PRET: 3200 RON negociabil
Traxxas UDR + acumulatori 2S + incarcator IMAX.
Lista completă upgrade-uri:
- Traxxas steel bubs / hex
- Traxxas front GTR blue springs
- Traxxas rear GTR blue springs
- Vitavon travel limit straps
- Aluminium steering assembly kit (bell crank + servo saver + link)
- GPM hardened steel thickened center front drive shaft
- GPM hardened steel front drive cups
- GPM extra duty front CVD with stainess steeel joints and hardened steel bodys
- GPM hardened steel thickened rear drive shaft
- GPM stainless steel swaybar complete kit
- GPM alloy thickened front upper arm stabilizer
- GPM stainess steel adjustable upper chassis links
- GPM 7075 aluminium axle carriers
- GPM aluminium front upper suspension arms
- GPM aluminium front lower suspension arms
- GPM aluminium front steering/tow links
- GPM 7075 aluminium rear trailing arms
- GPM aluminium servo mount
- GPM aluminium servo horn
- GPM aluminium adjustable servo rod
- GPM aluminium rear shock/damper mounts
- GPM aluminium front shock/damper mounts (nu sunt montate)
- GPM aluminium spare tire locking nuts
- RC4WD Raceline Monster 2.2”/3.0” beadlock aluminium rims
- 9imod 71kg digital brushless waterproof metal gear steering servo
- Ruddog 40mm fan (pentru motor)
- XT90 plugs
+ inca un set de 4 jante+anvelope orignale (cele rosii)
+ un set de 4 anvelope + 2 jante.
Traxxas UDR 1/7 + 4 acumulatori + multe extra
Postat 15 September 2025 - 04:25 PM
Am intampinat o problema la internet va rog stergeti postul duplicat ! Multumesc !!!
