Modelism - RHC Forum: Volantex Ranger 2000 - Modelism - RHC Forum
#1 Useril este offline   Tealk
  • Fly Low, Go Fast, Turn Left
  • Postari: 767
  • Inregistrat: 13-May 09
  • Interests:Aero, Navo
Postat 10 May 2026 - 01:00 PM
Se vinde Volantex Ranger 2000 cu foarte putine zboruri la activ, cumaparat in toamna lui 2025, dar prea vitezoman pentri mine la aterizare ... nu are probleme ...se vinde in varianta PNP.
Technical specification based on the different versions:
Wingspan: 2000mm
Overall Length: 1100mm
Prop Size: 8040 Folding Propeller
Motor Size: 2215/1400KV powerful out runner brushless motor
Speed Control: Easy-Plug 30A Switch-mode BEC brushless ESC
Servo 9-gram Servo * 6pcs
Necesita Radiocomanda, receptor si o baterie 3s 5200mAh ...se echilibreaza foasrte bine cu 5200mAh, cu 2200mAh conform specificatiilor nu se echilibreaza si necesita greutati ...nu isi au rostu ..zburat undeva la 40 min lejer cu 5200mAh
NU TRIMIT IN TARA!!! VA ROG NU INSISTATI, PREDARE PERSONALA IN CLUJ-NAPOCA
Pret 750 Ron PNP... (Nu se da giroscopu si receptoru ce se vede in poze)
0735276142 = prefer mesaj pe whatsupp
Cessna 182 2.2m
Volantex Trainstar Ascent
DJI Mini 4 PRO
Hornet Tunel Hull Sprint F1
Fly Low. Go Fast. Turn Left.
Do. Or do not. There is no try.
#2 Useril este offline   Tealk
  • Postari: 767
Postat 10 May 2026 - 01:07 PM
alte poze
alte poze
Cessna 182 2.2m
DJI Mini 4 PRO
#3 Useril este offline   Tealk
  • Postari: 767
Postat 14 May 2026 - 07:55 PM
pana in data de 20.05.2026 pretul se reduce la 600 ron
Cessna 182 2.2m
DJI Mini 4 PRO
#4 Useril este offline   Tealk
  • Postari: 767
Postat 26 May 2026 - 05:53 AM
650 Ron
Cessna 182 2.2m
DJI Mini 4 PRO
