Nu am reusit sa-l fac sa zboare, din pacate, si sta degeaba in dulap (prindere elice principala din plastic rupta).
Pret final pentru tot pachetul, nu vad separat componente, este de 800 ron.
HK-450 CCPM 3D Electric Helicopter Kit (Align T-rex Compatible) Modeled on the famous and proven Align T-Rex 450.
90% parts are compatible with the Align T-Rex 450.
Spec.
Length:660mm
Height:230mm
Main Blade Length:325mm
Main Rotor Diameter:700mm
Tail Rotor Diameter:150mm
Motor Pinion Gear:12T/13T (Not included)
Main Drive Gear:150T
Autorotation Tail Drive Gear:106T
Tail Drive Gear:25T
Weight(w/o blade):450g
Flying Weight:730~760g
Upgraded belt pulley gear & shaft. (No-slippage)
- Radio comanda Turnigy TGY 9X - 350
- Reciver 9X 2.4 GHz 8Ch v2 - 60- Brushless Motor Typhoon 2215 -75- ESc Birdie 50A - 75- Giro Assan GA250 - 65- Baterie Lipo Turnigy 2200 mAh - 130
- HobbyKing™ HKSCM9-6 Singlechip Digital Micro Servo 0.8kg / 0.11sec / 10g - 4buc - 60
Aceasta postare a fost editata de adi_aspri: 11 August 2024 - 03:06 PM
