Modelism - RHC Forum: Rulmenti pentru heli (si auto) ieftin si repede - Modelism - RHC Forum
  • Postari: 8341
Postat 21 June 2010 - 02:50 PM
Am avut nevoie de rulmenti pentru un motor si am gasit :
http://www.rcbearings.co.uk/
transportul este 1 lira, rulmentii sunt cam 0.7 lire. Am facut comanda joi, luni ii aveam in cutia postala. Dupa cum se vede din poza pe ei ii costa transportul spre 1,5 lire. Au toti rulmentii ca dimensiuni si tip. Recomand cu entuziasm. Stefan
  • Imagine atasata: DSCF7179.jpg
#2 Useril este offline   John
  • Postari: 243
Postat 22 June 2010 - 06:32 AM
Vezi postareastiganas, la Jun 21 2010, 03:50 PM, a spus:
Ce marca sint rulmentii?
Multumesc,
John
#3 Useril este offline   ionut EZ
  • Postari: 929
  • Inregistrat: 28-November 09
  • Interests:Modelism
Postat 22 June 2010 - 03:36 PM
Salut
Super preturile mai ales transportul,iar faptul ca sunt toate tipurile de rulmentii este super
Multumim de link domnule moderator
Toata stima
Robbe SZD-54
O aripa otravita de 1m
Radjet 800
Yak 55 Telink
Ansmann Virus 4.1cc
Thunder Tiger E-MTA
Aeroclub Fagaras
  • Postari: 8341
Postat 22 June 2010 - 09:47 PM
Am vorbit cu Colin, proprietarul shop-ului, pare foarte OK si raspunde imediat:
Hi,
Therer is no brand name for my bearings.
I source them from a company that makes their own bearings, but all
boost their inventory with those made by others.
So its a mix, but they are all at least ABEC3 and to date not had any
bad feedback about the quality.
I have a few national drivers running them to good effect.
Any branded bearings would cost much more.
Colin
www.RCbearings.co.uk
Vezi postareaJohn, la Jun 22 2010, 07:32 AM, a spus:
Multumesc,
John
#5 Useril este offline   Fxpower
  • Postari: 1603
  • Inregistrat: 29-March 04
Postat 23 June 2010 - 09:29 AM
Abec 3 este clasa de toleranta a rulmentilor nu marca atentie !!!!!
Imagine postata
Veniti fratilor la curse, acolo e distractia
Fxracing driver :
Team Associated Romania/ Clubul Sportiv FxracingMS/Team Associated B6/B64D/TC6/SC8 Tekin RS Pro/Sanwa/Reedy Brushless
WWW.FXRACINGMS.RO official club
#6 Useril este offline   Flying Kettle
  • Adevaratul ceaun zburator!
  • Postari: 2498
  • Inregistrat: 17-December 02
Postat 23 June 2010 - 12:34 PM
De unde vine ABEC; cam tot de acolo de unde, ISO9000 produce biscuiti.
Atasez un fisier cu tolerantele, asa cum sunt descrise de SKF.
Imagine atasata: clearance.jpg
#7 Useril este offline   nen77
  • --tadadam--
  • Postari: 1567
  • Inregistrat: 08-March 06
Postat 23 June 2010 - 08:31 PM
Vezi postareaBogdanStancu, la Jun 23 2010, 01:34 PM, a spus:
daca stiganas ii testeaza si zice ca sunt buni bag si eu o comanda ..
SKf au super calitate dar 2 rulmenti de trex 450 au fost 106 ron
West Hobby Team
  • Postari: 8341
Postat 23 June 2010 - 09:24 PM
De la mine nu o sa vedeti teste prea curand. Eu am luat rulmentii pentru motorul de HK500 dar am intrat in urmatoarele probleme:
- din neatentie/prostie un rulment l-am comanda gresit, 10 in loc de 11 diametru exterior
- am descoperit ca nu rulmentii erau dusi ci axul motorului, axul s-a invartit in rulment. s-a frecat, s-a subtiat Drept urmare si cu rulmentul nou tot prost merge.
- am intors axul si acum portiunea subtiata nu e in dreptul nici unui rulmemt dar am stripuit surubelul care fixa axul in clopotul motorului asa ca am pus axul in clopot cu CA (intra oricum foarte greu) sper sa tina dar nu sunt prea sigur
- lovitura de gratie - defapt nu vreau sa mai folosesc acest motor - am cumparat si e pe drum un motor similar de la HK cu KV de 1300. Asta va face sa am un headspeed mai mic, nu fac 3d nu am nevoie de turatie turbata in head.
Am pus si motorul de Protos (cu Kv 820) si pinion de 13 in HK500. Heli se ridica dar turatia e prea mica si e ca o gelatina. Se poate rezolva usor cu un pinion de 15-17T
Rulmenti SKF sunt aici in Bucuresti, multi dintre ei pe stoc la www.bad.ro Au sediul chiar pe langa terenul de zbor din Chitila. Un rulment SKF mic e cam 10 RON. E o doamna amabila la vanzari si da toate informatiile posibile prin telefon.
Vezi postareanen77, la Jun 23 2010, 09:31 PM, a spus:
  • R.D.
  • Postari: 5482
Postat 24 June 2010 - 09:42 AM
Vezi postareastiganas, la Jun 23 2010, 10:24 PM, a spus:
Ai idee daca au si rulmenti ceramici ? As vrea sa ii schimb la T-REX 600 ca deja am joc in head dupa 10 zboruri in regim de hover !
Sau normali nu neaparat ceramici caci sigur SKF-ul este mai bun decat Align !
Am incercat sa caut On Line dar nu gasesc codul lor 6800ZZ si nici dupa dimensiuni 10X19X5 ! si nici nu stiu la ce tip sa caut !
Aceasta postare a fost editata de REAL DESIGN: 24 June 2010 - 09:52 AM
  • Postari: 8341
Postat 24 June 2010 - 10:20 AM
http://www.rcbearings.co.uk/index.php?main...products_id=349
10x19x5 (MS) Bearing (x1) 6800zz
£0.80
Ceramici nu am vazut la dimensiunea asta. Trebuie intai sa vezi daca intradevar sunt rulmentii problema sau e altceva.
Vezi postareaREAL DESIGN, la Jun 24 2010, 10:42 AM, a spus:
  • R.D.
  • Postari: 5482
Postat 24 June 2010 - 10:52 AM
Vezi postareastiganas, la Jun 24 2010, 11:20 AM, a spus:
£0.80
Vreau sa schimb si Metal Main Shaft Bearing Block T-REX 600 caci ai mei sunt din plastic si este posibil ca rumentul sa aiba joc . Se misca pe zona celui de sus dar asta inseamna ca si cel de jos de tot are joc caci daca axul trece prin ceilalti doi ( jos si mijloc ) ar fi suficient ca sa nu simt joc cand misc manual ( in zbor nu ar rezista doar in 2 puncte )
Ceramici am vazut la Fast-Lad dar se pare ca trebuie sa cumperi niste Main Shaft Block de la alt producator facute CNC care sunt foarte scumpe.
P.S.
Eu vroiam sa stiu daca astia de la SKF din Chitila au ce imi trebuie mie !
  • Postari: 8341
Postat 24 June 2010 - 11:20 AM
Sanse mari ca jocul sa fie din main shaft bearing block daca sunt din plastic, asa am avut si eu la HK500 si aveau joc serios. La cat si cum ai zburat tu cu Trex 600 nu cred ca e ceva uzat in el.
Pentru SKF, da un telefon la bad in chitila si afli, e treaba de 5 minute, dupa aceea ne spui si noua daca au pe stoc si cat costa.
Vezi postareaREAL DESIGN, la Jun 24 2010, 11:52 AM, a spus:
P.S.
#13 Useril este offline   bogdyys
  • Postari: 531
  • Inregistrat: 20-October 08
Postat 24 June 2010 - 12:08 PM
P.S.
Am eu de metal,aceiasi problema,in rulmentul de sus am un joc mic dar este,am incercat cu alti rulmenti,aceiasi problema,problema eu zic ca este de la main shaft,am incercat cu perechea lui din punga si aceiasi treaba,dar si cu unul scos de pe heli in primavara cand aveam "tremurici" si nu mai gaseam buba si surpriza cu ala sta perfect pe rulmenti,ocazie cu care am observat ca main shaft-urile cumparate acum de curand au ruginit,ok,ala de pe heli a mai luat aer,dar al doilea a stat cuminte in cutie pana acum,ala original nu are absolut nimic,nici macar o pata,acum ai dau dreptate unui prieten care mi-a spus ca printre produsele "originale" comercializate sunt si facaturi.Incerca daca ai posibilitatea si cu alte main shaft-uri.Scuze de offtopic........stiu ca nu sunt in tema data. :)
FOREVER YOUNG.......
#14 Useril este offline   REAL DESIGN
  • R.D.
  • Postari: 5482
Postat 24 June 2010 - 03:36 PM
Vezi postareabogdyys, la Jun 24 2010, 01:08 PM, a spus:
Am eu de metal,aceiasi problema,in rulmentul de sus am un joc mic dar este,am incercat cu alti rulmenti,aceiasi problema,problema eu zic ca este de la main shaft,am incercat cu perechea lui din punga si aceiasi treaba,dar si cu unul scos de pe heli in primavara cand aveam "tremurici" si nu mai gaseam buba si surpriza cu ala sta perfect pe rulmenti,ocazie cu care am observat ca main shaft-urile cumparate acum de curand au ruginit,ok,ala de pe heli a mai luat aer,dar al doilea a stat cuminte in cutie pana acum,ala original nu are absolut nimic,nici macar o pata,acum ai dau dreptate unui prieten care mi-a spus ca printre produsele "originale" comercializate sunt si facaturi.Incerca daca ai posibilitatea si cu alte main shaft-uri.Scuze de offtopic........stiu ca nu sunt in tema data. :huh:
Multumesc de informatie ! Am sa verific ! ( suportul rulmentilor este din plastic - am sa il schimb cu metal dar nu au la nici un magazin din tara si am oroare de comenzi in afara )
#15 Useril este offline   Mag
  • Postari: 140
  • Inregistrat: 10-June 08
  Postat 05 July 2010 - 11:15 AM
Rulmenti SKF se gasesc si la Adeko. Cautati pe net. Aduce in maxim 3 zile orice rulment pe care il produce SKF. Eu numai de aici cumpar rulmenti si pentru T-rex 600 si altele.
T-rex 600E Scale
Comeback 5000B GAS
Futaba 9C
dj nunta
#16 Useril este offline   Champion
  • Postari: 16
  • Inregistrat: 27-December 06
Postat 11 July 2010 - 09:43 PM
Se pare ca RCBEARINGS nu mai poate fi accesat! La voi merge???
#17 Useril este offline   stiganas
  • Postari: 8341
Postat 11 July 2010 - 10:46 PM
Acu merge.
Vezi postareaChampion, la Jul 11 2010, 10:43 PM, a spus:
  • Postari: 8341
Postat 14 July 2010 - 10:55 AM
Dat comanda luni pe la ora 14, rulmenti in cutia postala miercuri pe la 12. Mai bine de atat nu cred ca se poate.
#19 Useril este offline   morph
  • Postari: 953
  • Inregistrat: 18-May 08
Postat 14 July 2010 - 12:53 PM
Damn, that was fast...
#20 Useril este offline   firedragon
  • Postari: 502
  • Inregistrat: 04-January 09
Postat 21 August 2010 - 12:47 PM
votez si eu ok pt rcbearings.
Imagine atasata: DSC090670.jpg
rulmentii par de calitate. sa vad cum rezista in timp. 3 zile au facut din Anglia  pana in Roman - Romania. comanda vineri pe la 14 si luni seara i-am gasit in posta cand m-am intors acasa. Foarte rapizi.
Videoclipurile mele Spektrum DX8
planor multiplex cularis
)Imagine postata
#21 Useril este offline   cornel parscov
  • Postari: 550
  • Inregistrat: 05-April 09
Postat 23 August 2010 - 10:51 PM
voi ma faceti sa imi schimb parerea (foarte proasta de altfel) despre posta romana. nu ma indoiesc ca sunt rapizi cei de acolo dar sa mearga treaba asa bine la posta romana ma mira!
* Logo 400 V-Bar
#22 Useril este offline   dramida
  • Postari: 599
  • Inregistrat: 05-November 08
  • Interests:filmari si fotografie aeriana, fpv
Postat 06 September 2010 - 08:03 PM
Uimitor si la mine au venit la fel de prompt.
Comanda data miercuri noaptea, practic joi, a venit in posta ca si plic luni dimineata.
Felicitari RCbearings.
Imagine atasata: rcBearings.jpg
Aceasta postare a fost editata de dramida: 06 September 2010 - 08:03 PM
#23 Useril este offline   morph
  • Postari: 953
Postat 25 October 2010 - 05:34 PM
+1 pt rcbearings
Comandati pe 20, azi 25 gasiti in cutia postala.
#24 Useril este offline   hxa
  • Postari: 95
  • Inregistrat: 05-October 10
  • Interests:Elicoptere, avioane si planoare.
Postat 15 November 2010 - 12:49 PM
Eu iau rulmentii de la rc-bearings.com. Am comandat, de exemplu, setul de upgrade pentru DX7 (4 bucati 4x7x2mm) si mi-a sosit din Arizona in cutia postala intr-o saptamana cu pretul final de 6.98 $. Recomand!
Aceasta postare a fost editata de hxa: 15 November 2010 - 12:53 PM
