Modelism - RHC Forum: Vand ochelari FPV Eachine EV100 cu mini DVR inclus - Modelism - RHC Forum
#1 Useril este offline   adyrex
  • Postari: 1543
Postat 23 July 2021 - 11:35 PM
Vând Eachine EV100 Googles cu DVR inclus Eachine EV100 Micro AV Recorder 1280*480.
Ochelarii sunt foarte puțin utilizați, funcționează perfect împreună cu acest mini DVR.
Se vând cu antene, cablu AV, manuale.
Bonus: 1 carrying case pentru transport.
Îi vând pentru că am trecut la altceva.
Preț total: 480 ron.
Tel. 0740131438
Specificații:
Weight : 221g
Resolution : 720*540
FOV : 28° diagonal
IPD : 58-68mm
Ratio : 4:3
Frequency : 5.8G 5333Mhz-5945Mhz
Sensitivity : <=-93dB
Antenna Impedance : 50Ω
Antenna Gain : 3dBi
Antenna Connector : RP-SMA
Video Formate : NTSC/PAL
Support AV IN/OUT
Support Focal Length/Brightness/Contrast Adjustment
Suport Firmware Upgrading
Power Input : 7.4V
Low Voltage : 6.8V
Battery : Li-po 7,4 V 1000mAh
Charging : USB Cable
Eachine EV100 Micro AV Recorder 1280*480 Mini DVR
Operating Voltage: DC 5V/ 7.4V(2S)
Working Current : 200MA ~ 240MA
Video Format: NTSC/PAL
Video Output Size: VGA(640*480px)D1(720*480)HD(1280*480)
Light Frequency: 50HZ/60HZ
Compress Format: MJPEG
Video Format : avi.
Records Frame Rate: 30 Frames
Max Support: 32G TF Card
Weight: 9g
#2 Useril este offline   adyrex
  • Postari: 1543
Postat 23 July 2021 - 11:45 PM
Poze
#3 Useril este offline   adyrex
  • Postari: 1543
Postat 23 July 2021 - 11:47 PM
Poze
#4 Useril este offline   adyrex
  • Postari: 1543
Postat 05 August 2021 - 10:57 AM
UP.
450 ron
#5 Useril este offline   adyrex
  • Postari: 1543
Postat 24 August 2021 - 01:33 PM
VÂNDUT.
