Modelism - RHC Forum: constructie aeromodel - Modelism - RHC Forum
constructie aeromodel se poate??
#31 Useril este offline   Great Snoopy
  • Postari: 8
  • Inregistrat: 27-March 06
Postat 26 June 2007 - 10:07 AM
Daca e foaaarte usor (deci incarcare alara extrem de mica) si daca grosimea aripii este infima comparativ cu suprafata sa.Aripa aia a ta pare mai degraba o caramida, iar tu te astepti sa zboare cu un motirici mic. Desigur, "with enough thrust pigs fly just fine" insa tu ai doar porcu' dar nu si destula forta :huh:
#32 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
  • Inregistrat: 03-February 07
  • Interests:AEROMODELISM
Postat 26 June 2007 - 10:20 AM
http://www.rhc.ro/forumrhc2/index.php?act=...=post&id=159548
...fal asa.
ADOR VITEZA!!!
#33 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 26 June 2007 - 10:22 AM
uite si cum zboara....
http://www.youtube.c...h?v=0cAWDJHtX1A
sper sa-ti fie de folos imaginea.
ADOR VITEZA!!!
#34 Useril este offline   Stunt23
  • Postari: 73
  • Inregistrat: 12-June 07
Postat 26 June 2007 - 10:42 AM
Imi dai si mie niste dimensiuni la avionu tau
#35 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 26 June 2007 - 10:47 AM
1000x960.....
Motor brushless ROXXY 2827/34
elice EPD1060
Aceasta postare a fost editata de TUROK: 26 June 2007 - 10:50 AM
ADOR VITEZA!!!
#36 Useril este offline   Stunt23
  • Postari: 73
Postat 26 June 2007 - 11:23 AM
Cum ai prins bagheta care vine de la aripa la "coada".Ai foloit adeziv?Bagheta e rotunda?Pot sa folosesc un segment de undita?? http://www.rhcforum....tyle_emoticons/default/rolleyes.gif
#37 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 26 June 2007 - 11:27 AM
bagheta este tija carbon de 6mm..lipita cu epoxi5 min.
ADOR VITEZA!!!
#38 Useril este offline   Stunt23
  • Postari: 73
Postat 26 June 2007 - 11:30 AM
De care acumulator folosesti si cam la ce greuate a ajuns tot aeromodelu'
#39 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 26 June 2007 - 11:36 AM
cu tot cu electronika dar fara acumulatot 530g....iar ca acumulatori folosesc li-po 1300-1800mAh
ADOR VITEZA!!!
#40 Useril este offline   Stunt23
  • Postari: 73
Postat 26 June 2007 - 04:20 PM
Dupa ce l-am modificat am avut si succese!!!!Primu zbor 5 secunde fara prabusire,al doilea 3 secunde nu s-a intamplat nimik,al treilea zbor a fost cel mai super,mai mult a planat decat a zburat dar a stat in aer 20 de secunde(nu mai mult ca fratii Wright) http://www.rhcforum....tyle_emoticons/default/rolleyes.gif dar.....s-a rupt elicea si nu mai am alta :D .avand in vedere ca nu are profundor eu zic ca m-am descurcat bine.Marti poate imi vin elicile si inca un servo pentru un profundor si sa vedeti atunci.
#41 Useril este offline   Stunt23
  • Postari: 73
Postat 26 June 2007 - 04:25 PM
Dupa modificari si crash
  • Imagine atasata: post-28-1182867932.jpg
#42 Useril este offline   Stunt23
  • Postari: 73
Postat 26 June 2007 - 04:27 PM
Banda adeziva la greu
  • Imagine atasata: post-28-1182868053.jpg
#43 Useril este offline   alexroad
  • Postari: 621
  • Inregistrat: 29-June 07
Postat 29 June 2007 - 11:46 AM
caut planuri aeromodele detaliate pentru avioane de vinatoare
Hodina-i ca slanina
Sa te maturizezi e optional!
#44 Useril este offline   Dexter_Jr
Postat 29 June 2007 - 04:32 PM
@stunt23
ia electronica jos de pe model...agata-l intr-un cui pe perete si pune mana si ia un ez star si invata sa zbori
#45 Useril este offline   Valteras
Postat 29 June 2007 - 04:56 PM
Stunt23, la 25 Jun 2007, 21:46, a spus:
doi
...Clasica problema cu elicea pusa invers...
...Si ca de obicei, numa' io ma prind...
Poza...
#46 Useril este offline   Emilare
  • Postari: 673
  • Inregistrat: 10-March 03
Postat 29 June 2007 - 05:20 PM
Nu-i adevarat.....ala e spatele aveonului... ;) :rolleyes:
#47 Useril este offline   alexroad
  • Postari: 621
Postat 29 June 2007 - 05:37 PM
are dreptate Emilare.avionul nu prea are nici un profil iar ca motor probabil ca un brushless ar fi mai indicat,ca sa nu mai spun ca la asa forma ,sunt necesare niste concordante intre fuselaj si aripi,unghi de atac ,etc
Hodina-i ca slanina
#48 Useril este offline   TUROK
  • BAGA VITEZA
  • Postari: 3708
Postat 30 June 2007 - 01:46 AM
poate el doreste sa zboare dea-n daratelea!!!! :rolleyes: http://www.rhcforum....tyle_emoticons/default/ic_13.gif
ADOR VITEZA!!!
#49 Useril este offline   dan_mitea
  • Postari: 9328
Postat 09 July 2007 - 05:11 AM
Un manual, interesant zic eu, cu informatii elementare despre modele:
http://www.carlgoldbergproducts.com/Genera...Information.pdf
Si un articol despre cum sa alegem culorile:
http://www.ultimatec....com/color.html
Aceasta postare a fost editata de Se poate si asa ?: 11 July 2007 - 02:17 AM
#50 Useril este offline   RichieYo
  • Postari: 145
  • Inregistrat: 14-July 07
Postat 15 July 2007 - 08:48 PM
salut. as dori sa construiesc un aeromodel electric cu mana mea dar nu prea stiu ce componente sa folosesc. sunt nou incepator in aeromodelele cu motor electric, nu am mai construit numai planoare simple. va rog sa ma ajutati sami ziceti cam ce model ar trebui sa folosesc si componente.
"Traim in Romania si asta ne ocupa tot timpul"
#51 Useril este offline   Stunt23
  • Postari: 73
Postat 10 August 2007 - 12:37 PM
Am reusit sa construiesc un avion controlabil dupa o luna si jumatate de documentare si teste.am pus pe el un motor 400 cu reductor regulator de 30 A acumulator ni-mh la 190 grdoua servo sg-90 la profundor si sg-50 la carma.face si looping dupa cum o sa vedeti in filmu pe care o sa-l pun.este facut din polisteren extrudat de 7 mm si un bat de undita.elice este 12x8.
#52 Useril este offline   Stunt23
  • Postari: 73
Postat 10 August 2007 - 12:38 PM
http://www.youtube.c...h?v=MkHp3Yf3LbU asta e video. :rolleyes:
#53 Useril este offline   Stunt23
  • Postari: 73
Postat 10 August 2007 - 12:40 PM
Multumiri lui turok si lui evrikus in special.Si celorlalti care m-au ajutat!!
#54 Useril este offline   SILVIU66
  • Postari: 6866
Postat 10 August 2007 - 12:55 PM
mai lucreaza un pic la centraj ca e greu de coada.....
in rest felicitari!
#55 Useril este offline   Marinaru
Postat 10 August 2007 - 01:01 PM
SILVIU66, la 10 Aug 2007, 13:55, a spus:
in rest felicitari!
sau aripa mutata putim mai spre coada!
#56 Useril este offline   Stunt23
  • Postari: 73
Postat 11 August 2007 - 12:47 PM
Am fost cu avionu ieri pe un vant destul de puternic si nu face fata.se da peste cap o ia razna.abia am reusit sa-l aterizez fara sa pateasca nimic. -_-
#57 Useril este offline   Stunt23
  • Postari: 73
Postat 12 August 2007 - 10:31 AM
Am luat niste roti din alea ultra usoare de 76 mmsi nu prea stiu cum pot sa le pun la avion.daca aveti poze cu trenuri de aterizare facute de voi postati va rog.la fiecare aterizare se rupe pentru ca l-am lipit de polisteren.cum lipesc trenul de aterizare de teava aia de fibra??
