Modelism - RHC Forum: Sistem de cronometrare - Modelism - RHC Forum
#1 Useril este offline   VIPER
  • Postari: 1506
Postat 26 October 2003 - 02:39 AM
Ce ziceti de asta? Nu e foarte performant, dar nici scump (210$ cu 1 transponder, 50$ 1 transponder, 65$ soft pentru PC-optional):
http://www2.gpmd.com/image/o/oric3600.jpg
Team Orion Super Lap Counting System
FEATURES: Counter and Transponder are both Anodized Purple Aluminum.
Counts one car at a time and holds lap times up to 60 laps.
Handles up to 100 separate channels
VEHICLE ANGLE OF APPROACH: If a vehicle passes by the counting unit
on a trajectory other than close to parallel a small delay may occur
LAP TIME MEASUREMENT: Able to measure lap times in 0.01sec increments
ENVIRONMENTAL INFLUENCES: The System may detect rays in ambient, or
if several vehicles using the system pass the counting unit at the
same time, the system may try to re-read the vehicles transponder ID
number again. Also, IR reflections may cause detection errors.
TIME MEASUREMENT: System can measure lap times of up to 11 minutes.
LAP TIME DISPLAY: The counting unit has a Liquid Crystal Display.
After a run the LCD will display the lap time information as listed-
Best Lap Time, Average Lap Time, Every Lap Time with Lap Number and
Total Time, and Complete Race Time with Total Laps.
ACOUSTIC SIGNALING: The Counting Unit has a built in buzzer, during
operation when a vehicle passes by the reciever the buzzer will beep
2 times. If the last completed lap is faster than the "Target Lap
Time" you entered, the buzzer will beep 4 times. Another Feature is
that when a lap is faster than the previous "Best Lap", the buzzer
will emit 3 beeps with a different sound.
MINIMUM LAP INTERVALS: The System can be set up for minimum lap times
of 3 to 30 seconds to minimize " Fail To Detect" errors.
TWO START MODES: Stagger: When a vehicle passes the reciever on a
running start, the reciever will start counting automatically, like
on a IFMAR style qualifying run. Count Down Signal Start: The unit
will beep every second and then emit a louder and different beep
during the last few seconds of the countdown, then the counting will
start, like for a standing start that is used for finals.
Reception Range: Indoor Tracks: approx. 32 Feet (10 meters)
Outdoor Tracks: approx. 16 feet (5 meters)
Reciver Power Supply: The system includes a test battery which may
be empty when you unpack it. USe a 006P9V battery as a standard
replacement.
Transponder has two leads, one with IR Sensor, and one with universal
receiver lead.
INCLUDES: One Pro LCS Lap Counting System
One Transponder
One set of Instructions
http://www2.gpmd.com/image/o/oric3610.jpg
Team Orion Additional Transponder
This is the Additional Transponder for the Team Orion Pro LCS Lap Counter.
This will only work with the Team Orion Lap Counter.
FEATURES: Aluminum Case Construction
Case is Anodized Purple
Post for mounting Machined on
Has Two Leads: Universal Rx connector and IR sensor lead
INCLUDES: One Aluminum Transponder
REQUIRES: One Pro LCS Lap Counter #36000
SPECS: Length: 35mm
Width: 30mm
Height: 15mm
http://www2.gpmd.com/image/o/oric3620.jpg
Team Orion PC Link & Software
This is the PC Link and Software for the Orion Pro Lap Counting System.
FEATURES: Allows users to keep track of race data from the lap counting system
on their PC. Display shows up to 60 different racers with lap times
and total elapsed time for reach racer.
Also shows Best lap time.
INCLUDES: One PC Interface unit.
One CD-ROM Software Disk.
REQUIRES: Windows compatible computer with avaliable Serial Port.
Orion Lap Counting System.
Windows 95/98 or Windows 2000 computer.
Administrator access required for Windows 2000.
Flickr - pozele mele
#2 Useril este offline   PiccoMaster
  • Postari: 211
  • Inregistrat: 25-April 02
Postat 26 October 2003 - 08:06 PM
....."Counts one car at a time".
Cred ca intelegi si singur.
