Experiment despre automentinere
Postat 20 July 2003 - 06:16 PM
Daca dam un impuls ansamblului dinamul va produce curent pe care motorasul il consuma ca sa invarta dinamul care va produce curent s.a.m.d. Intrebare: cum se calc cati dinti tre. sa aiba fiecare pinion pt ca eu am incaercat shi mi se oprea, dar chestia e ca mergea ca 20-30 min.?
Postat 20 July 2003 - 08:53 PM
Postat 20 July 2003 - 09:58 PM
Postat 21 July 2003 - 12:06 AM
007.rar (2.18K)
Postat 21 July 2003 - 01:04 AM
Postat 21 July 2003 - 02:17 AM
Postat 21 July 2003 - 07:19 AM
http://www.newebmast...rgy/index.shtml
are si brevet in SUA, este realizat de catre Howard Johnson
Daca o sa cauti pe Google o sa gasesti tot felul de implementari pentru experimentari: dintr-un HDD de la
calculator, CD-ROM ....
O scurta descriere:
"In short, it is a patent for a device capable of producing unlimited free energy with zero environmental impact. A device resembling an electric motor which produces work without electrical input, using only permanent magnets for motive force. What some might call perpetual motion. What the inventor believes is the harnessing of energy not thought possible by conventional science based on "incomplete information and theory with respect to the atomic motion occurring within a permanent magnet." He then goes into a lengthy discussion of his theories, which may or may not be accurate, and I am not qualified to say one way or the other. The fact remains, however, that he DOES have a working model of the invention. What ever path he look, he arrived at the same place. "
Sper sa te ajute! :huh:
Postat 21 July 2003 - 09:40 AM
Postat 21 July 2003 - 10:00 AM
Postat 21 July 2003 - 10:04 AM
Postat 21 July 2003 - 10:30 AM
Cu respect, Alexandru B.
Postat 21 July 2003 - 10:36 AM
Postat 21 July 2003 - 11:00 AM
Link-ul pe care l-am dat a fost in ideea de a citi si alte informatii, sint si altii care se ocupa de chestii din astea.
Eu unul nu am incercat sa construiesc asa ceva deci nu pot decit sa-mi dau cu parerea. Cine vrea sa incerce
n-are decit, e liber... poate asa mai apar diverse idei poate in cu totul alt domeniu de aplicabilitate.
Explicatia profesoarei era ceva de genul: nu se poate realiza asa ceva deoarece exista pierderi aproape peste tot, si anume:
1. rezistenta electrica a firelor de conexiuni
2. rezistenta electrica a bobinelor din motor
3. frecarea care exista in lagarele motorului
4. frecarea din lagarele generatorului
5. rezistenta electrica din infasurarile generatorului
Nu degeaba exista un randament al motorului si un randament al generatorului si pina acuma nimeni nu a realizat un generator care sa aiba un randament mai mare decit al motorului astfel incit sa poata sustine functionarea unui motor sau chiar generarea unui surplus de energie.
Link-ul sustine exact inversul acestor idei. Fiecare este liber sa incerce pe cont propriu daca teoria este adevarata sau nu. Din asemenea incercari "fara rost" au iesit de multe ori inventii remarcabile, poate fara nici o legatura cu experimentul initial.
Postat 21 July 2003 - 11:05 AM
Postat 21 July 2003 - 11:09 AM
Postat 21 July 2003 - 11:10 AM
Experimentul e frumos si cred ca la o anumita varsta l-am facut cu totii .
Postat 21 July 2003 - 12:02 PM
1.Un perpetuum mobile inseamna ca poti sa obti si un plus de energie pe care sa i-l folosesti in alta parte
2.Ce spune speedy007 este un ansamblu care nu face altceva decit sa recircule energie.Si nici pe aia cum trebuie.
3.Se opreste din cauza faptului ca atit motorul cit si dinamul au frecari , si pt ca exista pierderi de curent.
4.Energia mecanica pe care o folosesti pt. a obtine un curent destul de puternic va fi intotdeauna mai mare decit cea pe care o obtii.
DACA NU AI FRECARI SI NICI PIERDERI DE CURENT , ANSAMBLUL VA MERGE LA NESFIRSIT DAR ASTA INSEAMNA CA ESTI INTR-UN MEDIU IDEAL.
SE NUMESTE IDEAL PENTRU CA NU EXISTA ASA CEVA (ALTFEL SE NUMEA MEDIU REAL)
S-au gindit si altii la asta inaintea ta, cum a zis si zod. Energie gratis nu vei capata asa ca lasa-te.
Mai bine ocupati-va de modelism. :huh:
#19
Postat 21 July 2003 - 12:55 PM
Se ia o baterie de 1,5 V , un bec de 1,5 V si doua bucati de cablu electric.Se conecteaza cablurile la cele doua capete ale bateriei iar cele doua capete ramasa libere se conecteaza la bec.
Intrebare: Ce se intimpla? OOOOAUUUU! se aprinde becul.Si inca ceva. Cind nu mai e curent in baterie ,becul se stinge OOOAAUUUU! :D
Ce zici cata de experimentul asta.E special pentru modelism si ne ajuta sa intelegem principiul de functionare a statiei de radiocomanda! :huh:
Aceasta postare a fost editata de Pletila: 21 July 2003 - 12:56 PM
#20
Postat 21 July 2003 - 01:53 PM
Speedy007 ca sa vezi ca avem dreptate leaga de angrenajul tau o roata sau o elice sau orice sa vezi cam cat scade timpul in care se invarte mecanismu tau . Si apoi gandeste-te daca ce faci tu acolo e de fapt o masinuta care are carcasa, sasiu, servouri (care consuma curent) etc....
Ce zici o sa se mai invarta ?
#21
Postat 21 July 2003 - 02:37 PM
De exemplu stiti ca sint deja destul de multi pasionati care au transformat un motor de la unitatile de CD (cel care invirte CD-ul) pentru aeromodelism si nu numai ? Au rebobinat motorul si se pare ca au obtinut performante asemanatoare cu modelul 280 dar cu o greutate mai redusa. Si asta in conditia in care motorul are mai multe faze si e mai greu de comandat mai ales la turatii mai mari.
Daca are asemenea preocupari, chiar daca nu sta asa de bine cu cunostintele, in mod sigur o sa le obtina mai ales daca sint insotite si de experiente practice. Si daca dupa aceea se apuca si de modelism !!!
Nu credeti ca poate iesi ceva bun din asemenea experiente ?
#22
Postat 21 July 2003 - 05:18 PM
#23
Postat 21 July 2003 - 07:27 PM
#24
Postat 21 July 2003 - 08:53 PM
Speedy007, la 21 Jul 2003, 00:06, a spus:
Deci revin :
1. nu poti produce mai multa energie decit consumi
2.energia se consuma la tine prin:
a)frecare in lagare si pinioane
b)caldura disipata prin firele de conexiune si in bobinaj prin efect Joule
c)energia disipata prin camp electromagnetic ca doar avem pe acolo bobine
d)pierderile in redresor de tip Joule
3.ce ce ai obtinut tu este o combinatie intre o miscare intretinuta electromagnetic si una inertiala datorita maselor rotoarelor
Daca vrei cu adevarat sa faci ceva util fa o vizita la Muzeul Tehnic din Bucuresti si intreaba de pila Karpen( parca asa se scrie) ce invarte un motor electric de prin anii 30-40 si nu si-a dat inca duhul si atunci sa vezi ciudatenie!
Aceasta postare a fost editata de S62: 21 July 2003 - 08:55 PM
#25
Postat 21 July 2003 - 08:55 PM
Si in acest caz al perpetu...mobile se poate aplica legea relativitatii: Daca faci un motor care sa functioneze dupa principiul prezentat de tine ,mai bine de 100 ani ,il poti considrea Perpetuum mobile,deoarece tu nu mai apuci sa vezi cand se va opri .Iar daca cineva chiar il inventeaza pe acest perpetuum mobile nu poate demonstra ca functioneaza caci nu se stie daca intr-o zi se va opri. Parerea mea.
#26
Postat 21 July 2003 - 09:20 PM
#27
Postat 22 July 2003 - 07:14 AM
#28
Postat 22 July 2003 - 07:16 AM
#29
Postat 22 July 2003 - 12:26 PM
Eu m-am confruntat de mult cu problema asta iar tatal meu ca orice parinte si-a ajutat copilul cu ceva sfaturi (tata are cateva diplome de inovator si inventator dupa timpul lu' ceasca).
Jucaria asta care vreti voi sa o construiti o sa mearga din ce in ce mai bine dar nu o sa mearga la infinit deoarece este imposibil.
Orice jucarie deasta formata din doua sau mai multe parti care se antreneaza in miscare una pe cealalta se numeste perpetuum mobile.
Un mecanism dinasta nu cred ca functioneaza la infinit nici in spatiu unde atractile gravitationale ale planetelor sunt scazute.
Dupa atitea explicatii sa va dau si eu o idee.
Voi trebuie sa aveti un consum cat mai mic, un curent si o tensiune generata cat mai mare adica consumul sa fie mai mic decat produsul iar produsul sa fie cel putin egal cu consumul + pierderile.
Mai trebuie sa scadeti pierderile si frecarile.
Cum?
Voi aveti frecari la motor, la mecanismul de distributie si la generator.
Mai aveti pierderi la conexiuni-fire.
Astea merg reduse chiar sub 50% eliminind frecarile unuia dintre componente motor sau generator si frecarile mecanismului de distributie ba chiar conexiunilor si firelor.
Cum? http://www.rhcforum....tyle_emoticons/default/biggrin.gif berica si va spun.
De ce sa aveti atitea mecanisme si ansamble cand puteti sa aveti doar unul cu frecarile lui care sa produca curent singur.
Faceti un mecanism asemanator unui motor care pe linga bobinele motorului mai sunt atasate bobinele generatorului.
Unele bobine produc curent iar celalate il consuma. Acelasi lucru ca mai inainte numai ca ai mai eliminat din frecari si din pierderi iar jucaria in loc sa mearga 30 min merga poate 1 ora si 30 min.
ATENTIE: trebuie cinstruit at mai precis si cere foarte multe calcule si foarte complicate. Fizica sa traiasca.
O sa revin si cu un desen simplu.
#30
Postat 22 July 2003 - 03:27 PM
