Modelism - RHC Forum: Acumulator - Modelism - RHC Forum
Acumulator pt Easy Glider
#1 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
  • Inregistrat: 09-June 07
Postat 22 February 2008 - 01:05 PM
As vrea sa stiu si eu daca ar merge un Easy Glider cu un acumulator de 7 celule la 1000mAH, sau ar fi prea lenes?, cu cel de 8 celule merge bine. Motorul folosit este cel care vine cu modelul(Permax 400)
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#2 Useril este offline   aantikk
  • ex aantik
  • Postari: 995
  • Inregistrat: 11-June 07
Postat 22 February 2008 - 01:16 PM
Merge dar e cam lenes.
#3 Useril este offline   Porumbeu
  • Postari: 831
  • Inregistrat: 09-July 07
  • Interests:discussion
Postat 22 February 2008 - 03:32 PM
Este prea lenes :)... stai pe 8 celule
#4 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
Postat 22 February 2008 - 06:30 PM
Voi ce acc folositi (NIXX) si ce greutate au, am acc de 1600mAh dar au 250g, sunt prea grei???
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#5 Useril este offline   Porumbeu
  • Postari: 831
Postat 22 February 2008 - 09:27 PM
Cred ca doar baietii de la auto mai folosesc ni-xx ... la aero e treaba nu Li-Po. Nu sunt grei deloc. 8 celule. Sa nu uiti de CG ( centrul de greutate )
#6 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
Postat 23 February 2008 - 01:36 PM
alte pareri???
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#7 Useril este offline   sonic xz
  • Postari: 797
  • Inregistrat: 26-October 07
Postat 23 February 2008 - 03:34 PM
un lipo de 3 cell pe la 1200-2000 mAh...
#8 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
Postat 23 February 2008 - 05:30 PM
la 2 cell nu ar merge de 1300mAh???
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#9 Useril este offline   sonic xz
  • Postari: 797
Postat 02 March 2008 - 11:53 AM
merge si ala de 7.4(2 cell),dar daca la 8 cell de 1000 e lenes , atunci poti ceva de genu 3 cell si 1300mAh
de ce nu incerci un unu de 3 cell si 1800 de la concurenta,are 137grame asa ca nui problema.cu 3 cell ar trebui sa utilizezi cam 70 %din maneta.poti si max dar in cazuri de urgenta. :)
#10 Useril este offline   Porumbeu
  • Postari: 831
Postat 02 March 2008 - 03:32 PM
Daca motorul este stock ( 6v ) atunci baga 2s ( 7.4v 1200 - 1500 mah ) ... daca vrei sa bagi 3s ( 11.1 v ) ai toate sansele sa parlesti motorul. Recomandat pentru 3s ( 11.1v ) este motorul de 7.2v ( tot speed 400 Multiplex ).
#11 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
Postat 02 March 2008 - 05:25 PM
Motorul ii de 6V si am acc NiMh de 9,6 si 8,4 la 1000mAh si respectiv 1600mAh ,merge bine si cu Lipo 2s de 1300mAh, deci nu are rost sa pun 3s? Cu acc de 8,4 ii un pic cam lenes dar abia apuc sa vad cum derge cu Lipo 2s.
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#12 Useril este offline   sonic xz
  • Postari: 797
Postat 02 March 2008 - 05:54 PM
ok,daca e asa ,ramai pe 2 cell cu capacitate cat mai mare,sa ai un zbor cat mai lung.... :)
#13 Useril este offline   Porumbeu
  • Postari: 831
Postat 02 March 2008 - 09:21 PM
Poti sa pui si 3s doar ca sa nu-i dai gaz maxim mult timp... Nu bag mana-n foc ca se arde dar are mari sanse sa se arda.
#14 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
Postat 07 March 2008 - 07:03 PM
Inca o inrebare, merge la EG cu motor stok un acc de cessna 182 de 8,4v la 1000mAh???
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
#15 Useril este offline   Porumbeu
  • Postari: 831
Postat 07 March 2008 - 11:00 PM
8.4v = 7x1.2 Ne intoarcem de unde am plecat ?
#16 Useril este offline   casper20
  • Lifetime Beginner
  • Postari: 3630
Postat 07 March 2008 - 11:53 PM
ma gandeam la curentul de descarcare
FPV is not a crime!
FrSky 2.4GHz modul
Easy Glider BL
FW 190 A8
P 51D Mustang
IAR 80
ME 163
Tel: 0741-931.767
