Fokker DVII depron de 3mm
Postat 16 September 2008 - 12:19 PM
Modele FPV
Piper-Wot4
Modelare 3D
Modele pt.simulator - RealFlight :
LazyBee;SpeedyBee;Aurora Scimitar;Sbach 342;BV 141;Heptad
Postat 16 September 2008 - 12:23 PM
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 12:33 PM
Romulus, la Sep 16 2008, 01:25 PM, a spus:
Multumesc. Ma tot uit pe fereastra si cand vad cum ploua !!!!........
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 01:04 PM
Si daca nu cer prea mult si o idee de motorizare (gata ca de acu sunt din cale afara)
Postat 16 September 2008 - 01:17 PM
Gregorius_Syth, la Sep 16 2008, 02:04 PM, a spus:
Desigur :
Motor BL A1510-22 Outrunner, KV 2200, 8A
Caracteristici
KV: 2200
Dimensiuni: Φ18mm x 17.5mm (fara ax)
Masa: 16.1g fara conectori
Diametru ax: Φ2mm
Lungime ax: 8mm
Rezistenta: 0.52 Ω
Curent de eficienta maxima: 2A to 6A, >70%
Curent maxim: 8.5A
Curent de mers in gol: 0.5A/10V
Elice recomandata:
3S/10V, GWS 5030HD, 16500 RPM, 5.5A, tractiune 272g
2S/7V, GWS 7035HD, 10150 RPM, 5.6A, tractiune 215g
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 01:18 PM
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 01:20 PM
fac si eu un SE5a tot din depron in acelasi stil !! am vazut ceva pe forum si sper sa iasa !! ca motorizare ma gindesc la un motor in jur de 100 w -12-13 A cu accu 3 lipo - 1300mA ; spor la treaba !!
Postat 16 September 2008 - 01:34 PM
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 01:36 PM
kristian, la Sep 16 2008, 02:20 PM, a spus:
Multumesc. La ce anvergura si greutate il estimezi ?
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 02:09 PM
Postat 16 September 2008 - 02:28 PM
kristian, la Sep 16 2008, 03:09 PM, a spus:
ai armat aripa cu ceva , am vazut ca este din 2 straturi ???
...am pus cate un lonjeron de 3x3 mm plus o fasie de 2 cm depron 3mm ca sa ajung la profilul dorit.....cat despre Se5a eu cred ca va zbura judecand dupa opiniile din http://www.rcgroups....ad.php?t=649178
Modele FPV
Piper-Wot4
Modelare 3D
Postat 16 September 2008 - 08:03 PM
Modele FPV
Piper-Wot4
Modelare 3D
Postat 17 September 2008 - 08:11 AM
Postat 17 September 2008 - 08:42 AM
kristian, la Sep 17 2008, 09:11 AM, a spus:
Multumesc;nu cred ca-l voi vopsi pana nu-l vad zburand bine ( va iesi destul de greu si fara vopsea );am incercat motorul pe planorul descris aici http://www.rhc.ro/fo...showtopic=17983 - care avea peste 400 gr. la o suprafata alara doar cu 10 % mai mare decat va avea biplanul ;la ce dimensiuni / greutate estimezi Tiger Moth-ul ?......
Modele FPV
Piper-Wot4
Modelare 3D
Postat 17 September 2008 - 08:44 AM
Specificatii:
Capacitate: 900 mAh
Rata de descarcare: 20/30C
Curent de descarcare: 18 A continuu, 27 A burst
Tensiune: 7.4 V
Dimensiuni: 70 x 31 x 15 mm
Greutate: 49g
Modele FPV
Piper-Wot4
Modelare 3D
Postat 18 September 2008 - 02:22 PM
Modele FPV
Piper-Wot4
Modelare 3D
#19
Postat 18 September 2008 - 08:11 PM
#20
Postat 18 September 2008 - 09:16 PM
fokker2, la Sep 18 2008, 09:11 PM, a spus:
...placuta aceea este de fapt cablaj din textolit nedecapat de 1mm grosime .....
Modele FPV
Piper-Wot4
Modelare 3D
#22
Postat 19 September 2008 - 09:03 AM
kristian, la Sep 19 2008, 09:35 AM, a spus:
Multumesc. In principal Blu-Baby - caruia i-am facut 3 fuselaje ( doua din depron si unul din coroplast ) si 3 aripi : una 4-40 , a doua KFM cu eleroane si ultima 4-40 cu intradosul placat-plan. Am mai inceput un Se5a din coroplast ( am terminat aripile si ampenajele ) dar care va mai dura pana voi fi capabil ( financiar ) sa-i cumpar electronica potrivita - il estimez cam la 600 gr.gata de zbor. Ambitia mea este sa contruiesc si sa zbor un model VUIA 1.....
....si apropo, in imagini modelele arata mult mai bine decat in realitate....
Modele FPV
Piper-Wot4
Modelare 3D
#23
Postat 19 September 2008 - 01:05 PM
pccdtk, la Sep 19 2008, 10:03 AM, a spus:
ceroplastu este folia aia cu celule care se pune la ambalaje (sau se fac ) ? nu prea mi place ca ramin golurile alea vizibile ,da cam nasol ! in schimb poti da cu modelul de pamint fara mari avarii !! ce electronica vrei sa pui pe Se ? este buna ideea cu vuia 1 , din ce vrei sa il faci ?!! l -o mai fi facut cineva ?? ar fi ca lumea facut micro cu structura din paie !!
eu am vrut sa fac nieuport 11 , l - am facut ( din depron ) dar nu am reusit sa zbor cu el si l - am abandonat !! vreau insa sa reiau proiectul ! sa mi zici si mie cum faci aripile din depron !!??
salutari !! cristi
#24
Postat 19 September 2008 - 01:14 PM
kristian, la Sep 19 2008, 02:05 PM, a spus:
salutari !! cristi
1.Da - coroplast _http://www.rhc.ro/forumrhc2/index.php?showtopic=18175
2.Am de gand la Vuia1 sa-i fac nacela din bete de bambus de 3mm - ceea ce va duce la scara la o anvergura ~ 900 mm , iar aripa din depron de 3mm , cu sectiunile sprijinite pe cateva nervuri de carbon...
3. Dupa ce am incercat sa fac aripi pt.BB in vreo 3 variante pot sa-ti spun ca cea mai buna solutie ( greutate redusa - structura suficienta ) este cea de aici :
Modele FPV
Piper-Wot4
Modelare 3D
#26
Postat 19 September 2008 - 08:19 PM
tetea, la Sep 19 2008, 05:36 PM, a spus:
.....chiar este .....Eu am coroplast de 3 mm ( 460 gr./m2 - l-am cantarit ) adus de un prieten ( fusese utilizat ca ambalaj pentru un ascensor )
......da .....cum am amintit mai sus m-am apucat mai de mult de un Se5a. Aripa are acum 81 de gr.( nelipita inca ) dar daca as fi facut-o din depron nu ar fi depasit 50;55 gr.
......lipit f.bine cu CA cu vascozitate mare.....am mai incercat ( si renuntat din cauza greutatii ) pe cateva bucatele sa-l lipesc cu glue-gun - functioneaza cu conditia ca pistolul sa fie f.bine incins....
Modele FPV
Piper-Wot4
Modelare 3D
#27
Postat 06 October 2008 - 10:38 AM
pccdtk, la Sep 19 2008, 09:19 PM, a spus:
salutare !!!
ai terminat fokker - ul ??? cum zboara ??
toate cele bune !
cristi
#28
Postat 07 October 2008 - 01:00 PM
kristian, la Oct 6 2008, 11:38 AM, a spus:
toate cele bune !
cristi
...inca nu ....dar sunt aproape :
Modele FPV
Piper-Wot4
Modelare 3D
