Modelism - RHC Forum: tips for better cooling (= higher currents :-) - Modelism - RHC Forum
#1 Useril este offline   ron_van_sommeren
  • Postari: 124
  • Inregistrat: 03-June 05
Postat 06 August 2008 - 05:02 AM
See
http://mgm-compro.co...cal-information
-> controller cooling in models
Vriendelijke groeten :lol: Ron
#2 Useril este offline   Valteras
Postat 07 August 2008 - 10:53 PM
Thanks Ron, for sharing.
See my approach when upgrading a slim Q10 glider
Fisier atasat  Q10.jpg (90.55K)
from a Speed 400 + Kontronik Rondo, to a 180W brushless.
Obvious, there were no room left inside for the controler, whatsoever!
Original Q10 canopy
Fisier atasat  1_original_Q10_hatch.jpg (143K)
The new one
Fisier atasat  2_radiator_Q10_hatch.jpg (250.91K)
Aceasta postare a fost editata de Valteras: 07 August 2008 - 11:09 PM
#3 Useril este offline   Valteras
Postat 07 August 2008 - 10:55 PM
So, a new canopy was made (new model, mold, etc.)
#4 Useril este offline   Valteras
Postat 07 August 2008 - 11:00 PM
Fisier atasat  4_Q10_and_X_30.jpg (237.21K)
The controler was strip off of shrink.
Fisier atasat  5_inside.jpg (142.33K)
An aluminium radiator was fixed from inside and the controler pressed to it.
#5 Useril este offline   alexroad
  • Postari: 621
  • Inregistrat: 29-June 07
Postat 17 August 2008 - 09:59 AM
Am facut acelasi lucru la un controler de 30A cu motor de 25A si se simte diferenta.Acum am o intrebare: acelasi tip de controler il folosesc cu un motor de 3800kV outruner dar se incalzeste destul de bine cu toate ca motorul in sarcina cu o elice de 5X4 consuma la turatie maxima 20A, care sa fie cauza?
P.S.
Trebuia sa scriu in engleza?
Aceasta postare a fost editata de alexroad: 17 August 2008 - 10:01 AM
Hodina-i ca slanina
Sa te maturizezi e optional!
#6 Useril este offline   Valteras
Postat 18 August 2008 - 08:33 PM
Check the timing setup of your controler.
If the motor is outrunner, the timing must be set on "hard".
#7 Useril este offline   ave
  • Postari: 1010
  • Inregistrat: 13-December 07
Postat 19 August 2008 - 03:27 PM
Just to make sure: did you use some thermal conductive glue for that ESC or did you simply press it against the radiator?
Aceasta postare a fost editata de ave: 19 August 2008 - 03:28 PM
Ave
#8 Useril este offline   Valteras
Postat 20 August 2008 - 10:21 AM
Vezi postareaave, la Aug 19 2008, 04:27 PM, a spus:
...thermal conductive glue ...
Wish I had some!
I just put some white thermal transfer paste in-between and pressed the
controller onto the radiator with those balsa strips.
