Modelism - RHC Forum: Vand quad 5inch 4-6S F7 AIO VTX FPV - Modelism - RHC Forum
Vand quad 5inch 4-6S F7 AIO VTX FPV Matek F7, BLHeli_32, 800mW VTX, Emax RS II 2306, Runcam Nano 4
#1 Useril este offline   andrewbt
  • Postari: 1014
Postat 22 January 2021 - 11:47 AM
Vand quad complet 5inch 4-6S, componentele de calitate, cu BiDirectional DSHOT si RPM filtering, merge si 4S pt incepatori, stare foarte buna fara joc la motoare, am si receptor Frsky XM 16CH daca se vrea, se poate monta usor un GoPro in fata.
-Motoare EMAX Race Series II 2306 1700KV 4-6S (100$)
-FC Matek F722-SE F7 Dual Gyro AIO, PDB 2-8S, Baro, I2C, 5+1UART, OSD, BEC 5V/3A (49$)
-Frame Umbrella 230mm 4mm carbon (clona Armattan Rooster) (50$)
-ESC Airbot Wraith32 35A 2-6S DSHOT1200 BlHeli_32, cu telemetrie, senzor curent și LED RGB (75$)
-VTX TX805 5.8GHz 40CH 800mW SmartAudio nou (20$)
-Camera Runcam Nano 4 800TVL WDR (20$)
-Elici HQProp 5x4.3x3 Watermelon (10$)
+condesatori 470uF 35V pe fiecare ESC
+2buc brate rezerva originale Armattan (10$)
Pret: 900lei
Tel: 0749 121 132
Andrei
