Modelism - RHC Forum: Motor BL Marine 2856 / KV2300 - Modelism - RHC Forum
Motor BL Marine 2856 / KV2300 Ce o fi de capul lui?
#1 Useril este offline   HESS
  • Postari: 955
  • Inregistrat: 08-October 07
Postat 02 February 2008 - 07:53 PM
Are cineva asa ceva? Sa fi ceva de el?
Motor BL Inrunner Marine 2856 / KV2300
Specificatii:
Tensiune: 6 - 12 volti
Curent in gol: 1.8 A
Curent in sarcina: aprox. 39 A
Curent maxim in sarcina: 47 A
Turatie in gol: 2300 rot/min/volt
Masa: 189 g
Lungime: 67 mm
Diametru: 35 mm
Lungime ax: 15 mm
Diametru ax: 4 mm
Regulator recomandat: 60 A (eventual cu reverse)
  • Imagine atasata: post-8-1201974792.jpg
#2 Useril este offline   alexroad
  • Postari: 621
  • Inregistrat: 29-June 07
Postat 03 February 2008 - 11:20 AM
Daca il folosesti la navo e OK deoarece e cu racire cu apa.
Eu am asa ceva
am comandat altceva si mi-a venit asta (sau poate am gresit eu),dar sigur o sa ii gasesc o intrebuintarehttp://www.hobbycity.com/hobbycity/store/u...?idProduct=5146
Aceasta postare a fost editata de alexroad: 03 February 2008 - 11:30 AM
Hodina-i ca slanina
Sa te maturizezi e optional!
#3 Useril este offline   HESS
  • Postari: 955
Postat 03 February 2008 - 12:54 PM
Cam puturoase in ture... B) Pacat.
#4 Useril este offline   fulgerica
  • Postari: 2235
  • Inregistrat: 31-July 07
  • Interests:vintage
Postat 03 February 2008 - 01:16 PM
nu trebuie sa te iei dupa turatia in gol. pe pagina urmatoare a saitului e si un 3656 / 1800 kv care duce mai mult decat 3656 / 04 care are vreo 3500 ture/ volt.
Laser frate!
#5 Useril este offline   HESS
  • Postari: 955
Postat 03 February 2008 - 01:29 PM
fulgerica, la 3 Feb 2008, 13:16, a spus:
Stai ca nu am inteles... Ai gasit un BL marine care are 3500rpm/V???
#6 Useril este offline   HESS
  • Postari: 955
Postat 03 February 2008 - 01:38 PM
Aero....
#7 Useril este offline   nelu bv
  • Postari: 658
  • Inregistrat: 19-May 07
Postat 03 February 2008 - 03:34 PM
HESS, la 3 Feb 2008, 12:54, a spus:
salut .
lamuriti-ma si pe mine,2300rpm/v inseamna 2300*12=27600. e putin ?
dar nu asta e nelamurirea.
care e avantajul folosirii unui motor BL?
consuma foarte mult. exemplul de fata 39 A. deci un accu de 4A il termina in aproximativ 6 minute.
deci ?
Decat sa bei si sa conduci mai bine fumezi si zbori !!!!!!!
#8 Useril este offline   Dexter_Jr
Postat 03 February 2008 - 03:38 PM
brushless-urile au eficienta mai mare.
la aceleasi caracteristici un motor brushed ar fi mai mare, mai greu si ar consuma mai mult
#9 Useril este offline   HESS
  • Postari: 955
Postat 03 February 2008 - 06:04 PM
Dexter_Jr, la 3 Feb 2008, 15:38, a spus:
plus ca la aceeasi putere trebuie o racire supradimensionata.... perii schimbate... Naspa! Renuntati la perii :rolleyes:
#10 Useril este offline   HESS
  • Postari: 955
Postat 03 February 2008 - 06:09 PM
nelu bv, la 3 Feb 2008, 15:34, a spus:
Cam puturoase in ture... :(  Pacat.
salut .
deci ?
Putin frate, putin, mai ales ca si alea sunt in gol :( In apa raman doua trei ture pe volt... :rolleyes: :) cat sa se tarasca...
#11 Useril este offline   dily
  • Postari: 1383
Postat 05 February 2008 - 07:43 PM
hess..........te contrazic
Eu am pe barca (scorpia -- gasesti filmulete cu ea pe forum) motorul ala de la roxy de 1800 rpv....parca....si are 410w. Fuge de rupe cu pak de 5 cel lipo (chiar ci cu 3 cel merge f. bine), asta cu elice de 45 Graupner, deci eu merg pe varianta ca la navo ai nevoie de forta in dertrimentul turatiei.
Motorul ala de care zici e cam chinezesc.....nu prea as avea increderein el ....eu am mai incercat la navo si alte motoare bl. made in china si nu prea am fost multumit, in special de consumul f. mare in sarcina.
nr. de telefon......
0744.35.25.89
0727.88.75.46
#12 Useril este offline   AG-74-HESS
  • Postari: 3573
  • Inregistrat: 04-February 08
Postat 06 February 2008 - 05:30 PM
Nu ma poti contrazice, ca doar am intrebat daca e ceva de el :)
As vrea sa-l cumpar... Ca am spus ca mai are una, doua ture in apa, iti dai seama ca am glumit :D
Deci tu ce zici, ala marine la 2300, nu se merita?
#13 Useril este offline   dily
  • Postari: 1383
Postat 07 February 2008 - 01:27 AM
nu stiu ce sa zic.........mi se pare cam scump si nu stiu absolut nimic de firma producatoare........daca vrei performante.....nu face
0744.35.25.89
0727.88.75.46
#14 Useril este offline   nelu bv
  • Postari: 658
Postat 07 February 2008 - 10:06 PM
va rog frumos recomandati-mi si mie un bl de la concurenta sau din alta parte.
vreau sa il folosesc pe o coca de fsr lunga de 80 cm. as vrea totusi ceva cu un consum redus
mersi :angry:
#15 Useril este offline   iony
  • Postari: 2346
  • Inregistrat: 06-April 07
Postat 08 February 2008 - 06:28 PM
pai daca vrei un consum redus o sa ai si viteza redusa :D
#16 Useril este offline   AG-74-HESS
  • Postari: 3573
Postat 08 February 2008 - 10:25 PM
nelu bv, la 7 Feb 2008, 22:06, a spus:
mersi   :D
Cat mai multi W, cat mai multe ture! :D Normal ca in functie de cat de ``suparat`` este motorul, si curentul absorbit va fi mai mare...
Alchimistii au disparut, ei ``puteau ``face din plumb aur..... Daca mai erau si astazi, scoteau 10KW dintr-o baterie de ceas.
Deci vrei mai mult, dai mai mult! Asa este fizica asta zgarcita.... :D
Aceasta postare a fost editata de AG-74-HESS: 08 February 2008 - 10:54 PM
#17 Useril este offline   AG-74-HESS
  • Postari: 3573
Postat 19 May 2008 - 06:03 PM
HESS, la 2 Feb 2008, 19:53, a spus:
Specificatii:
Masa: 189 g
Lungime: 67 mm
Diametru: 35 mm
Lungime ax: 15 mm
Diametru ax: 4 mm
Intrebasem daca e ceva de acest motor, dar cum nu il testase cineva, m-am gandit sa incerc... Daca mai sunt curiosi sa incerce, cam asta a iesit ( cu 3 lipitori de 4A):
http://www.youtube.c...h?v=O4FB_i6aHpA
