https://www.mg-model...speech&speech=2
thumbnail (1).jpg (189.94K)
Preț 199 lei
Tel.0733-127486
This low-wing aircraft speed coaches in red-white outfit has been designed for flying enthusiasts who want to "whistle" with high speed across the field. A perfectly created model in wood construction is finished ready strung. The kit is more than fully equipped with fiberglass hood.
Technical specifications:
- Wingspan: 700 mm
- Length: 560 mm
- Weight: about 490g
- Brushless drives - For example, Engine Boost 10 Combo C3166
- Propeller: for example, 7 x 6 inches
- Battery: 3 cell Li- Po.
Scope of supply:
Colored cardboard, fuselage pre-covered in wood construction (red and white), Styro-balsabeplankte wing covered with finished surface linkages well done, finished rudder section covered with rudder, tailplane section strung ready (red, white), transparent thermoforming part of the cockpit and cockpit upgrade parts , high-gloss decal sheet, small parts to complete, pre-painted fiberglass cowling, building instructions in words and pictures. google translate
thumbnail (2).jpg (89.05K)
Number of downloads: 130 -
thumbnail (3).jpg (90.29K)
Aceasta postare a fost editata de SuperFly: 29 March 2020 - 06:50 PM
Acest topic e inchis
