Modelism - RHC Forum: Tehnologie noua - Modelism - RHC Forum
Tehnologie noua 99% antibruiaj de la MZK
Postat 03 May 2006 - 05:04 PM
unul dintre cele mai interesante workshopuri de la ALBA s-a desfasurat in felul urmator:
eu si prietenul meu Atty zburam in acelasi canal ,si m-a invitat sa incerc sa-l bruiez (la sol of-cors :D )
- a pornit omul statia ,a pornit receptorul ,a asteptat 3 secunde......si m-a invitat sa pornesc si eu statia !!!
(ambii eram in acelasi canal ambii cu PPM)
SURPRIZA!!!
MODELUL IN CONTINUARE ASCULTA PERFECT DE STATIA LUI IAR DE A MEA DELOC!!!
ambii ne aflam la mai putin de 1 m de model ,iar statia mea parca nici nu era pornita.
receptorul pe care il folosea pe numele lui OCTAVA produs de MZK include o functie care se cheama TSR ( Transmitter Signature Recognition) si aceasta functie nu-l lasa sa asculte decat de statia "de pe care a boot-at"
bineinteles ca invers pornind intai statia mea si receptorul dupa ,modelul asculta DOAR de statia mea fara sa mai asculte de statia originala a proprietarului.
e?
ce ziceti de treaba asta?
am forat putin pe net si am gasit niste descrieri pe care nu am timp sa le traduc acuma dar se intelege foarte bine:
A Professional Series receiver with high reliability and interference resistance due to a special RF-input circuit design as well as the application of TSR, DSP, HOLD, FS and QR program functions. This receiver allows safe flying in areas with high interference levels where flying was formerly impossible.
The receiver contains a fully programmable FS system on all channels.
DSP (Digital Signal Processing) describes the function of a very precise digital filter inside the microprocessor decoder which contains adaptive algorithms following the signal/noise ratio of the received signal. This filter sends correct output pulses to the relevant receiver channel outputs, incorrect pulses are discarded and short term replaced by correct pulses received last.
TSR (Transmitter Signature Recognition). The receiver learns and remebers the number of channels, the keying pulse lengths and the approximate frame timing of the transmitter. After this only a few seconds lasting "booting period" the receiver will only listen to your type of transmitter. This so called TSR process is refreshed everytime the receiver is switched on and works with all types of FM transmitters.
HOLD: In case of signal loss all servos are held for 2 seconds in their last position, after that time these pulses decease and can be without any delay replaced by oncomming correct pulses or fail safe pulses.
FS: In case of FS mode activation (FAIL-SAFE mode, programmable by the user) the servo outputs keep for approx. 2 seconds their last positions (HOLD), after 2 seconds the servo outputs change to fail-safe servo positions formerly programmed by the user.
QR: Quick Recovery means a delayless recovery of the correct signal after its previous loss or after fail-safe activity (much faster than with PCM-FS systems).
Notice:
This receiver is assigned for the use of standard size crystals. We strongly recommend the use of high precision MZK crystals.
nu mai spun ca receptorul merge cu orice tip de statie,ca are auto-shift recognition .......s.a.m.d.
si cel mai buna treaba este ca e mai ieftin decat un receptor PCM.
Aceasta postare a fost editata de SILVIU66: 03 May 2006 - 05:07 PM
Postat 03 May 2006 - 07:12 PM
Am gasit si io niste materiale referitoare la tipu' asta de protectie. Incerc sa gasesc link-urile, da' cum am avut --> format c:..., nu mai stiu pe unde le-am ... mutat. Se adevereste faptul ca lucrurile simple sunt si foarte eficace. Se pare ca ieftinatatea de care zici tu, e data de principiul ff simplu pe care se bazeaza si anume identificarea foarte precisa a duratei unui frame, adica al unui pachet de date care contine si numarul de canale ale Tx-ului. Cele 3 secunde de care are nevoie Rx-u' ala, sunt necesare pentru calarea si memorarea duratei exacte a unui frame si identificare numarului de canale. Receptoru' are niste circuite speciale (de fapt e un procesor dedicat acestei functii de protectie, care lucreaza cu filtre digitale care se "muleaza" pe semnalu' initial, foarte precise !), indiferent de sursa lui. Orice alt semnal de radiofrecventa este ignorat, daca nu are parametrii pe care i-a recunoscut la inceput, in cursul celor 2-3 secunde de initializare. Odata calat pe purtatoarea initiala, receptoru' nu demoduleaza decat acea purtatoare si decodoru' de canale, nu decodeaza decat semnalu aferent acelei purtatoare RF.
Deci, are doo criterii de recunoastere: durata frame-ului si numarul de ch. Face o logica simpla AND intre aceste doo criterii, si daca cel putin unu' nu e indeplinit, intra in FS. S-ar putea sa mai fie si alte cele, da' cam asta am retinut. Mi se pare o solutie taaare eleganta si simpla. Se pare ca isi construieste referintele de frecventa pt procesoru' de date din purtatoarea Rf, motiv pentru care se insista asupra utilizarii quarturilor dedicate, MZK.
Este genu' de Rx care invata parametrii Tx-ului de la initializare si nu-l mai vrea decat pe ala.
Buna treaba !!
Luci, l-a vazut ?? :D
Postat 03 May 2006 - 08:02 PM
Tehnologia asta e veche de mai mult de 1 an. Poate si doi. Unii au reusit-o mai bine, altii mai putin (dar se lauda cu ea, bineinteles).
#4 Useril este offline   Atty
  • Postari: 81
  • Inregistrat: 12-January 04
Postat 03 May 2006 - 09:55 PM
Pai cum o fi sau cum nu o fi ...ideea este ca functioneaza. Eu unul sunt foarte multumit de aceste receptoare . Pe langa cele spuse mai are functia de hold de pana la 5 sec si fail safe programabil.
In 2005 a fost prezentat in revista FMT din Germania ca cel mai reusit receptor al anului 2005.
E bine sa vezi ca se lucreaza tot mai mult in directia asta de siguranta .
Postat 04 May 2006 - 10:59 AM
Bine mah, @silviu66, si sa nu ma tragi tu de maneca, :D , acolo la Alba si sa-mi arati minunea ... http://www.rhcforum....tyle_emoticons/default/ic_05.gif :huh:
#6 Useril este offline   Red Sky
  • Gold Member
  • Postari: 935
  • Inregistrat: 15-March 06
Postat 20 March 2007 - 01:01 PM
domnu_doctor, la 3 May 2006, 19:12, a spus:
Luci, l-a vazut ??
V-am demonstrat practic (cred ca la Oradea) ca se poate bruia destul de usor. Pare sa aibe o oarecare "ghidusie" in plus la recunoasterea semnalului dar daca vorbim de calitatea receptiei... no comment.
Eu n-o sa folosesc asa ceva. (adica "punct")
www.redsky.ro
Postat 20 March 2007 - 01:35 PM
@ Red Sky. Te rog sa-mi spui ce parere ai despre receptoarele Berg.
http://www.castlecre...ducts/berg.html
Multumesc anticipat.
Aceasta postare a fost editata de Se poate si asa ?: 20 March 2007 - 01:40 PM
Postat 20 March 2007 - 03:27 PM
Red Sky, la 20 Mar 2007, 14:01, a spus:
nici eu nu folosesc.atunci am fost incantati,intre timp parerile se mai schimba...
poate ne povestesti ce si cum...
#9 Useril este offline   Spitaludenebuni
  • Postari: 71
  • Inregistrat: 08-January 07
Postat 20 March 2007 - 09:23 PM
Sunt foarte frumoase!
#10 Useril este offline   Red Sky
  • Gold Member
  • Postari: 935
Postat 20 March 2007 - 11:49 PM
Imi pare rau dar nu le cunosc. Nu pot sa-mi exprim nici o parere, nici macar subiectiva.
Aaa, poate doar ca sint (vorba calului :D ) foarte frumoase.
Pai foarte simplu:
Atty si-a pornit statia si receptorul dupa care eu mi-am pornit statia mea => i-am "luat" comanda.
Avand doar statii Graupner/JR, folosesc numai receptoare de aceeasi marca.
Pe modele serioase EXCLUSIV SPCM-DS iar in rest SPCM.
www.redsky.ro
#11 Useril este offline   melsoft
  • Postari: 414
  • Inregistrat: 16-April 05
  Postat 21 March 2007 - 08:31 AM
Daca tot veni vorba de libertatea de frecvente, ati vazut noua statie de la FUTABA DX9??? E declarata ca nefiind afectata de nimic, merge in 2.4GhZ. Pt cei care vor mai mult am aici mai multe informatii despre generatia mai veche DX7.
Aceasta postare a fost editata de melsoft: 21 March 2007 - 08:35 AM
