Modelism - RHC Forum: Piese heli clasa 700 - Modelism - RHC Forum
#1 Useril este offline   Ciprian97
  • Postari: 3947
Postat 01 March 2020 - 03:05 PM
Vreau sa scap de urmatoarele pentru clasa 700 - posibil compatibil clasa 600:
1) pale principale ALIGN clasa 700 - stare excelenta - 150 lei
2) pale principale clasa 700 de la SWERC.COM - stare excelenta - 100 lei
3) main shaft spacer HN7075T - nou in punga - 15 lei
4) damper feathering shaft HN7024T - nou in punga - 15lei
5) damper feathering shaft HN7024AT- nou in punga - 15lei
6) thrust bearing HN7003T - nou in punga - 15lei
7) main gear + autorotation gear - folosite, fara rulment unisens, dinti drepti - 50 lei
8) torq tube + teava coada + tail link pentru stretch la 800mm - folosit, are ceva gauri ciudate date in ea dar altfel utilizabil - 100 lei
9) 4 rulmenti HN7066T - 2 seturi - unul nou unul folosit - 60 lei toti 8 rulmentii
10) 2 ball linkuri si'o pala de coada 115mm -gratis cui mai cumpara si altceva
11) motor mount tray 2 bucati - 50 lei bucata
12) pinion 11T drept - pt ax de 6mm - 20 lei
13) pinion umbrella pt torq tube,plastic, alb - partea care intra in TT - 20 lei
13) pinion 10T slanted - pt ax de 6mm - 20 lei
14) pinion 10t drept - pt ax de 6mm - 20lei
15) tail hub + tail control arm (ansamblu complet cu rulmenti presiune) - fara ball link-uri - original ALIGN - 50 lei
16) tren aterizare H70F001XAT - nou in punga 80 lei
17) pale coada 100mm - plastic negru - 50 lei
18) pale coada align 105mm - albe - stare excelenta - 90 lei
19) pale coada 105mm - galben fosforescente - 50 lei
20) blade balancer turnigy - 50 lei
21) main shaft clasa 700 - 50 lei
0751538090 Bucuresti.
  • Postari: 3947
Postat 09 March 2020 - 10:00 PM
50% reducere la toate. Doar sa ma scape cineva de ele, ca le arunc la cos.
#3 Useril este offline   Ciprian97
  • Postari: 3947
Postat 31 March 2020 - 09:59 AM
Vezi postareaCiprian97, la 01 March 2020 - 03:05 PM, a spus:
5) damper feathering shaft HN7024AT - nou in punga - 15lei
8 ) torq tube + teava coada + tail link pentru stretch la 800mm - folosit, are ceva gauri ciudate date in ea dar altfel utilizabil - 100 lei
10) 2 ball linkuri si'o pala de coada 115mm - gratis cui mai cumpara si altceva
0751538090
#4 Useril este offline   Ciprian97
  • Postari: 3947
Postat 08 April 2020 - 09:32 PM
up
#5 Useril este offline   Ciprian97
  • Postari: 3947
Postat 12 April 2020 - 10:02 PM
Up
LE ...scuze, m-a lasat matematica, nu e inca vremea.
Aceasta postare a fost editata de Ciprian97: 12 April 2020 - 10:03 PM
#6 Useril este offline   Ciprian97
  • Postari: 3947
Postat 22 April 2020 - 08:39 AM
Up
#7 Useril este offline   adi_ryan
  • Postari: 189
  • Inregistrat: 06-January 10
Postat 22 April 2020 - 10:50 AM
Deci pret la blade balancer Turnigy 25 Ron?
#8 Useril este offline   Ciprian97
  • Postari: 3947
Postat 25 April 2020 - 08:52 AM
Da, dar sa se adune macar 50 lei/colet sa merite drumul.
#9 Useril este offline   Ciprian97
  • Postari: 3947
Postat 03 May 2020 - 11:42 AM
up
#10 Useril este offline   Ciprian97
  • Postari: 3947
Postat 13 May 2020 - 02:41 PM
Up
#11 Useril este offline   Ciprian97
  • Postari: 3947
Postat 03 June 2020 - 05:33 PM
Ramas:
4
5
7
9
11- > 15
17
20
21
#12 Useril este offline   Ciprian97
  • Postari: 3947
Postat 19 June 2020 - 04:28 PM
Up
#13 Useril este offline   Ciprian97
  • Postari: 3947
Postat 28 June 2020 - 09:25 PM
up
#14 Useril este offline   Ciprian97
  • Postari: 3947
Postat 10 July 2020 - 07:55 AM
up
#15 Useril este offline   Ciprian97
  • Postari: 3947
Postat 07 August 2020 - 09:30 PM
Up
#16 Useril este offline   Ciprian97
  • Postari: 3947
Postat 29 August 2020 - 06:07 PM
up
#17 Useril este offline   Ciprian97
  • Postari: 3947
Postat 20 October 2020 - 09:12 PM
up down left left right right start
trebuia sa pice ceva powerup cu hack-ul asta...
#18 Useril este offline   Ciprian97
  • Postari: 3947
Postat 04 November 2020 - 06:19 PM
up
#19 Useril este offline   Ciprian97
  • Postari: 3947
Postat 03 December 2020 - 09:39 PM
up
#20 Useril este offline   Ciprian97
  • Postari: 3947
Postat 24 December 2020 - 09:37 AM
Up si 20% reducere, daca nu le arunc la cos la finalul anului.
#21 Useril este offline   Ciprian97
  • Postari: 3947
Postat 01 January 2021 - 11:13 AM
Se scot de la vanzare, se muta in cosul de gunoi.
