca pistolul de lipit e mai de finete decat ciocanul de lipit, dar se pare ca ma insel. Sau? Linkuri, explicatii... anything is good. Ce e bun si pentru ce?
Vreau sa imi iau si un aparat de masura. Am gasit unul ieftin (DT830B) la
http://www.telecomenzi.ro/index.php?offset...isplay&pid=1647
(al treilea din lista) (poza aici http://www.telecomen...age.php?id=1647 ). In TM l-am vazut intr-un magazin la vreo 370.000, dar pe net l-am gasit la vreo 180.000. Ce ziceti: e bun? Sunt incepator spre foarte incepator, si de aceea nu cred ca o sa am nevoie de altceva. Sugestii?
--acker
#7 Useril este offline   LooSeR
  • Postari: 1108
Postat 17 November 2004 - 01:51 PM
Vreau sa iti zic !
Daca nu vrei sa dai bani pe o placa super scumpa - audygit iati o placa de SUnet YAMAHA una este cam 150.000 - 300.000 lei
este FOARTE buna
Galeria mea
#8 Useril este offline   One
  • Postari: 192
  • Inregistrat: 22-July 03
Postat 17 November 2004 - 04:38 PM
Castile sunt de foarte buna calitate. Subscriu si eu la sfaturile de a-ti lua o placa ceva mai buna. La mine se intampla fenomenul invers: cand aveam calculatorul oprit, se auzea zgomot, prindea posturi AM, iar la pornire disparea. Problema s-a remediat simplu, prin montarea unor rezistente de 100 ohmi in paralel pe fiecare intrare a boxelor. Incearca sa faci si tu asta. Construiesti un adaptor su 2 mufe, (mama+tata) si pe firul dintre ele sau chiar in interiorul unei mufe, pui cate o rezistenta intre fiecare canal si masa. Daca nu dispare astfel, atunci aceste rezistente ar trebui montate undeva pe placa de sunet, cam pe unde ar fi niste "intrari" audio, asa ca tot solutia cu alta placa e mai buna.
Pentru a inventa ceva ai nevoie de o imaginatie bogata si o gramada de gunoi. Thomas A. Edison (1847 - 1931)
