Modelism - RHC Forum: Electronica ptr modelisti - Modelism - RHC Forum
Electronica ptr modelisti Linkuri si scheme
#1 Useril este offline   Picatot
  • Postari: 839
  • Inregistrat: 05-June 04
Postat 09 October 2004 - 11:33 AM
Deschid acest capitol in speranta de a unifica macar o parte din linkurile de scheme necesare oricaruia dintre noi:
Scheme 1
Cuprins LINK:
1. Simple charge rate limiter.
Use your wall charger to charge small mA battery packs with this charge rate limiter.
2. Deluxe charge rate limiter.
Use your wall charger to simultaneously charge two small mA packs.
3. Downed plane locator.
Loud buzzer helps you locate your slope plane in the brush or weeds.
4. Another plane locator.
This circuit is easier to build and works great.
5. Precision Receiver Battery Low Voltage Alarm.
Lightweight alarm in your plane warns of impending control failure.
6. Another Receiver Battery Low Voltage Alarm.
Simple, and an use only Radio Shack parts for this alarm.
7. The ULTIMATE Receiver Battery Low Voltage Alarm.
Five parts and no circuit board, low power, light.
8. *SLOPE SHEPHERD Low Voltage Alarm and Plane Locator.
This is the one in most of my ships now.
9."CLONEPAC" memory module for Futaba 8UAF/8UAP
Build a memory module for your transmitter.
10. Battery discharger.
Discharges your receiver NiCad battery to a set voltage, then stops with an alarm.
11. Assembling your own servo connectors.
A tutorial to help you make servo connectors.
12. Making Printed Circuit Boards.
A brief tutorial to get you started making printed circuit boards.
Sa nu existe confuzii!
Postat 09 October 2004 - 09:20 PM
Un loc pe care l-am gasit cautind receptoare cu sinteza de frecventa :
http://hem.passagen....ation/meny.html unde veti da de multe scheme/lucruri interesante chiar daca nu toate sint legate de modelism. Exemplu: teoria bobinelor (inclusiv cele TOKO), oscilatoare cu quartz, emitatoare si receptoare de toate felurile, etc.
Autorul e un radioamator suedez pasionat printre altele si de aeromodelism.
Postat 09 October 2004 - 09:27 PM
Si pentru cunoscatori ai limbii ruse, http://www.rcdesign....us/electronics/ unde gasiti:
1 un ESC revers mic ca putere comandata (rezistenta interna 0,1 ohmi) cu PIC. Schimbati MOS-FET-urile !
2 un receptor FM in 40 Mhz simpla conversie cu MMC3371P, cu pina la 8 canale
3 un modul "MemPAC 64K" pentru Futaba
4 un convertizor de tensiune in comutatie de la 12V la 1,5-2V pentru buji cu filament
5 un cablu interfatza FMS (Pc - statie emisie) cu PIC. Aveti si un link catre FMS 2.0 alpha 8.1
6 un adaptor ptr. Joystik cu ATmel
7 un tahometru meserias cu Atmel si LCD
8 un ESC unisens cu frina ptr SPEED 400, cu PIC
9 un preincalzitor motor (???)
10 un indicator tensiune
11 o alarma simpla (locator) cu PIC. Buna cind pierzi modelul in iarba, cind uiti sa deschizi emitatorul,
sau cind vrei sa vezi daca e ocupat canalul.
(12 un ... piezogiroscop. Stati nu va ambalati. Din pacate nu da nici o documentatie.) :)
p.s. dar asta: http://home.nordnet.fr/~fthobois/ mi se pare "creme a la creme" (vorba unui marocan)
in josul paginii la "retro" sint scheme clasice
Aceasta postare a fost editata de navigator: 09 October 2004 - 10:02 PM
#4 Useril este offline   D3xt3r_Jr.
  • Postari: 1284
Postat 10 October 2004 - 01:48 PM
nene cine ma poate ajuta cu un timer
ori sa imi faca unul
sau am eu un calculator de buzunar care are timer reglabil incorporat problema e ca e touch screen
se poate face sa porneasca timeru cand se ating 2 contacte
#5 Useril este offline   charlie
  • Postari: 765
  • Inregistrat: 31-May 04
Postat 14 October 2004 - 10:02 AM
mai da niste detalii despre timer....
