Modelism - RHC Forum: Proiecte pe 2004-2005 - Modelism - RHC Forum
  • 11 Pagini +
#241 Useril este offline   Jimmy
  • Postari: 927
Postat 31 August 2005 - 10:19 PM
SE-5a powered by YS Yamada
Graupner MC-19 powered by HOTT 2.4GHz
Fieseler Storch 2.4m powered by Magnum
Hyper Bipe Electric
Motto:"Don't take a toy to a scale competition and expect to have earned the respect of real modellers."
#242 Useril este offline   Jimmy
  • Postari: 927
Postat 31 August 2005 - 10:20 PM
Hyper Bipe Electric
#243 Useril este offline   Jimmy
  • Postari: 927
Postat 31 August 2005 - 10:22 PM
Hyper Bipe Electric
#244 Useril este offline   Jimmy
  • Postari: 927
Postat 31 August 2005 - 10:23 PM
Colorarea in verde-roz-verde este probabil din cauza lipsei de lumina...
Hyper Bipe Electric
#245 Useril este offline   domnu_doctor
Postat 01 September 2005 - 04:04 PM
Superb! http://www.rhcforum....tyle_emoticons/default/cool.gif
"Fusta" aia din spate e totala! :D
Stilul si mana ma duce cu gandul la havionul lu' Mugurel!
Sa fie fo legatura (?), nu cred !
PS: Inca o data: Felicitari!
#246 Useril este offline   SILVIU66
Postat 01 September 2005 - 04:13 PM
domnu_doctor, la 1 Sep 2005, 16:04, a spus:
ba tocma! sa crezi!
#247 Useril este offline   domnu_doctor
Postat 01 September 2005 - 04:16 PM
SILVIU66, la 1 Sep 2005, 16:13, a spus:
...ba tocma! sa crezi!
Ziceam si io asa...! :D
Stiam,
#248 Useril este offline   Jimmy
  • Postari: 927
Postat 03 September 2005 - 05:02 AM
In curand " baga " si Mugurel FW-ul....acusi e gata!
Stima JIMMY.
Hyper Bipe Electric
#249 Useril este offline   MUGUREL.
  • Postari: 744
Postat 04 October 2005 - 01:20 PM
Si acest Me 109 superb e impachetat cu al meu Fw , impreuna o mica Luftwaffe! Gata pentru Strejnicu!!
Stima MUGUREL.
#250 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:01 PM
Salut prieteni
Sateva concluzii, pe care le-am tras dupa cele doua zboruri de la Strejnic
La zborul 1:-din cauza modificarii programului de zbor ( de la duminica dimineata la
sambata ora 15, nu am ajuns sa facem toate reglajele,inclusiv un zbor de proba inainte
de zborurile oficiale ) a trebuit sa suport emotiile primului zbor, in plin concurs.
-pana la desfacerea capotei superioare, totul parea ca merge bine
,dupa decolare, am redus gazul, cred ca prea mult, si a rezultat o usoara
instabilitate ( am zburat si modele MAI instabile ) ceea ce m-a surprins,
a fost faptul ca la 50-60% din gaz, vantul nu a creat probleme,nici in zbor
drept ,nici la viraje.
-singurul lucru de care mi-a fost teama, a fost parghia profundorului
era foarte elastica,la viteza prea mare cred ca putea intra in oscilatii, ce se
puteau amplifica...de aceea nu prea l-am tinut in viteza.
-desprinderea pe o parte a capotei (s-a desfacut surubul ce tinea suportul
capotajului ) a produs o puternica descentrare aerodinamica a modelului,ce dupa cum
s-a putut vedea, mi-a produs ceva emotii la aterizare ( am si intrerupt programul din
aceasta cauza ).
-modelul a zburat fara coafa facuta initial de mine ,deoarece pur si simplu
s-a dezintegrat dupa primele porniri ( intre timp am gasit ceva material,si un strungar
sa ma ajute ).
-grabit sa aduc modelul la sol ,am uitat sa scot flapsurile...
La zborul 2 -intre zboruri am reusit sa fixez suportul capotajului
-stiind cum se comporta in vant,nu am mai redus asa mult gazul cu vant din
spate,mentinand viteza maxima,cat mai redusa posibil ( pericol de flutter? profundor )
-dupa ce am redus gazul, pentru coborarea la 360* a murit motorul... la o
altitudine si viteza mica! Singura explicatie: rodaj insuficient cca. 30min. si un amestec
saracit pt. avea putere maxima la decolare...
-solutia cea mai buna gasita pe moment: coborare 45* cu vant din fata (initial
am vrut sa mai fac o intoarcere de 360* pentru a face priza mai din stanga = catastrofa)
pentru a castiga viteza, in schimb priza de aterizare am facut-o la capatul din dreapta al pistei.
-la amandoua zborurile aterizarea s-a facut in regim de urgenta ,fara a putea
trage concluzii.La urmatorul zbor voi pune accentul pe aterizare.
Per ansamblu, modelul s-a comportat peste asteptari cu centrajele long/transv bune.
- C.G. la 107mm. calculat/ aprox 110mm. pe model
- unghi de incidenta la aripa 1.5*
- unghi de incidenta amp. oriz. 0*
- la motor unghiuri 0*
- greutate totala 4300gr.
- centrajul C.G. obtinut FARA plumb.( din constructie )
- putere motor, masurata cu dinamometrul, cu modelul pe sol 4000gr.
- dupa cca.1-3 ore de functionare probabil va creste puterea...
Momentan am defrisat zona parghiei prof. >>>> schimb parghia si tija ce uneste cele doua jumatati
ale profundorului pt. a reduce la max. jocuri...etc. pentru a scapa de grija ce a devenit obsesie
la primele zboruri.
Pana la urmatorul zbor, mai vreau sa testez cateva elicii, cu pas diferit, masurand turatia si
puterea.
Coafa ( care da farmec Messerului ) incerc sa o fac din fibra sau poliamida strunjita.
Cam atat pentru viitor legat de Messer.
Cu stima JIMMY.
Hyper Bipe Electric
#251 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:03 PM
cele doua modele imachetate pt. un drum de aproape 1000Km. Au ajuns cu bine la Strejnic.
Hyper Bipe Electric
#252 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:04 PM
Un popas la o cafea, impreuna cu Calin Alin Mugurel si Marcel.
Hyper Bipe Electric
#253 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:06 PM
Hyper Bipe Electric
#254 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:09 PM
Unul din cele doua Pitts-uri gemene ,care mi-au facut o impresie placuta ( unii ar spune:-pacat ca NU sunt Kit-uri).
Hyper Bipe Electric
#255 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:11 PM
Pitts!
Hyper Bipe Electric
#256 Useril este offline   Jimmy
  • Postari: 927
Postat 20 October 2005 - 06:13 PM
Hyper Bipe Electric
#257 Useril este offline   Jimmy
  • Postari: 927
Postat 09 February 2006 - 07:05 PM
SALUTARE TUTUROR!
Modelistilor aero, avand in vedere interesul "enorm"fata de subiectul Me 109G6 prezentat in cadrul Proiecte pe 200x-200y m-am hotarat sa-l fac vazut si pe la fratii de breasla Americani (nu numai) pe doua site-uri consacrate:
rcuniverse si rcscalebuilder
daca ar fi sa fac un bilant as zice ca "laudele" au fost proportionale cu numarul de machetisti (atat romani cat si americani).
Pentru a nu suna a "umflare in pene" puteti sa va convingeti din curiozitate accesand cele doua site-uri, facand abstractie de Me 109 Dream machine by JIMMYMUGUREL ,sper ca toti ce incearca sa vada ce e pe acolo vor ramane cu ceva, la ce sa mediteze....incepand cu ceea ce mentioneaza moderatorii la interventia intr-un subiect pana la "indicatiile" acestora referitor la modul de adresare intre membrii forumului.....poate mai invatam si noi cate ceva de la EI.
Am selectionat cateva pareri ale unor membri cu mai multe sau mai putine "stelute" de vechime in forum.
Dupa numarul de interventii si aprecieri ,personal chiar eram tentat sa dau o "fuga" pana in USA colea la un TOP GUN.....pacat ca acolo nu as avea sansele de aici de a "rupe norii" mai in gluma spus...
JIMMY
Hyper Bipe Electric
#258 Useril este offline   Jimmy
  • Postari: 927
Postat 09 February 2006 - 07:12 PM
pentru orientare in sit-eur;i la rcuniverse exista mai multe rubrici la capitolul aero....pariez ca o sa va placa...oricare
Hyper Bipe Electric
#259 Useril este offline   Jimmy
  • Postari: 927
Postat 09 February 2006 - 07:15 PM
rcscalebuilder...."orbeste" de la sine...................................sunt MCHETE! si machete?
Hyper Bipe Electric
#260 Useril este offline   Jimmy
  • Postari: 927
Postat 09 February 2006 - 07:21 PM
chestia cu TOP GUN-ul am refuzat-o politicos......
Hyper Bipe Electric
#261 Useril este offline   Jimmy
  • Postari: 927
Postat 09 February 2006 - 07:23 PM
Hyper Bipe Electric
#262 Useril este offline   Jimmy
  • Postari: 927
Postat 09 February 2006 - 07:25 PM
....singurul inconvenient de moment ar fi ca la ambele site-uri trebuie sa te inregistrezi,altfel nu se poate....
Hyper Bipe Electric
#263 Useril este offline   Jimmy
  • Postari: 927
Postat 30 May 2006 - 12:14 PM
Salut!
In acest weekend voi merge cu Mugurel la Deva sa zburam Me si FW (la Lugoj inca nu ne permite "natura" terenului...e prea denivelat! ).
Sper sa tina vremea cu noi!
Voi face cateva poze, un prieten i-mi imprumuta un "digital".
Daca vor fi poze , SIGUR le voi posta pe forum!
Cu stima JIMMY
Hyper Bipe Electric
#264 Useril este offline   Blue Raven
  • Postari: 742
  • Inregistrat: 07-August 05
Postat 30 May 2006 - 05:22 PM
Beton Jimmy!
Abia astept sa vad pozele!
Spor la zburat si aterizat fara crash!
Blue Raven
#265 Useril este offline   Jimmy
  • Postari: 927
Postat 02 June 2006 - 02:51 PM
Salut!
Zilele trecute am dat peste o fotografie "de epoca" cu doua din avioanele CONSTRUITE
de mine prin anii 86-88.
Am tinut sa o postez, pentru ca cele doua modele au doua povesti diferite complet.
Spit-ul, a ajuns printr-o intamplare nefericita pe mainile unui modelist "de duminica"
,dupa ce a fost partial accidentat. Ulterior, am cunoscut cativa modelisti capabili,
carora cu placere l-as fi donat,stiind ca a incaput pe maini bune...
In schimb, cu Messer-ul povestea a fost total opusul.A ajuns la loc de cinste in
colectia de modele construite de Marcel Stratulat,unul din cei mai buni modelisti-cons
tructori cunoscut de mine,un bun coleg de club,cu un caracter de invidiat,de la care
oricand avem de invatat, nu numai modelism ...
- JIMMY -
Hyper Bipe Electric
#266 Useril este offline   Jimmy
  • Postari: 927
Postat 02 June 2006 - 02:52 PM
............si inca una ce i-mi place mult
Hyper Bipe Electric
#267 Useril este offline   Jimmy
  • Postari: 927
Postat 02 June 2006 - 02:54 PM
Se pare ca vremea NU tine cu noi!
PLOUA,PLOUA,PLOUA
Hyper Bipe Electric
#268 Useril este offline   Jimmy
  • Postari: 927
Postat 13 June 2006 - 04:47 PM
Salut!
Poate plictisesc cu Messer-ul,dar de data asta am reusit sa fac cateva poze cu un aparat mai acatarii.
Unele poze contin si o mostra cu aproape acelasi detaliu ale avionului "mare".
Hyper Bipe Electric
#269 Useril este offline   Jimmy
  • Postari: 927
Postat 13 June 2006 - 04:48 PM
13 Red/de aproape
Hyper Bipe Electric
#270 Useril este offline   Jimmy
  • Postari: 927
Postat 13 June 2006 - 04:50 PM
loop antenna si aceeasi pe un avion la muzeu prin SUA
Hyper Bipe Electric
  • 11 Pagini +
6 useri citesc topicul
