Telemetrie de la Hitec Ca sa fim mai informati...:)
Postat 06 January 2011 - 11:30 AM
Drept urmare, ignorand gerul de afara (7 grade cu minus) si multe alte treburi care le aveam de facut ieri, am decis sa-mi aloc 15 minute "bolii incurabile" si sa-mi fac de cap. Pentru asta am ales ca platforma de test Funjet-ul, pe care nu-l zburasem de mult si se preta perfect la aterizari in zapada. Deci:
Aeromodel : Funjet Ultra
Senzori : temperatura (montat la ESC), turatie (optic), GPS si temperatura mediu ambiant (cel de la masina :) )
Statie : Hitec Aurora
Baterie : un pack obosit de 3S 2200mAh, pe care nu am mai montat senzor de temperatura...de lene.
Ce a rezultat va povestesc din foto:
Sensor station-ul si gps-ul (placut surprins ca nu trebuie sa-l scot afara)
Number of downloads: 90 IMG00008_20110104_1550.jpg (49K)
Senzorul de RPM, montat cam departe (nu am vrut sa-l prelungesc doar pentru Funjet)
Postat 06 January 2011 - 11:38 AM
Number of downloads: 77 Berceni_flight_log.jpg (140.32K)
Number of downloads: 76 Berceni_flight_log__2_.jpg (153.75K)
Postat 06 January 2011 - 11:58 AM
apropo sensorul magnetic de rpm cum se contecteaza ?
Aceasta postare a fost editata de Iamzoli: 06 January 2011 - 11:59 AM
Postat 06 January 2011 - 12:11 PM
T-REX 600N/OS55HZ-R
T-REX 700X
T-REX 800 TOURBINE
RAPTOR 90 SE gasser
HENSELEIT 3DNT
Save the flybar !!
Postat 06 January 2011 - 12:49 PM
T-REX 600N/OS55HZ-R
T-REX 700X
T-REX 800 TOURBINE
RAPTOR 90 SE gasser
HENSELEIT 3DNT
Save the flybar !!
Postat 06 January 2011 - 01:04 PM
Ice9, la Jan 6 2011, 12:28 PM, a spus:
Anul trecut inseamna pana acum o saptamana. :) Deci Furios a zis adevarul.
Aceasta postare a fost editata de navigator: 06 January 2011 - 01:05 PM
Postat 06 January 2011 - 01:31 PM
Number of downloads: 22 optima_6_lite.png (67.76K)
We put the already lightweight Optima 6 on a diet and came up with the Optima 6 Lite. Built with a thin Lexan case and weighing under 10 grams, our ultra-dependable, full-range 6-channel receiver is the perfect answer for small aircraft. The Optima 6 Lite utilizes our 2.4GHz AFHSS technology, exclusive single Boosted Omni-Directional Antenna and selectable Scan Mode ensuring an interference-free, full-range connection at an unbeatable 0price.
Lightweight and affordable – what else could you ask for?
Features
Full-range Operation
35% Lighter Weight than the Optima 6
Thin, Lexan Case
Built-in Battery Telemetry Function
“Brownout” Prevention Supplemental Power Connection (SPC) Port
Single Boosted Omni-Directional Antenna
Selectable Smart Scan Mode
Fail Safe/Hold Function
Postat 06 January 2011 - 01:33 PM
#12
Postat 06 January 2011 - 01:38 PM
#13
Postat 06 January 2011 - 01:50 PM
Iamzoli, la Jan 6 2011, 01:38 PM, a spus:
Daca imi aduc bine aminte pana la 4 pale...trebuie sa verific. Hitec spune urmatoarele:
RPM Sensors
There are two different RPM sensors available for use on the Hitec telemetry system.
1. Optical RPM Sensor (HTS-ORPM) - provides RPM information using a optic sensor. This is used for outdoor heli head speed RPM values.
NOTE: Indoor lighting and outdoor lighting variations can affect the readings of the optic sensor.
2. Magnetic RPM Sensor (HTS-MRPM) - provides RPM information using a magnetic sensor. This is used for aircraft with propellers, ducted fans, and heli tail rotors and main gears.
#14
Postat 06 January 2011 - 01:55 PM
#15
Postat 06 January 2011 - 02:05 PM
dan_mitea, la Jan 6 2011, 01:55 PM, a spus:
Varinta blue are in plus un senzor de curent si unul de tensiune si in minus senzorul pentru carburant. :)
http://www.hitecrcd.com/products/aircraft-...ts-ss-blue.html
Our compact sensor station collects data from each sensor of your electric powered aircraft sending it back to your transmitter via the Optima 7 or Optima 9 omni-directional receivers
4 Temperature Sensor Ports (HTS-TEMP)
2 RPM Sensor Ports (HTS-RPM)
Current Sensor Port (for 50Aor 200A Sensor)
Voltage Sensor Port
GPS Port (HTS-GPS
Part Number: 55846
Aceasta postare a fost editata de silver arrow: 06 January 2011 - 02:08 PM
#17
Postat 06 January 2011 - 02:18 PM
#18
Postat 06 January 2011 - 02:34 PM
#22
Postat 03 February 2011 - 07:34 PM
Ice9, la Jan 10 2011, 02:31 AM, a spus:
La mine nu a fost cazul. am facut upgrade la tx , apoi la spectra , apoi la rx si au mers din prima fara probleme. NU a trebuit sa ii rebinduiesc
#23
Postat 06 February 2011 - 11:43 PM
dan_mitea, la Jan 6 2011, 02:12 PM, a spus:
Sunteti multumiti de Aurora9?
Super statie merita efortul financiar pe deplin
#24
Postat 07 February 2011 - 02:24 PM
#25
Postat 07 February 2011 - 09:44 PM
dan_mitea, la Feb 7 2011, 02:24 PM, a spus:
Eu am folosit inregistrare in timp real...deci puteam inregistra de cati "giga" aveam hard-ul. :D
#26
Postat 07 February 2011 - 09:53 PM
Iamzoli, la Feb 3 2011, 07:34 PM, a spus:
Eu le-am rebind-uit, pentru ca probabil, nu am facut si upgrade-ul la toate RX-urile (am 5 receptoare Optima 6, care nu intra in discutie la telemetrie si nu m-am gandit sa le upgradez, in fara de cele 3 Optima 7 si un Optima 9). :D
#27
Postat 08 February 2011 - 02:30 AM
#28
Postat 08 February 2011 - 11:47 AM
dan_mitea, la Feb 8 2011, 02:30 AM, a spus:
Ar trebui sa poata sa inregistreze informatiile pe un tip de memorie...si nu stiu care componenta poate sa faca asta...in laptop, genereaza 2 fisire (de aprox. 700k la un zbor de 4min.), care se deschid cu soft-ul HPP22. Eu nu am vazut optiune de download de pe modul sau orice altceva. Oricum, daca nu te "plimbi" mult in timp ce pilotezi, un cablu ceva mai lung miniUSB - USB, rezolva toata problema...nu trebuie sa ramai atent decat la model, iar programul isi face treaba...acasa te delectezi cu rezultatele si imaginile in GoogleEarth. :rolleyes:
Pot sa-ti trimit cele 2 fisiere generate pe care le deschizi cu Google Earth si HPP-22, ca idee... :rolleyes:
#30
Postat 08 February 2011 - 07:21 PM
In descrierea interfetei:
http://www.hitecrcd.com/products/aircraft-...acc/hpp-22.html
spune asa:
•Radio, Module and Receiver Firmware Upgrade
•Radio, Module and Receiver Data Setting
•Data save and Load to PC
•Data Reset
•Auto Version Check
Eu am interpretat ca as putea citi datele dupa zbor...asa sa fie? Sau am interpretat asa cum mi-ar place?
