Modelism - RHC Forum: Adaptor pentru a face balance la baterii 2s pe charger care are mufe d - Modelism - RHC Forum
Adaptor pentru a face balance la baterii 2s pe charger care are mufe d facut in casa sau cumparat de gata
#1 Useril este offline   Gerula
  • Postari: 381
  • Inregistrat: 09-September 08
Postat 06 March 2010 - 09:41 PM
Pornind de la problema proprie (Gaui 200 foloseste baterii 2s, chargerul meu are de la 3s in sus) am cautat pe diferite site-uri de profil un adaptor care sa permita incarcarea bateriilor 2s de la mufa 3s a chargerului. Pana acum nu am gasit, daca stie cineva de unde se poate cumpara un asemenea produs please share :rolleyes:.
Intre timp, pentru cine vrea sa-si faca unul acasa, am gasit aceasta postare:
had same problem TP balancer is 4 pin, Gaui battery is 3pin
I even called thunder power.
any way with there info and a voltmeter I sorted it out.
first you need a female 3pin connector, either look threw some old computer parts (like desolder a motherboard fan 3pin connector.
or do like me and order a adapter from helidirect
http://www.helidirect.com/product_info.php...roducts_id=2978
it has the 3 pin female connector you need . wires are two reds and a black.(the center red would be the Gaui yellow.) clip off the male you only need the female side.
then get a TP 4pin adapter http://www.readyheli....p_p/tp4pin.htm
color coded to match TP's info .
I then used volt meter Very carefully not to short anything, and figured out the wires on the Gaui battery.
Black is Negative, Yellow is single cell 3.85v Red two cells 7.69v
if you look tp 205 manual or call tp. there colors are Black neg, white first cell, Blue second cell, Orange third cell .
so you connect:
black to black
Yellow to White (middle)
Blue to red
Orange is simply not used for 2 cell battery. so i clipped it off and put heat shrink over it so it does not short anything .
oh you might also want to get some small heat shrink tubing to make the soldered splices on the 3 wires.
I could not find a ready made adapter.
this image may also help
http://www.techmodelproducts.com/images/ba...connections.jpg
pin 1 black pin 2 white pin 3 blue pin 4 orange (tp colors)
Linkurile de la cele doua magazine nu mai merg, dar ideea e simpla.
Personal cred insa ca numai cumparatul mufelor e mai mare daraua decat ocaua, cel putin in Romania. E posibil sa le aiba pe la Maica Domnului dar deja s-a cam bulit treaba si pe-acolo, ultima oara cand am avut nevoie n-am gasit nici macar niste condensatori destul de banali.
Align T-rex 450 SE V2, Gaui Hurricane 200 V2 FES, Blade MSR,
Starmax He-162, V-Mar Do-335, Parkzone P-51D ultra-micro
Spektrum Dx7
  • Postari: 8341
Postat 06 March 2010 - 09:50 PM
Daca sunt baterii china normale si la fel si incarcatorul adica cu mufa JST-XH pentru egalizare nu ai nevoie de nici un fel de adaptor.
Pur si simplu bagi mufa 2s in portul 3s, ai grija sa fie minusul bateriei la minusul incarcatorului si trebuie sa barbieresti mustatile mufei cu un briceag sa intre - o sa te prinzi cand vrei sa o bagi.
Eu fac asta tot timpul - am un prelungitor 4s si in el bag baterii 3s si 2s.
La alte tipuri de baterii cred ca e la fel dar nu stiu cum arata mufa.
Stefan
#3 Useril este offline   Gerula
  • Postari: 381
Postat 06 March 2010 - 09:58 PM
Mersi de sfat, stiu ca merge, dar barbierind mufa apare riscul sa bagi gresit bateria mai mica, din graba/neatentie.
Ma gandeam la o solutie mai eleganta, poate a vazut cineva vreun asemenea prelungitor/adaptor disponibil comercial.
Spektrum Dx7
  • Postari: 19181
Postat 06 March 2010 - 10:21 PM
Si eu la fel ca stiganas, tocmai pentru ca solutia "elegnta" s-a dus naiba, a avut niste lipituri infecte.
De ce sa introduc inca doua conectoare in circuit care ma pot fenta ?
#5 Useril este offline   Gerula
  • Postari: 381
Postat 06 March 2010 - 10:29 PM
Pai daca bagi prelungitorul (cum face stiganas) nu tot doi conectori in plus ai? Iar daca "barbieresti" mufa de pe charger poti baga bateria mai mica gresit, poate sa iasa firul in timpul incarcarii etc.
Spektrum Dx7
#6 Useril este offline   Gerula
  • Postari: 381
Postat 06 March 2010 - 10:32 PM
In alta ordine de idei, am gasit destul de ieftin mufele cu tot cu fire, trebuie doar facute niste lipituri. Sa vad ce mai gasesc de cumparat de pe site-ul respectiv, sa iasa de un pachet.
Daca vreti careva mate de-astea pentru facut adaptor ziceti aici pe topic, facem o lista etc.
http://www.himodel.com/electric/3-Pin_2S_B...nsion_Lead.html
http://www.himodel.com/electric/4-Pin_3S_B...ale_W_Lead.html
Spektrum Dx7
#7 Useril este offline   Gerula
  • Postari: 381
Postat 08 March 2010 - 04:06 PM
Am gasit la un magazin din Bucuresti si mufe 2s si mufa 4s, asa ca o sa fac un splitter cu care sa pot incarca si doua baterii identice 2s in acelasi timp.
Are cineva vreun link cu layout-ul pinilor la mufele 2s si 4s?
Spektrum Dx7
#8 Useril este offline   Gerula
  • Postari: 381
Postat 09 March 2010 - 09:09 PM
Scrisesem un post mai consistent azi la pranz dar l-am pierdut.
In tot cazul, se "imparte" firul de la mijlocul mufei 4s, schema e clar prezentata pe site-ul la care ai dat link. Efectiv pui cele doua mufe 2s una peste alta (pe lung) si imparti firele din aia 4s, cu mentiunea splitarii celui din mijloc.
Pe mine ma mai intereseaza si sa fac un adaptor pentru incarcarea unei sigure baterii 2s din mufa 3s sau 4s. Dupa logica mea se iau firele de la extremitatile mufei 3s sau 4s si se duc la extremitatile mufei 2s, iar al doilea fir de sus din mufa 3s/4s se duce in milocul mufei 2s. Evident, merge doar daca chargerul stie sa selecteze 2s desi ai conectat mufa 3s/4s .
Spektrum Dx7
