Aceasta postare a fost editata de Dan Andrei: 11 October 2009 - 06:46 PM
Futaba 7C
Postat 11 October 2009 - 06:34 PM
Yak 55 EP by Telink
Heli-T-Rex 450 Sport
HK450 pro
Postat 11 October 2009 - 06:47 PM
Dan Andrei, la Oct 11 2009, 07:34 PM, a spus:
Da, merge si trim-ul la ambele suprafete simultan. Trebuie doar sa vezi pe ce canal trebuie pus semiprofundorul 2. La mine la T10 vrea neaparat pe canalul 8. Dar cel mai simplu e sa descoperi astea singur cu telecomanda in mana si vezi cum se misca servourile. Sau macar verifici din meniul SERVO al telecomenzii.
Postat 11 October 2009 - 06:56 PM
misumat, la Oct 11 2009, 07:47 PM, a spus:
Merge? La 7c ? Cum ?
Pe site la futaba uite ce scrie..: http://www.futaba-rc...aq-7c-q763.html
Postat 11 October 2009 - 07:07 PM
Yak 55 EP by Telink
HK450 pro
Postat 11 October 2009 - 07:08 PM
Dar trimul nu e clar din manual cum actioneaza... pag.45
http://manuals.hobbi...4ghz-manual.pdf
Postat 11 October 2009 - 07:17 PM
Yak 55 EP by Telink
HK450 pro
Postat 11 October 2009 - 07:57 PM
"The 7C FASST transmitter has newer software and does have the ailevator function. That does have trim available on both channels used for dual elevator servos."
http://www.rcunivers...b.asp?m=8349414
Postat 11 October 2009 - 08:09 PM
Yak 55 EP by Telink
HK450 pro
Postat 11 October 2009 - 08:17 PM
P.S. off topic: Dane uita`te in tabelul asta si o sa vezi ca ce ziceam azi la zbor e corect (referitor la TM-8 FASST si receptoarele HS)
Aceasta postare a fost editata de shogi: 11 October 2009 - 08:19 PM
Postat 11 October 2009 - 08:20 PM
Uite cum faci :
1. pornesti statia
2.meniu apasat 2sec
3.meniu din nou
4.te duci in jos pana ajungi la ailvator
5. intri acolo si in loc de INH scimbo in ON
6. la AIL dai ambele 0
Si gata :lol:
Later edit
@shogi baga profundoru 1 in canalu 2 si profundoru 2 in canalu 5 si da, intradevar nu poti pune profundoru 2 numa pe canalu 5, nu pe oricare ai vrea...
Aceasta postare a fost editata de BIGfoot: 11 October 2009 - 08:23 PM
Live to fly
#11
Postat 11 October 2009 - 08:22 PM
Aceasta postare a fost editata de shogi: 11 October 2009 - 08:23 PM
#12
Postat 11 October 2009 - 08:33 PM
#13
Postat 11 October 2009 - 08:39 PM
Aceasta postare a fost editata de BIGfoot: 11 October 2009 - 08:40 PM
Live to fly
#14
Postat 11 October 2009 - 08:40 PM
Din pagina si link-ul citat anterior. plus... RTFM :lol:
#15
Postat 11 October 2009 - 08:41 PM
@renatoa ...in cazul asta cred ca practica bate teoria.Azi la camp am lasat un profundor bagat in canalul 2 si apoi celalalt l`am luat de la 1 pana la 7 in fiecare gaura,cu mixul AILVATOR activat si nu a mers,chiar imi venea sa o dau de pamant cand am vazut ca aveam mixul activat,cu mufele in canale 5 sau 7 si dadeam de switch si mi se misca semiprofundorul,repet,cu mixul activat.
E totusi ceva ce parca nu am incercat.In parametru pot seta canalul 5 si 7 pe ce switch sa actioneze.Oare daca dadeam canalul 5 sa nu actioneze nici un switch si apoi faceam mixajul mergea ?Rog pe cineva care are 7C sa incerce si sa scrie aici.
Aceasta postare a fost editata de shogi: 11 October 2009 - 08:47 PM
#16
Postat 11 October 2009 - 08:46 PM
shogi, la Oct 11 2009, 09:33 PM, a spus:
Actioneaza ambele , dar daca functia d/r e pe 100 trimul mie mil face doar pe profundorul 1 , daca e pe alt numar vad mi face trim pe ambele
Live to fly
#17
Postat 11 October 2009 - 08:48 PM
BIGfoot, la Oct 11 2009, 09:46 PM, a spus:
Si face trim corect pe amandoua????
Yak 55 EP by Telink
HK450 pro
#18
Postat 11 October 2009 - 08:49 PM
shogi, la Oct 11 2009, 09:41 PM, a spus:
Nam inteles nici eu nici tu de vreme ce Romulus foloseste receptorul R6004FF desi pe tabel zice ca nu merge !
@Dan Andrei => da face trim pe ambele
Aceasta postare a fost editata de BIGfoot: 11 October 2009 - 08:51 PM
Live to fly
#19
Postat 11 October 2009 - 08:50 PM
shogi, la Oct 11 2009, 09:17 PM, a spus:
Canalele pt. profundor la statia asta sunt exact cum zice Bigfoot. 2 si 5. Am aceeasi statie si am si model cu semiprofundoare. Se baga in canalele 2 si 5 si din meniu se da on la ailvator si acolo se seteaza eleroanele pe zero iar profundoarele la ce cursa le vrei. Dupa ce acticezi mixul ai cele 2 semiprofundoare actionate in acelasi timp( ramane sa setezi si cursa lor sa fie egala) iar cel mai important este ca daca dai de trimul normal de profundor iti pleaca ambele in mod egal.
#20
Postat 11 October 2009 - 08:55 PM
nimsoc,ma intereseaza ce ai in parametru la modelul respectiv adica ce scrie in dreptul canalului 5.
#21
Postat 11 October 2009 - 09:00 PM
[/quote]
Mamaaa .....daca reusesc sa fac mixajul sa mearga corect dau o bere mare tuturor celor care s-au implicat in discutie mai putin lui Bogdan care este deja dator la mine cu o "aterizare" :lol:
Yak 55 EP by Telink
HK450 pro
#22
Postat 11 October 2009 - 09:04 PM
La mine in parametru este pt. canalul 5 switch G. Dar fct. ailevator nu se poate asigna cu switch-uri. Este doar ON sau INH. Vezi ca nu cumva canalul 5 la tine sa fie omorat din alte setari. EPA sau poate chiar din meniul de ailevator, sub setarea eleroanelor mai ai si setarea profundoarelor. Verifica sa nu fie unul din ele fara cursa setata.. Iti stau la dispozitie daca mai ai intrebari si-ti zic ce setari am eu. Repet, la mine functioneaza f.bine ailevatorul cu cele 2 profundoare.
#23
Postat 11 October 2009 - 09:06 PM
nimsoc, la Oct 11 2009, 10:04 PM, a spus:
Mi-ai luat o piatra de pe inima!!
Yak 55 EP by Telink
HK450 pro
#24
Postat 11 October 2009 - 09:14 PM
#25
Postat 11 October 2009 - 09:24 PM
Aceasta postare a fost editata de misumat: 11 October 2009 - 09:25 PM
#26
Postat 11 October 2009 - 09:36 PM
Pt. ff9, daca nu aveti receptor cu opt canale, functia AILVATOR nu poate fi folosita, dar se poate folosi un mix programabil la care trebuie neaparat sa dati TRIM pe ON.
Shogi, am vazut ca vrei sa vinzi TM-7, asta e motivul, ca nu ai trim pe semiprofundorul 2? Daca da, vezi ca gresesti, si eu am tot TM-7 si nu am probleme.
#27
Postat 11 October 2009 - 09:45 PM
misumat, la Oct 11 2009, 10:24 PM, a spus:
misumat ...la 7c nu cred ca ai toate functiile alea (TRIM,SW,POSI).Nu stiu sigur de toate dar TRIM nu am vazut.
Aceasta postare a fost editata de shogi: 11 October 2009 - 09:48 PM
#28
Postat 11 October 2009 - 10:00 PM
shogi, la Oct 11 2009, 10:45 PM, a spus:
Da, se pare ca ai dreptate, SWITCH si POSITION sunt si la T7C dar TRIM nu e... Ce am zis se aplica la T10 si probabil la T9.
#29
Postat 12 October 2009 - 06:14 AM
Nimsoc tu ai o statie 7c in 2,4GHz sau tu imi vorbesti de setarile pe care le faci pe o alta statie Futaba(mai performanta) si care crezi ca s-ar potrivi si la 7C?
Yak 55 EP by Telink
HK450 pro
#30
Postat 12 October 2009 - 06:20 AM
Pt. 7c in 2,4ghz, Trimul pt. semiprofundorul 2 functioneaza fara probleme, trebuie setata functia AILVATOR pe on, cu semiprofundorul 2 in canalul 5.
Ai facut aceste setari personal pe 7c 2,4MHz si au functionat sau doar ai auzit ca ar merge?Imi cer scuze ca sunt Toma necredinciosul dar ieri cu Shogi am incercat ff multe variante si nu au mers <_<
Yak 55 EP by Telink
HK450 pro
Acest topic e inchis
