Vand aeromodel P-38 Lighting - model Flight LineWingspan 1600mm / 63inLength 1168mm / 46inWeight (w/o battery) 3150gElectronic Speed Control 60A Brushless with XT60 connectorPropeller 12x7 3 Blade Propeller x 2Servos9g hybrid gear standard with 300mm lead: nose gear door9g hybrid gear reverse with 300mm lead: nose gear steering, right outboard flap, right inboard flap9g hybrid gear standard with 300mm lead: left outboard flap, left inboard flap, left aileron, right aileron9g hybrid gear standard reverse with 550mm lead: left gear door9g hybrid gear standard with 550mm lead: right gear door17g metal gear standard with 300mm lead: elevator9g hybrid gear standard with 100mm lead: left rudder, right rudderLanding Gear Electric retracts with metal trunionsRequired BatteryTwo 4 Cell 14.8v 2500mAh to 3000mAh batteries with XT60 connector, or One 4 Cell 14.8v 5000mAh battery with XT60 connector (will require an EC5-to-two-XT60-connector adapter)Ailerons YesElevator YesRudder YesFlaps YesLights YesHinge Type Nylon and foam hingesMaterial EPO FoamPret 2300 ronVand aeromodel Fieseler Storch - model HobbyKingWingspan: 1600mm (63")Fuselage Length: 1000mm (40")Flying Weight: 1.6~1.8Kg approx Battery - 2200~2800mah 3~4S Lipo batterymotor = PROPDRIVE V2 2830 1200KV Brushless Outrunner Motor esc = HobbyKing 50A (2~4S) ESC 4A UBEC servo x 8 = Turnigy™ TGY-50090M Analog Servo 20T MG 1.6kg / 0.08sec / 9g elice = 11/7 Pret 1500 ronModelele nu au fost zburate niciodata,modelul P-38 are facuta de mine ,,imbatranire" pentru a simula modelul real,iar modelul Fieseler are camuflaj dupa poze reale.Le vand din lipsa de spatiu.Modelele sunt cu electronica completa,sunt necesari acumulatori si statie de radiocomanda.Modelul Fieseler a venit ca si kit de lemn si este montat,impanzit si vopsit de mineLink-uri catre paginile producatorilor:https://www.motionrc.eu/collections/rc-warbirds/products/flightline-p-38l-lightning-allied-green-1600mm-63-wingspan-pnphttps://hobbyking.com/en_us/h-king-fieseler-fi-156-storch-balsa-wood-rc-laser-cut-airplane-kit-1600mm-63-for-electric-or-i-c.html?queryID=43c67aa0d326c648c8faa257ceea2909&objectID=85934&indexName=hbk_live_products_analyticsPoze :https://ibb.co/YNhGqQdhttps://ibb.co/gJ0xRmvhttps://ibb.co/kDgY81Fhttps://ibb.co/HB8FZNKhttps://ibb.co/rwqrrKKhttps://ibb.co/gmWHLLghttps://ibb.co/LCjqkJ5https://ibb.co/SVqhHdYhttps://ibb.co/0hcGdRnhttps://ibb.co/0tdtvkphttps://ibb.co/ZTS7Bjx
Vand aeromodel P-38 Lighting si Fieseler Storch
Acest topic e inchis
