Modelism - RHC Forum: TEMA DE CASA! - Modelism - RHC Forum
  • 24 Pagini +
TEMA DE CASA! Sau cum sa construiesti un aeromodel!
#121 Useril este offline   Picatot
  • Postari: 839
  • Inregistrat: 05-June 04
Postat 22 November 2004 - 01:12 PM
exact!
Sa nu existe confuzii!
#122 Useril este offline   TRazvan
  • Postari: 83
  • Inregistrat: 14-August 04
Postat 22 November 2004 - 08:50 PM
Gicosu, fuzelajul e plin? Sau e facut din placi?
Razvan
Tzac, pac, bag la sac!
#123 Useril este offline   gicosu
  • Postari: 1849
  • Inregistrat: 08-May 03
Postat 22 November 2004 - 10:21 PM
Nu inteleg prea bine intrebarea ta,dar incerc sa-ti raspund.Intre panourile de pfl am introdus bucatile de polistiren,in cazul asta,da este plin[cu polistiren].
#124 Useril este offline   Valteras
Postat 23 November 2004 - 08:53 AM
Gicosule, uite raspuns despre roate:
Hi Florin,
now I'm back home and I can give you more information's
about my wheels: They are produced by AIRTOP, Made in
France. If you have problems to get them: I have a
wholesale-shop in Swiss, where I can order them for you.
Unfortunately I cannot find them online. Perhaps you have
more luck.
Bye
PHILIPP GARDEMIN
#125 Useril este offline   gicosu
  • Postari: 1849
Postat 24 November 2004 - 07:43 PM
alterasule,uite raspunsul meu,am comandat la Sunshine Modell 'ROATELE' si ma costa de te ustura in cur, vreo 31 euro bucata+ TVA+transport=in jur de 80 euro doua bucati.Daca stie cineva mai ieftin il rog sa-mi spuna si mie!Cam asa arata o roata.
#126 Useril este offline   SILVIU66
Postat 27 November 2004 - 02:34 PM
si mandria mea cea noua
aici era in lucru
#127 Useril este offline   SILVIU66
Postat 27 November 2004 - 02:43 PM
aici langa o aripa normala pt a se vedea diferenta de dimensiuni.
va fi dotata cu motor graupner microspeed de 16g ,rec pico de 4g,servo graupner de 7g,si un pack de 33 -50 g (nu m-am hotarata inca daca lipo sau nimh)
un gen de minimodel
#128 Useril este offline   Valteras
Postat 27 November 2004 - 04:26 PM
Bravos Silviule! De la mare la mic, de la mic la mai mic! Sa aibe si Marinarul de cine sa faca bascalie!
Poanta este ca la dimensiunile astea si la vitezele cu care o sa zboare microbul asta al tau, scociul cu care este invelita ii face mai mult rau decat bine! Suprafata aripii era bine sa ramana cat mai rugoasa, asa cum iesea din taiere/slefuire. In cazul asta, datorita microturbulentelor cauzate de rugozitatea invelisului, stratul limita are mai multe sanse sa ramana atasat profilului mai mult decat daca suprafata este lisa.
Daca suprafata este lisa si nr. Reynolds este mic (cazul nostru), stratul limita laminar fiind, nu ramane atasat profilului la incidente prea mari. In traducere libera, dracovenia se va angaja mai repede si mai violent. Va trebui zburata cu grija si in viteza.
Daca asta ii va fi comportamentul, poti sa-i pui niste turbularizatoare, mai inspre BA, pe extrados. Poa sa fie niste straifuri de scoci mai gros (0,2-0,5 mm), late de fo 5-10 mm, pe linia de 10-15%, sa zicem. Poa sa fie si un fir de nailon de pescuit sau chiar si o antena de rx, lipita sub un scoci (evident ca va trebui sa pui ceva si pe celalata aripa, sa fie simetrica).
Daca cumva ai lucrat neingrijit la aplicarea scociului si a iesit incretit, asta de fapt s-ar putea sa-i faca bine si deja sa ai aripa "turbularizata". Mai vezi tu, ca io numa' chibitzez!
#129 Useril este offline   SILVIU66
Postat 27 November 2004 - 07:56 PM
merci valterashule
scociul din pacate a iesit destul de bine intins,asa ca o sa fac treaba cu antena de receptie.
oricum e un experiment asta mica,ca intre timp fac si doo muuult mai mari de 1,5 m.
apropos aia a ta de sta agatata de tavanu la ceelo ce anvergura are? (adikatelea incape aripa de 1,5 m in ceelo?)
p.s. sa vezi ce bascalie face luni marinaru :(
#130 Useril este offline   antic
  • Postari: 108
  • Inregistrat: 01-August 04
Postat 29 November 2004 - 12:52 AM
Picatot.... de ce dimensiuni e (SPITFIRE) al tau ..... sha poi spuneai de o matrita dupa finisarea modelului ..
din ce material o sa fiie matrita ? ... shi bafta :mellow:
sus in ceruri se zice ca cel ce na zburat nici na trait... :)
  • Fisier atasat  iac55.TIF (95.91K)
#131 Useril este offline   antic
  • Postari: 108
Postat 29 November 2004 - 01:04 AM
BROWSE de mai sus shi inclusiv asta e planul la IAK 3 pentru lupte .. pe el in fac eu acu ...
#132 Useril este offline   Valteras
Postat 29 November 2004 - 09:13 AM
SILVIU66, la 27 Nov 2004, 19:56, a spus:
Aia a mea este clasica si are fo 1250 mm anv. (wings cut by Grig). Incape fest pe tavanu lui Cieloooo, chiar cu wingleturile pe el. Io cred ca ar incapea si una de 1,5 m, mai chinuit ce e drept, dar musai cu wingleturile date jos si aripa coborata mult inspre luneta. Fa intai un mockup de carton si vezi cum stai cu spatiul in "hangar". Este prima etapa de predimensionare a aeronavei, in orice proiect importand de super aeronava revolutionara. Sa nu patesti ca si niste cretini ce s-au apucat sa faca nu mai stiu ce super avion de pasageri (sau cargo) si dupa ce l-au incropit, s-au trezit ca nu poa sa-l scoata din hangar din cauza verticalului, care era mai inalt decat usa hangarului, he, he...
@ Antic:
Uite, ti-am "lipit" planurile alea ale lui IAK 55 si le-am salvat .jpg, ca sa le vada toata lumea, fara sa le mai faca download. Sunt in rezolutie mica, sa le putem pune aici direct. Care le vreti in rez. mai mare (originalele erau in 600 dpi - nejustificat de mult), vi le trimit "acasa" cu dedicatie, numa sa ziceti pe ce adresa. Oricum, nu sunt super lizibile, dar merg, ca sa va faceti o idee.
#133 Useril este offline   IlPadrino
  • Postari: 1437
  • Inregistrat: 17-January 04
Postat 29 November 2004 - 07:27 PM
unii fac lucruri minunate, iar io din resturi incerc sa fac lucruri care sa functioneze.
poate ca era mai bine sa postez la cel mai eftin aeromodel,
in mod clar bate la costuri aripa delta, dar cre'ca merge shi aici
pe scurt poza unui planor construit efectiv din resturi
Aceasta postare a fost editata de IlPadrino: 29 November 2004 - 07:28 PM
0728.26.93.19
#134 Useril este offline   IlPadrino
  • Postari: 1437
Postat 29 November 2004 - 07:34 PM
datele tehnice sunt:
2 micro servo
1 micro receptor
1 micro accu pack (da de ala de se gasesc pt telefoane cordless) inca neprocurat
profil aripa: Ritz 1-30-13 (coordonatele se pot lua din profili - chiar shi demo)
initial a fost conceput pt lansarea cu prastia, dar cred ca va fi totusi motorizat ulterior, asta in functzie de pack
0728.26.93.19
#135 Useril este offline   SILVIU66
Postat 02 December 2004 - 04:47 PM
continui si eu cu aripa bimotor care avanseaza
#136 Useril este offline   SILVIU66
Postat 02 December 2004 - 04:49 PM
sa nu mai zica valterashu ca fac numa dalea mici sa faca marinaru bashcalie (oricum face dastai marinar)
tre sa mapuc sa plachez cu balsa
#137 Useril este offline   Alex Baccilu
  • Membru care este
  • Postari: 681
  • Inregistrat: 05-January 03
Postat 03 December 2004 - 09:06 AM
Ce misto arata! Are doua motoare? Cum se rezolva ca amandoua sa traga la fel? Se compenseaza ceva din radiocomanda sau cum? Mi-am pus problema asta de cand am vazut primul bimotor de jucarie.
Boardgame is the future!
#138 Useril este offline   SILVIU66
Postat 03 December 2004 - 09:16 AM
mai multe variante:
-1 regulator de amperaj mai mare cu cablu y
-2 regulatoare separate legate la doua canale diferite in receptor pe stickul din stanga,sa poti opri brusc unul din motoare si sa-l dai pe celalalt in full sa faca aripa ca toate alea pe sus :wub: (asta este emanatzia lui valterash,care are idei bune care este ele).am intzeles tot de la el ca s-a mai facut asa ceva si a fost super
#139 Useril este offline   SILVIU66
Postat 03 December 2004 - 09:43 AM
si trenu de aterizare ,care de fapt foloseste la aruncarea aripei-taiat de la protectia unei masini de spalat asa cum vine ea in cutie
#140 Useril este offline   Picatot
  • Postari: 839
Postat 03 December 2004 - 12:01 PM
Sa revenim la povestea Spitului:
A fost odata ca nici o data a fost un avion mare si frumos!
Cica terminat si "infasat" cu ce s-a gasit :wub:
#141 Useril este offline   Picatot
  • Postari: 839
Postat 03 December 2004 - 12:03 PM
Beeep... sii de poza:
#142 Useril este offline   Picatot
  • Postari: 839
Postat 03 December 2004 - 12:05 PM
Gata de zbor la inceputul unei zile de iarna:
#143 Useril este offline   Marinaru
Postat 03 December 2004 - 12:06 PM
OOOO...felicitari...avad in vedere experienta de care ne-ai povestit, nu pot sa nu te felicit...a iesit el cam "omida" dar e gata de zbor si e chiar zburabil...SA NE POVESTESTI!
#144 Useril este offline   Picatot
  • Postari: 839
Postat 03 December 2004 - 12:07 PM
Si dupa ce s-a comportat superb in aer la aterizare s-a intimplat NENOROCIREA:
#145 Useril este offline   Picatot
  • Postari: 839
Postat 03 December 2004 - 12:08 PM
Povestea PESTE un ceas!
#146 Useril este offline   Marinaru
Postat 03 December 2004 - 12:10 PM
Priveste partea plina apaharului..aripa si ampenajele au scapat...oricum, un fuselaj mai rigid, imbracat cu balsa se cere!
#147 Useril este offline   Picatot
  • Postari: 839
Postat 03 December 2004 - 12:26 PM
Nu e suparare si nici nenorocire. http://www.rhcforum....tyle_emoticons/default/tongue.gif
Dar sa o luam cu inceputul:
- Motorizare seria 600 cu reductor planetar;
- servo normale
- accu 8x1200
Dupa citeva reglaje sumare la sol sa ridicat frumusel, adica neasteptat de bine fiindca TOATA LUMEA DADEA cu poci http://www.rhcforum....tyle_emoticons/default/tongue.gif .
Zborul s-a desfasurat la viteza destul de mica fara incidente.
@ Marinaru ai avut dreptate cu usoara tendinta de ridicare! corijata din servo!
A avut de asemeni o tendinta de angajare pe o aripa, fara anuntare prealabila, la o manevra mai brusca!
Incidentul s-a produs aproape de aterizare cind a "SARIT ELICEA" si nu l-am mai putut controla, eram sub viteza critica.
Deci concluzii:
1. Trebuie micsorata sarcina alara: Majorata aripa macar la 1500 mm;
2. Trebuie intarit fuselajul (bagheta +acoperire cu balsa) desi tare mi-ar fi placut o "Fibra de carbon" d-a lui ANTIC da devine prea greu;
Astept si alte sfaturi de la voi!
NU DISPER, caci il consider UN MARE PAS IN FATA! si o prima experienta INTERESANTA
@TATHsme: Dupa cum iti spuneam NU TOT ce zboara se si maninca, http://www.rhcforum....tyle_emoticons/default/tongue.gif, scuze aterizeaza cu bine!
Aceasta postare a fost editata de Picatot: 03 December 2004 - 03:17 PM
#148 Useril este offline   Valteras
Postat 03 December 2004 - 02:02 PM
SILVIU66, la 3 Dec 2004, 09:16, a spus:
2 regulatoare separate legate la doua canale diferite in receptor pe stickul din stanga,sa poti opri brusc unul din motoare si sa-l dai pe celalalt in full sa faca aripa ca toate alea pe sus http://www.rhcforum....tyle_emoticons/default/biggrin.gif (asta este emanatzia lui valterash,care are idei bune care este ele).am intzeles tot de la el ca s-a mai facut asa ceva si a fost super
Nuuuuu, nu este de la mine citire. E drept ca ma gandeam mai demult sa fac o aripa bimotor cu motarele (controlerele) mixate, dar nu am demarat si pana atunci a facut una Manel & Grig & Co. Era fuuuutere pe sus!
@Picatot: Superfain Spitul! Pacat de "inconvenient". Sa ne povestesti! Io deja am niste... prejudecati!
Las' ca-l faci tu din nou, da, cu motor mai mic, poate 480 cu reductor, ca la cum arata, 600 cu reductor este/pare mult mai mult decat ii trebe.
In rest, CAVEAT: aripa eliptica + amp. oriz mic = bubu!
#149 Useril este offline   SILVIU66
Postat 03 December 2004 - 04:55 PM
si forma finala cu motoare si elici montate...
extrados
#150 Useril este offline   SILVIU66
Postat 03 December 2004 - 04:57 PM
si intrados;mai tre sa ingrop bagheta de brad
  • 24 Pagini +
