Da de asta ce ziceti?
RCGF 15cc
http://img193.imageshack.us/img193/4712/2010012330143361.jpg
Displacement (cc) :
15cc
Bore x Stroke (mm): 29mm*26mm
Carburetor : Walbro Pump(made in Japan) & Made in China (Diaphragm butterfly valve type)
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 4.8-6V
Maximum Output :
2.1 hp/1.54KW
speed rang : 1500-15000rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 (recommended : 30:1)
(90% high otcane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 15*8 8000 rpm; 13*8 10000rpm (Standard Two leafs prop)
recommended props 13 x 6, 14 x6,13X8,15X8,15X6
recommended Airplane: 60 size plane,50 size plane,40 size plane
Cooling System : Air Cooled
Packing Weight :
N.W. (Including ignition and muffler ):
825g
N.W. (Not including ignition and muffler) : 635g
Pe ebay se vinde cu 230$...
http://www.youtube.c...h?v=cls_hLyVPBQ
http://www.youtube.c...h?v=yMwbWN0aiwE
http://www.youtube.c...h?v=qzRsv5QUfY8
