Rulmenti pentru heli (si auto) ieftin si repede
Postat 21 June 2010 - 02:50 PM
http://www.rcbearings.co.uk/
transportul este 1 lira, rulmentii sunt cam 0.7 lire. Am facut comanda joi, luni ii aveam in cutia postala. Dupa cum se vede din poza pe ei ii costa transportul spre 1,5 lire. Au toti rulmentii ca dimensiuni si tip. Recomand cu entuziasm. Stefan
Postat 22 June 2010 - 06:32 AM
stiganas, la Jun 21 2010, 03:50 PM, a spus:
Ce marca sint rulmentii?
Multumesc,
John
Postat 22 June 2010 - 03:36 PM
Super preturile mai ales transportul,iar faptul ca sunt toate tipurile de rulmentii este super
Multumim de link domnule moderator
Toata stima
O aripa otravita de 1m
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
Postat 22 June 2010 - 09:47 PM
Hi,
Therer is no brand name for my bearings.
I source them from a company that makes their own bearings, but all
boost their inventory with those made by others.
So its a mix, but they are all at least ABEC3 and to date not had any
bad feedback about the quality.
I have a few national drivers running them to good effect.
Any branded bearings would cost much more.
Colin
www.RCbearings.co.uk
John, la Jun 22 2010, 07:32 AM, a spus:
Multumesc,
John
Postat 23 June 2010 - 09:29 AM
Veniti fratilor la curse, acolo e distractia
Fxracing driver :
Team Associated Romania/ Clubul Sportiv FxracingMS/Team Associated B6/B64D/TC6/SC8 Tekin RS Pro/Sanwa/Reedy Brushless
WWW.FXRACINGMS.RO official club
Postat 23 June 2010 - 08:31 PM
BogdanStancu, la Jun 23 2010, 01:34 PM, a spus:
Atasez un fisier cu tolerantele, asa cum sunt descrise de SKF.
daca stiganas ii testeaza si zice ca sunt buni bag si eu o comanda ..
SKf au super calitate dar 2 rulmenti de trex 450 au fost 106 ron
Postat 23 June 2010 - 09:24 PM
- din neatentie/prostie un rulment l-am comanda gresit, 10 in loc de 11 diametru exterior
- am descoperit ca nu rulmentii erau dusi ci axul motorului, axul s-a invartit in rulment. s-a frecat, s-a subtiat Drept urmare si cu rulmentul nou tot prost merge.
- am intors axul si acum portiunea subtiata nu e in dreptul nici unui rulmemt dar am stripuit surubelul care fixa axul in clopotul motorului asa ca am pus axul in clopot cu CA (intra oricum foarte greu) sper sa tina dar nu sunt prea sigur
- lovitura de gratie - defapt nu vreau sa mai folosesc acest motor - am cumparat si e pe drum un motor similar de la HK cu KV de 1300. Asta va face sa am un headspeed mai mic, nu fac 3d nu am nevoie de turatie turbata in head.
Am pus si motorul de Protos (cu Kv 820) si pinion de 13 in HK500. Heli se ridica dar turatia e prea mica si e ca o gelatina. Se poate rezolva usor cu un pinion de 15-17T
Rulmenti SKF sunt aici in Bucuresti, multi dintre ei pe stoc la www.bad.ro Au sediul chiar pe langa terenul de zbor din Chitila. Un rulment SKF mic e cam 10 RON. E o doamna amabila la vanzari si da toate informatiile posibile prin telefon.
nen77, la Jun 23 2010, 09:31 PM, a spus:
Postat 24 June 2010 - 09:42 AM
stiganas, la Jun 23 2010, 10:24 PM, a spus:
Ai idee daca au si rulmenti ceramici ? As vrea sa ii schimb la T-REX 600 ca deja am joc in head dupa 10 zboruri in regim de hover !
Sau normali nu neaparat ceramici caci sigur SKF-ul este mai bun decat Align !
Am incercat sa caut On Line dar nu gasesc codul lor 6800ZZ si nici dupa dimensiuni 10X19X5 ! si nici nu stiu la ce tip sa caut !
Aceasta postare a fost editata de REAL DESIGN: 24 June 2010 - 09:52 AM
Postat 24 June 2010 - 10:20 AM
10x19x5 (MS) Bearing (x1) 6800zz
£0.80
Ceramici nu am vazut la dimensiunea asta. Trebuie intai sa vezi daca intradevar sunt rulmentii problema sau e altceva.
REAL DESIGN, la Jun 24 2010, 10:42 AM, a spus:
#11
Postat 24 June 2010 - 10:52 AM
stiganas, la Jun 24 2010, 11:20 AM, a spus:
£0.80
Vreau sa schimb si Metal Main Shaft Bearing Block T-REX 600 caci ai mei sunt din plastic si este posibil ca rumentul sa aiba joc . Se misca pe zona celui de sus dar asta inseamna ca si cel de jos de tot are joc caci daca axul trece prin ceilalti doi ( jos si mijloc ) ar fi suficient ca sa nu simt joc cand misc manual ( in zbor nu ar rezista doar in 2 puncte )
Ceramici am vazut la Fast-Lad dar se pare ca trebuie sa cumperi niste Main Shaft Block de la alt producator facute CNC care sunt foarte scumpe.
P.S.
Eu vroiam sa stiu daca astia de la SKF din Chitila au ce imi trebuie mie !
#12
Postat 24 June 2010 - 11:20 AM
Pentru SKF, da un telefon la bad in chitila si afli, e treaba de 5 minute, dupa aceea ne spui si noua daca au pe stoc si cat costa.
REAL DESIGN, la Jun 24 2010, 11:52 AM, a spus:
P.S.
#13
Postat 24 June 2010 - 12:08 PM
P.S.
Am eu de metal,aceiasi problema,in rulmentul de sus am un joc mic dar este,am incercat cu alti rulmenti,aceiasi problema,problema eu zic ca este de la main shaft,am incercat cu perechea lui din punga si aceiasi treaba,dar si cu unul scos de pe heli in primavara cand aveam "tremurici" si nu mai gaseam buba si surpriza cu ala sta perfect pe rulmenti,ocazie cu care am observat ca main shaft-urile cumparate acum de curand au ruginit,ok,ala de pe heli a mai luat aer,dar al doilea a stat cuminte in cutie pana acum,ala original nu are absolut nimic,nici macar o pata,acum ai dau dreptate unui prieten care mi-a spus ca printre produsele "originale" comercializate sunt si facaturi.Incerca daca ai posibilitatea si cu alte main shaft-uri.Scuze de offtopic........stiu ca nu sunt in tema data. :)
FOREVER YOUNG.......
#14
Postat 24 June 2010 - 03:36 PM
bogdyys, la Jun 24 2010, 01:08 PM, a spus:
Multumesc de informatie ! Am sa verific ! ( suportul rulmentilor este din plastic - am sa il schimb cu metal dar nu au la nici un magazin din tara si am oroare de comenzi in afara )
#15
Postat 05 July 2010 - 11:15 AM
Rulmenti SKF se gasesc si la Adeko. Cautati pe net. Aduce in maxim 3 zile orice rulment pe care il produce SKF. Eu numai de aici cumpar rulmenti si pentru T-rex 600 si altele.
#17
Postat 11 July 2010 - 10:46 PM
Champion, la Jul 11 2010, 10:43 PM, a spus:
#18
Postat 14 July 2010 - 10:55 AM
#20
Postat 21 August 2010 - 12:47 PM
rulmentii par de calitate. sa vad cum rezista in timp. 3 zile au facut din Anglia  pana in Roman - Romania. comanda vineri pe la 14 si luni seara i-am gasit in posta cand m-am intors acasa. Foarte rapizi.
planor multiplex cularis
#24
Postat 15 November 2010 - 12:49 PM
Aceasta postare a fost editata de hxa: 15 November 2010 - 12:53 PM
